Oil wick
Dell30/10/2022 08:57:01
230 forum posts
44 photos
I need some replacement oil wicks for my Pultra does anyone know of a place/ supplier that sells such a thing , I have been told that lighter wicks would work but I don’t want to strip the headstock until I am sure I have suitable replacement, has anyone got a picture of said wicks.
thanks in advance Dell
MichaelR30/10/2022 09:22:50
528 forum posts
79 photos
Have a look for oil lamp wicks they come in all shapes and sizes, can be unravelled to suit your needs, plenty on the internet sites.
MichaelR
noel shelley30/10/2022 09:34:45
2308 forum posts
33 photos
Try a craft shop for candle wick, comes in different sizes and could be twisted to make a large one ! Noel.
Joseph Noci 130/10/2022 09:46:16
1323 forum posts
1431 photos
I used pipe cleaners in the oil-cups on all the lube points on my Alba shaper - works very well. The wire in the cleaner permits easy shaping of the wick, if needed.
Joe
Dell30/10/2022 10:30:45
230 forum posts
44 photos
Thanks for replying everyone Joseph Noci 1 I understand the wicks go round the bearings then down a hole to the oil , in that case would not the wire in a pipe cleaner damage the spindle?
Dell
Joseph Noci 130/10/2022 10:41:07
1323 forum posts
1431 photos
Dell,
Not familiar with your specific needs/setup - wick lubricators I am familiar with sit atop the bearing or slide, with a hole down to the lubricated surface. A wick sits in the oil bath in the lubricator, and in a U bend goes up then down into the bearing/slide lube hole. The wick does not touch the moving surface -
What Pultra do you have?
A typical Wick Lubricator for lathe bearings
Joe
Michael Gilligan30/10/2022 10:55:02
23121 forum posts
1360 photos
These may help:
Edited By Michael Gilligan on 30/10/2022 10:56:10
Michael Gilligan30/10/2022 11:21:41
23121 forum posts
1360 photos
For those who admired the Muncaster watercolour recently posted by Jason
Here is a Pultra headstock, featuring the wick, for you to colour !
bricky30/10/2022 11:34:41
627 forum posts
72 photos
Myford use wicks on the headstock ,they would be able to supply there wick which may be altered to suit your needs.
Frank
JasonB30/10/2022 14:54:23
Heritage Steam Supplied do the Worstead wool for oilers and details of use
SillyOldDuffer30/10/2022 14:59:48
10668 forum posts
2415 photos
Posted by Michael Gilligan on 30/10/2022 11:21:41:
Is there a prize? I offer:
And:
And
david bennett 830/10/2022 15:48:49
245 forum posts
19 photos
Posted by Dell on 30/10/2022 10:30:45:
Dell
No,the wicks do not go round the bearings. The wicks come up from the oil to the bearings. (It might help to know which model you have)
dave8
Edited By david bennett 8 on 30/10/2022 15:52:20
Michael Gilligan30/10/2022 16:04:32
23121 forum posts
1360 photos
With only one entrant for the unadvertised colouring competition
S.O.D. might have won … But unfortunately he failed to clearly identify the wick, so is disqualified.
Edited By Michael Gilligan on 30/10/2022 16:10:06
Michael Gilligan30/10/2022 16:07:33
23121 forum posts
1360 photos
Posted by david bennett 8 on 30/10/2022 15:48:49:
Hint: **LINK**
https://www.model-engineer.co.uk/albums/member_album.asp?a=56494
Dell30/10/2022 16:08:29
230 forum posts
44 photos
Thanks once again for replies my Pultra is the 17/70 according to the manual that I have and someone has posted above it goes round the bearings then down a hole to oil and to be careful not to sever them.
Dell
Michael Gilligan30/10/2022 16:26:31
23121 forum posts
1360 photos
Recommended Reading: **LINK**
http://cm1cm2.ceyreste.free.fr/pultra_1770.html
… or at least have a look at the pictures.
Michael Gilligan30/10/2022 16:35:25
23121 forum posts
1360 photos
Text from the relevant section … Translation by Google
The lathe being reassembled: we can see the belt on the right, and in the middle the oil reserve of the spindle bearings:
Detail of the two braided cotton strands that raise the oil to the bearings:
Small glass lens that allows you to monitor the oil level in the crankcase:
Replacement of cotton braids with felt strands, more suitable for the rise of oil in the bearings:
david bennett 830/10/2022 16:41:50
245 forum posts
19 photos
Posted by Dell on 30/10/2022 16:08:29:
Dell
Take off the inspection plates on the headstock. That should show you the oil reservoir. You should see the wicks leading up to the bearings.
dave8
Edited By david bennett 8 on 30/10/2022 16:42:23
Nigel McBurney 130/10/2022 17:02:00
1101 forum posts
I use thick knitting PURE wool it MUST not have any synthetic fibre in it, on all of my stationary engines requiring wicks,it was common practice years ago to use brass wire to support the wick as brass will not cause any damage should it come in contact with the rotating spindle. Some years ago wicks used on locomotives were not feeding oil and it was found that the wool had a proportion of synthetic wool in it, if the bearing got too warm the synthetic content melted and ran in amongs the natural wool ,blocked up the strands and stopped feeding oil,it gets expensive with white metal bearings, There is some info on the web about how to make wicks., just a case of searching.One thing I have found that natural sheeps wool spun at home did not feed as well as pure knitting wool,never found out why.
Dave Halford30/10/2022 17:30:20
2536 forum posts
24 photos
Dell
Hi Dell,
There are several different types of wick oiler although they a run by capillary action.
The one linked to by Joseph uses a plain metal wire loop to lift oil up out of a cup and drip it down onto the top of a spindle surface through an oil hole in the bearing. The flow is metered by the wire thickness. It sounds far-fetched but it does work.
Another used on full sized engines uses worsted wool to lift oil in the same manner. Flow is metered by the number of strands of wool in the oil.
Yours seems to use cotton to lift oil out of a sump through the pear shaped hole (Michael's link after the first spindle photo) in the bottom of the bearing to touch the splndle. The oil should then be pulled off the end of the wick by rotation and the shallow groove will distribute it across the whole bearing.
If you try to turn the wick 90 deg and spread it across the groove I would expect a jam to happen at some point.
I had a lathe with a felt wiper that ran for the whole width of the bearing, but that was set in a slot cut right through the bearing surface and not a shallow depression.
