Dell | 10/02/2023 16:58:06 |
![]() 230 forum posts 44 photos | Well after using my 17/70 Pultra for a while I was finding the maximum through bore of 8mm a bit restricted so I have finally bit the bullet and purchased a Myford ML10 , I can’t go any bigger because of space limitations, collecting it tomorrow touch wood it will fit in my B Class, couldn’t pass at the price,as I have mostly used a graver in the past and never turned threads it’s going to be another big learning curve but that’s good for the brain cells when we get old. |
Michael Gilligan | 10/02/2023 17:02:46 |
![]() 23121 forum posts 1360 photos | Those should make a nicely balanced ‘Team’ A very wise choice, I would think MichaelG |
roy entwistle | 10/02/2023 17:16:32 |
1716 forum posts | Do not use the switch shown as an on - off switch. It only designed for reversing the lathe while the lathe is stopped. Roy |
Roderick Jenkins | 10/02/2023 17:35:00 |
![]() 2376 forum posts 800 photos | That's a bit didactic. Not best modern practise perhaps but people have been using Dewhurst switches safely and successfully for the last 70 years. The contacts may get a bit pitted after half a century - a bit like putting a plug into an un-switched socket. Anyway, nice lathe Dell. You'll enjoy that. Rod |
Dave Wootton | 10/02/2023 17:35:15 |
505 forum posts 99 photos | Very nice, looks pristine with a griptrue chuck as well, My late friend had an ML10 and built several locomotives in 31/2" gauge and countless Stuart Turner stationary engines as well, all built on the lathe with a vertical slide as the only machine tool apart from a little Champion drill press, which i have now got and treasure. Enjoy! Dave He didn't know about not using the reversing switch for starting the machine, but in well over twenty five years of regular use nothing untoward happened.
jaCK Hobson | 10/02/2023 17:43:13 |
383 forum posts 101 photos | Very nice condition! I'd swap my S7 for that. |
Howard Lewis | 10/02/2023 17:47:40 |
7227 forum posts 21 photos | That looks really nice. Hope that bit has a good range of accessories with it. A lot of what messers Sparey and Bradlkey wrote was ML7 based, so a lot will read across ontom the ML10. ENJOY! Howard |
Oldiron | 10/02/2023 17:49:48 |
1193 forum posts 59 photos | Nice looking lathe. Lets hope it performs as well as it looks. Nice find. As long as the lathe actually stops rotating before reversing there is no problem with a Dewhurst switch as it has a centre off position. The contacts are pretty meaty as well. regards |
Dell | 10/02/2023 17:55:13 |
![]() 230 forum posts 44 photos | Posted by roy entwistle on 10/02/2023 17:16:32:
Do not use the switch shown as an on - off switch. It only designed for reversing the lathe while the lathe is stopped. Roy So where is the on/off switch? |
old mart | 10/02/2023 18:06:50 |
4655 forum posts 304 photos | I agree with needing a proper switch, I would add a no volt on off with an emergency button. A lot of Myfords came from the factory with just the reversing switch, my boss when I was an instrument mechanic bought a brand new Super 7 long bed and that only had the reversing switch. It was used as is and we knew no better at the time. The reversing switches are expensive and parts are not that easy to come by, that is a good reason to add a proper switch and only set the reversing switch when switched off.
Edited By old mart on 10/02/2023 18:09:12 |
Rod Renshaw | 10/02/2023 18:10:02 |
438 forum posts 2 photos | Nice, clean looking lathe. You will get a lot of use and fun with that.. I would not worry unduly about the switch. While Roy is theoretically correct. and use in Industry under the beady eye of a Health and Safety person might require a separate on /off switch, in practice Rod's post is more realistic for the use most amateurs make of their machines. What may happen is that in many years time the switch may fail and have to be repaired or replaced, but it's rather unlikely to happen in your lifetime. The fact that there is no separate on/off switch on your purchase suggests strongly that the previous owner also thought along these lines.
Edited By Rod Renshaw on 10/02/2023 18:34:06 |
Dell | 10/02/2023 18:12:47 |
![]() 230 forum posts 44 photos | Posted by Howard Lewis on 10/02/2023 17:47:40:
That looks really nice. Hope that bit has a good range of accessories with it. A lot of what messers Sparey and Bradlkey wrote was ML7 based, so a lot will read across ontom the ML10. ENJOY! Howard Hi Howard Yes quite a few accessories but no collets or collet chuck. |
Howard Lewis | 10/02/2023 18:19:01 |
7227 forum posts 21 photos | Really there should be an On/Off switch of adequate capacity, (About 3 Kw to cope with starting currents, so ideally a NVR ) wired between the supply and the Dewhusrt swithch. Have to admit that when I had my at least secondhand ML7 used the Dewhurst to start (But only when the spindle was stationary, ) and stop and never had any trouble. Howard |
old mart | 10/02/2023 18:19:05 |
4655 forum posts 304 photos | Anyone noticed the set true chuck? |
Dell | 10/02/2023 18:31:14 |
Ady1 | 10/02/2023 23:49:51 |
![]() 6137 forum posts 893 photos | Well done you Welcome to the nuthouse, and have fun with your new pal |
peak4 | 11/02/2023 02:30:27 |
![]() 2207 forum posts 210 photos | Do enjoy your new toy.
Hopper | 11/02/2023 04:44:16 |
![]() 7881 forum posts 397 photos | Looks very nice indeed, like it has hardly been used. The leadscrew dog clutch is a very handy feature that is sadly missing on the ML7s. The trick to turning larger diameter jobs on these is to use a fixed steady on the larger job sticking out of the chuck. My ML7 has only the reversing switch, which has been on there for decades unknown without contact problems. I will get around to fitting an NVR at the other end of the bench at some point. I have had it sitting under the bench for a couple of years now, just needs wiring in. Nice to have two options for stopping and starting. |
Clive India | 11/02/2023 10:33:15 |
![]() 277 forum posts | Nice one Dell. |
Chris Pearson 1 | 11/02/2023 11:21:54 |
189 forum posts 3 photos | Posted by Howard Lewis on 10/02/2023 18:19:01:
Really there should be an On/Off switch of adequate capacity, (About 3 Kw to cope with starting currents, so ideally a NVR ) wired between the supply and the Dewhusrt swithch. Have to admit that when I had my at least secondhand ML7 used the Dewhurst to start (But only when the spindle was stationary, ) and stop and never had any trouble. With respect, 3 kW is not correct. I suspect that the motor is 1/3 h.p. so it will draw 1 amp under load and up to 6 A briefly on starting. A Dewhurst switch will certainly cope with that. I never had a problem with mine on an S7 so a slightly bigger motor. The advantages of a separate NVR switch are (a) if the power is cut, the motor will not start up again unexpectedly when the power is restored; and (b) there is the option of an emergency stop mushroom button. However, it is certainly not a necessity. It looks lovely - enjoy it! Edited By Chris Pearson 1 on 11/02/2023 11:22:54 |
