I should have faxed this message
Bazyle | 01/11/2022 23:16:36 |
![]() 6956 forum posts 229 photos | Having just got a printer that apparently can send faxes - I won't be able to. |
not done it yet | 02/11/2022 06:42:52 |
7517 forum posts 20 photos | I think it is only dedicated fax lines that are being removed from the system. My faxes were always operated from my usual phone line, so nothing has changed on that score? |
Speedy Builder5 | 02/11/2022 06:51:47 |
2878 forum posts 248 photos | I think the first one we installed was the Class 1 machine, weighed about 40 lbs and was quite slow. Within a couple of years, it was replaced with a class 2 machine, much faster and lighter and compact. After that, the Class 3 machine was appearing on most secretarial desks. Before lap-tops, intelligent typewriters started to have FAX capability and became portable, having inbuilt multi class modems. Ah! the days of Oliveti thermal typewriter paper ! |
Michael Gilligan | 02/11/2022 07:17:21 |
![]() 23121 forum posts 1360 photos | The truth is out there: https://www.ofcom.org.uk/news-centre/2022/farewell-to-the-fax-machine MichaelG. |
pgk pgk | 02/11/2022 07:21:07 |
2661 forum posts 294 photos | One of my better faux pas was setting up turbocad in real world size and redrawing some building plan alterations for the architect's approval.. and sending it directly from turbocad as a fax - thus emptying the prodigious paper content of the receiving machine as multiple blank sheets and an occasional line.... pgk |
John Haine | 02/11/2022 07:31:29 |
5563 forum posts 322 photos | Posted by not done it yet on 02/11/2022 06:42:52:
I think it is only dedicated fax lines that are being removed from the system. My faxes were always operated from my usual phone line, so nothing has changed on that score? Not quite. Fax machines require the pstn to support a specific class of voiceband modem, which the VoIP to the edge that modern fibre access networks use don't support. |
Martin Connelly | 02/11/2022 08:30:55 |
![]() 2549 forum posts 235 photos | When the phone network at work was changed over to a digital system we had to let the IT department know which phone sockets had to be left as analogue for FAX transmission and reception. Within a couple of years we no longer sent or received any as email replaced it as a means of communication. Martin C |
Robert Atkinson 2 | 02/11/2022 10:57:43 |
![]() 1891 forum posts 37 photos | A little known fact was that in the past when companies had private automatic telephone exchanges they would not support FAX machines. So the FAX was generally on a dedicated line. This could be handy if you needed to make a international call or call to another number that was restricted by the exchange Robert G8RPI. |
Michael Gilligan | 02/11/2022 11:13:32 |
![]() 23121 forum posts 1360 photos | With Copper allegedly being withdrawn circa 2025 … I do hope they get VoIP compatibility better than it is now. My ‘Full Fibre’ broadband uses a FRITZ!Box 2530 which is an amazing router … but it cannot connect my pacemaker monitor to the hospital, because there is a VoIP mis-match. MichaelG. . Ref. __ https://en.avm.de/products/fritzbox/fritzbox-7530/technical-data/ Edited By Michael Gilligan on 02/11/2022 11:14:20 |
Peter G. Shaw | 02/11/2022 11:48:41 |
![]() 1531 forum posts 44 photos | I have to say that I think it's not before time. Indeed, I haven't used fax on a personal basis for, I think, about 15 years, but then as a non-working person, I don't really have much need of it. I think the last time I used fax was to send some information to my GP - today they use email. A few years ago I did have a spate of receiving faxes which were not for me and it took some tracking down to find out who they were intended for and then to get it stopped. The problem was that my Linux based computers did not do fax and I couldn't be bothered setting it up. Also, because of this, I was unable to read the faxes to determine their correct destination. Eventually, I found a telephone number of a firm that was sending them, telephoned them, and received a load of abuse on the lines of it's no-one here. I did then wish that I did indeed have a working fax as I would have sent copies back to them, probably multi-copies at that, the reason being that the originating telephone number was shown at the top of the fax so I had proof of where they were coming from. Later, I found another telephone number for a different firm that was sending them, and this time I managed to get back to the person who was sending them only to find that they were being sent to a local performance car specialist firm. On contacting this firm, I discovered that they were indeed using my home 'phone number as their fax no. Needless to say, they changed tack pretty quickly once they knew. It transpired that it was all down to misreading the third digit of their fax telephone number. As it was, we had a few weeks of receiving faxes with next to no come back. And I wasn't happy! Having said all that, I do think that fax has been of use, but ii's time has now come to an end. Cheers, Peter G. Shaw
Bryan Cedar 1 | 02/11/2022 12:50:32 |
127 forum posts 4 photos | I do use Fax as this is the only way I can send money over the daily limit through my bank account. I do not have a local bank and use Fax to instruct my bank to send a CHAPS same day payment. |
peak4 | 02/11/2022 13:36:29 |
![]() 2207 forum posts 210 photos | A good friend of mine, and lodger at the time, used to work in software support for a firm which provided specialist software for various garment production companies. |
bricky | 02/11/2022 13:54:12 |
627 forum posts 72 photos | I had experience of receiving faxes for other people.Two were for the local police station,one was about a raid on a house in a local village giving names and details of the crimes,the other was far more serious a van driver on the M5 repeatably over took a car but as he did the last passing he was met with a gun through the car window.The van withdrew sharply according to the van driver.It was reported to the police and they sent this information to the Grantham police to go to the car owners address in Grantham and arrest him.I received this on a Friday but the fax ran out of carbon and I didn't renew the carbon unti Tuesday.On reporting the fax to the police they said this can't happen but I insisted and told them what was in the fax .Fastest response from the police station ever two burly detective came to the door in a very threatening manner and stupidly asked if I had read the fax they tried to say I had hung onto it deliberatley,jobsworths Frank |
Mike Poole | 02/11/2022 14:06:19 |
![]() 3676 forum posts 82 photos | I think the fax machine was a most useful device in its day but that is long past. There are plenty of solutions to the passing of the fax machine. Our office machine was retired about 1999. Spam used to be when the fax machine burst into life and some unwanted advert used up the heat sensitive paper of our long in the tooth Toshiba fax machine. |
Peter Greene | 02/11/2022 14:19:48 |
865 forum posts 12 photos | Posted by Martin Connelly on 02/11/2022 08:30:55:
...... as email replaced it as a means of communication.
What next? Edited By Peter Greene 🇨🇦 on 02/11/2022 14:20:14 |
bricky | 02/11/2022 15:17:52 |
Jeff Dayman | 02/11/2022 18:01:10 |
2356 forum posts 47 photos | "What next?"
Telepathy / voodoo (now taking cover)
FYI I and the folks I worked for stopped using fax about 2008 - but many doctors and dentists here still want stuff sent that way. |
SillyOldDuffer | 02/11/2022 18:10:19 |
10668 forum posts 2415 photos | Posted by Jeff Dayman on 02/11/2022 18:01:10:
"What next?"
... Artificial Intelligence. The day Smart Phones become smarter than their owners! Not long now... Dave |
duncan webster | 02/11/2022 18:17:59 |
5307 forum posts 83 photos | Last time I used a fax was to send some info to the NHS. They couldn't cope with email. Took me ages to find someone with a fax machine, and it cost me. At last they move into the 21st century. the origin of the fax machine had 2 pendulums, the sender had a photosensor, the receiver had some kind of writing device (spark generator?). Set both pendulums swinging in phase and connect with a long bit of wire. as the penduli swung the paper both ends was inched through. OK in principle, but no idea how well it worked, must have been fun getting them exactly in synch |
Peter Cook 6 | 02/11/2022 18:24:50 |
462 forum posts 113 photos | Posted by Peter Greene 🇨🇦 on 02/11/2022 14:19:48
What next? I find an increasing number of (particularly small) business only communicate on Facebook. As I refuse to have an account, they don't get my business - but I don't suppose they care. |
