Bill Phinn | 15/12/2022 00:21:24 |
1076 forum posts 129 photos | Would anyone be able to tell me whether the lifting apparatus in the link [widely used by ambulance services], which basically consists of a battery-powered compressor connected by airlines to conjoined inflatable cushions, could feasibly be improvised more cheaply, and if so how we'd best go about it? We are sorely in need of such a device. https://www.johnpreston.co.uk/mangar-elk-emergency-lifting-cushion-and-airflo-24 Edited By Bill Phinn on 15/12/2022 00:24:12 |
peak4 | 15/12/2022 01:03:48 |
![]() 2207 forum posts 210 photos | Ebay might be a starting point https://www.ebay.co.uk/itm/155267284314 Bill |
Ady1 | 15/12/2022 01:33:47 |
![]() 6137 forum posts 893 photos | various pneumatic widgets might suffice |
Bill Phinn | 15/12/2022 01:49:28 |
1076 forum posts 129 photos | Posted by peak4 on 15/12/2022 01:03:48:
Ebay might be a starting point https://www.ebay.co.uk/itm/155267284314 Bill Yes, I've scoured the secondhand offerings on ebay. Where the price is affordable, my reservations are usually about how hard the equipment has been worked, and whether the battery is still reasonably capable of holding a charge. I know you said ebay is just a starting point, but that one does look heavily used and has no charger or controller. As an alternative to secondhand Mangars I was wondering whether a portable tyre-inflater style compressor and some inflatable pillows or camp beds could be improvised. |
Bill Phinn | 15/12/2022 01:50:26 |
1076 forum posts 129 photos | Posted by Ady1 on 15/12/2022 01:33:47:
various pneumatic widgets might suffice That does look interesting, Ady. |
not done it yet | 15/12/2022 07:34:59 |
7517 forum posts 20 photos | I note most of these things (apart from very heavy duty vehicle air bags) are termed as ‘emergency’. Personally, I prefer hydraulic rather than pneumatic, particularly for larger lifts (as in ‘higher) as any split would result in a very rapid deflation. So that is my advice - go hydraulic, like most fluid lifting devices around. |
Robert Atkinson 2 | 15/12/2022 07:39:40 |
![]() 1891 forum posts 37 photos | Hydralic is not suitable for this device. You would need at least 30 liters of fluid, probably more. Not very portable. |
Sam Longley 1 | 15/12/2022 08:17:33 |
965 forum posts 34 photos | I hope that I have understood what you are after correctly You only need about 3 PSI in these bags & I inflate airbags ( size 2.4 * 1.5 diam) for laying moorings weighing up to 2.5 tonnes with a simple high volume, low pressure pump costing £18-00. iin under 15 minutes. But mine is 240 V & you want 12 V May I suggest 2 options first is an inflatable dinghy pump as sold by marinescene & other yacht chandlers- There are many- Marine scene Or you could just use a simple hand pump as I use for my Avon dinghy. Stirrup pump they do foot operated ones. It is not rocket science to make the adaptors fit You would inflate your bags in a 30 strokes of the pump & for the cost it is worth experimenting. You will not have battery issues to worry about. For batteries one could just get small ones & keep them charged such as a scooter battery. Or go into an RC model shop & buy a couple of LIPO batteries & a charger & get them to explain how to charge & store them. They may even solder the correct connections on for you if you ask. |
Gary Wooding | 15/12/2022 09:04:49 |
1074 forum posts 290 photos | Get in touch with your local REMAP panel. We've used pneumatic car jacks for similar purposes, in conjunction with a battery operated dinghy pump as mentioned by Sam. Go to www.remap.org.uk to find your local panel and/or make a referral. |
Mike Poole | 15/12/2022 09:17:09 |
![]() 3676 forum posts 82 photos | Scroll down to the videos on Bills link and the application of the device and what is required becomes clear. Mike |
Samsaranda | 15/12/2022 09:27:27 |
![]() 1688 forum posts 16 photos | Air bags are eminently suitable for lifting quite heavy items, when I was in the Air Force we used them for lifting large heavy aircraft, they operate on very little Pounds per square inch. Dave W |
Sam Longley 1 | 15/12/2022 09:28:53 |
965 forum posts 34 photos | Posted by Mike Poole on 15/12/2022 09:17:09:
Scroll down to the videos on Bills link and the application of the device and what is required becomes clear. Mike Apologies. I thought that he had the cushions but could not pump them up. Careless of me This forum no longer allows me to edit my post which is a little iritating. Otherwise I would remove it. But if it is air bags that are wanted, then go & see a bouncy castle firm & get some glued up. Then use the pumps that I suggested. They could probably make the bag seat shaped as well, thus putting the patient into a sitting position
Edited By Sam Longley 1 on 15/12/2022 09:43:25 |
Ady1 | 15/12/2022 10:06:42 |
![]() 6137 forum posts 893 photos | Those cordless airpumps crank out a lot of air at low pressure for dinghys etc You can see them in action on youtube |
Clive Foster | 15/12/2022 10:18:31 |
3630 forum posts 128 photos | The issue with improvised systems will be stability. The proper thing is made as several sections to help control wobbling around as it goes up. Presumably there is something clever inside the bags to justify the outrageous price. The big car jack bags are seriously squidgy in all directions. They rely on the weight of the car and grip of the un-lifted wheels to stop them flexing their way out. For people lifting I'd be much happier with the airbag in some sort of parallelogram style frame with a seat on top so the airbag just lifts. The frame gives stability. Clive |
Hopper | 15/12/2022 11:11:32 |
![]() 7881 forum posts 397 photos | Those are pretty specialised for lifting people who have fallen and can't get up because they and their carer are ill, elderly, frail etc. Does not seem very safe to try to jury rig something out of a car jack bag. The person could roll off the side of that. If you are caring for someone at home and they have a fall, you are best to call an ambulance. They will come and help and have the training and gear to do it safely. I only found that out after my late wife had a fall and I just about did my back in lifting her up as a dead weight. Wish I had known it or thought of it on the night. |
Sam Longley 1 | 15/12/2022 11:19:08 |
965 forum posts 34 photos | Has the OP considered exactly how he would get the bag under the casualty? Is the intention just to raise their upper body into a sitting position untill help comes, or raise the entire frame. How does the bag help get the person on to their feet without them rolling off & sustaining further injury. Or just as bad - creating undue stress during the process. Is the intention to make a comfortable bed?- In which case a decent lilo would be just as good. Placed correctly & then inflated might ease the pressure points for a while. Ambulances can take a long time to arrive. Edited By Sam Longley 1 on 15/12/2022 11:22:27 |
Bill Phinn | 15/12/2022 15:05:55 |
Sam Longley 1 | 15/12/2022 15:18:01 |
965 forum posts 34 photos | Thinking differently would not a demountable frame 2.2 M tall a bit like a child's swing with a small electric hoist work? 4 stainless steel 25mm diam legs & a short cross bar with 4 sockets. Just put it together over them & the hoist could be on 1 leg with a dynema cord going up over a light pulley clipped to the top If they fall over a lot, have one permanently welded up with 4 small castors & just move it over them. Lift the casualty with a webbing strop under the arms. Edited By Sam Longley 1 on 15/12/2022 15:21:29 |
Ady1 | 15/12/2022 15:21:34 |
![]() 6137 forum posts 893 photos | He should be in a wheelchair now IMO, before something gets badly broken The big guys always struggle with old age, it's great when you're young but it's the little skinny runty guys who thrive in old age, (I used to do residential nursing home stuff) I'm managing my own folks too ATM, but there's 3 of us to spread the load about edit: back to the thread Look for any care homes closing down locally, the increase in care costs means there will be closures and that means spare equipment looking for a good home Another possibility, a modified car engine hoist? Edited By Ady1 on 15/12/2022 15:26:43 |
HOWARDT | 15/12/2022 16:18:31 |
1081 forum posts 39 photos | When my father was alive I had a similar problem, he used a wheelchair to get around his bungalow but would fall at times either from a chair or bed and end up lying on the floor overnight. As he only had bad legs and couldn't use them to lift himself, he needed me to lift him onto a seat. I thought of this problem and the main difficulty is getting something under them initially to use as a support to lift. Most places that have to do this use two people, one either side to lift under the arms, difficult for one person particularly if the person struggles. Probably something along the lines of a screw lift chair with bars which could be slipped under a person even without lifting them to do so would work. Air cushions would be difficult to slide under a person unless you had room to roll them to the side and back, again difficult with a non co-operative one. Maybe there is something out there in the medical apparatus field that would work but I think most places that would have a use for it just use two people (or more0. |
