Here is a list of all the postings david bennett 8 has made in our forums. Click on a thread name to jump to the thread.
Thread: Isochronous knife edge suspension? |
15/09/2023 16:28:49 |
John, could that error be "tuned out" with a rating nut? dave8 |
12/09/2023 16:12:40 |
Posted by John Haine on 12/09/2023 08:32:22:
I'm not sure I see that Dave. Why wouldn't the arrangement I sketched work? John, I think you mean the sketch in the "general" forum? (If this works, it leads to the intrigueing idea that local magnetism can replace gravity in a clock) Just from playing about with magnets and rollers they accelerate to seek the closest contact at the strongest pole point. This ruins any hope of a high Q and swamps the effect of gravity. I was trying to minimise this by putting the magnet in the centre of the rollers.It just felt wrong. |
11/09/2023 23:00:59 |
If this project wasn't already dead, here's another nail in the coffin. In preparing a cirular section to match the required circle ( 125mm radius now), placement of the magnet came up. The only place for the magnetic forces to even out would be in the middle of the bob! Not very practical. dave8 |
Thread: Interesting Curves |
10/09/2023 22:51:03 |
I don't know how to play! So i've got a real spirograph coming next week. |
10/09/2023 19:14:41 |
Nor willI be doing it, even if Iknew how. I agree about the "purity" dave8 |
10/09/2023 18:35:03 |
Michael, still just musing. Is it possible to put time-values on those dots and run a comparison within a 10 degee pendulum swing? --- just for fun! dave8 Edited By david bennett 8 on 10/09/2023 18:37:07 |
10/09/2023 18:04:50 |
Now, I wonder how that would look showing only the paths within a 10 degree swing - - - -? dave8 |
09/09/2023 23:14:38 |
Thanks everybody for your help in this. I've finally got my head around the change of curve from extending the rod, and even the apparent paradox of a point in a circle being a cycloid one minute and not the next. Sorry for testing your patience so hard. dave8 |
09/09/2023 14:26:23 |
I think I now see where the confusion comes from. Much of this discussion has become about Huygens cycloidal cheeks and how they are constructed. The 1/2 pendulum length roller is needed for that. The method I proposed is based on the rolling wheel principal to produce a cycloidal path. That is a completely different approach to Huygens. The question now is - does the diameter of the roller matter in this context? dave8 |
09/09/2023 12:23:11 |
Michael |
09/09/2023 11:52:12 |
o.k. dave8 |
09/09/2023 11:06:34 |
Michael, guilty. Me, not you. Its because of perceived rissole-like responses from one member. I would be happy to draw a line here. dave8 |
09/09/2023 04:45:04 |
Posted by Tony Jeffree on 07/09/2023 14:04:58:
Of course, a moment's thought about the wheels on a car would have brought you to the same conclusion. A point on the tread follows a near-enough cycloidal path (give or take the flexibility of the tyre), but you'd better hope that the wheel axle doesn't follow a cycloid, or it is going to be a rather bumpy ride! Edited By Tony Jeffree on 07/09/2023 14:05:35 If a point on your tread follows a near-enough cycloidal path, you probably need new bearings. dave8 Edited By david bennett 8 on 09/09/2023 04:45:55 Edited By david bennett 8 on 09/09/2023 04:58:52 |
09/09/2023 01:56:08 |
On second thoughts, if you find that is a convenient size, please go ahead. Be sure to do a write-up so we can follow your procedures, especially the measuring. It's sure to attract a lot of attention. You'd like that, wouldn't you? dave8 |
09/09/2023 01:19:55 |
Then it wouldn't be a convenient size - would it? dave8 |
08/09/2023 20:39:40 |
Posted by Tony Jeffree on 08/09/2023 18:38:03:
Posted by duncan webster on 08/09/2023 13:51:38:
Posted by Tony Jeffree on 08/09/2023 12:34:16:
..........or what radius of generating circle for the cycloid is required in order for it to work.
Same as the pendulum cycloid. Plausible answer, but where's the proof? As I tried to show in my post yesterday,at 16:28 the generating circle doesn't matter. A cycloid is a cycloid. Pick any convenient size. dave8 |
08/09/2023 19:40:10 |
If you are inside a moving car, observing the wheel will show a circular path (you may need a mirror) If you are outside the car, and stationary, a point on the wheel of a moving car will be seen to have followed a cycloidal path. dave8 Edited By david bennett 8 on 08/09/2023 19:41:01 |
08/09/2023 18:51:16 |
Of course, a moment's thought about the wheels on a car would have brought you to the same conclusion. A point on the tread follows a near-enough cycloidal path (give or take the flexibility of the tyre), but you'd better hope that the wheel axle doesn't follow a cycloid, or it is going to be a rather bumpy ride! Edited By Tony Jeffree on 07/09/2023 14:05:35 No. A point on the tread follows a circular path. dave8 |
08/09/2023 12:36:22 |
Posted by david bennett 8 on 08/09/2023 01:11:46:
I don't think Huygens suggested that the cylinder had to be half pendulum size in diameter. It was just convenient. He was just using that to present his proof for his particular pendulum. Others since him have mis-interpreted his intentions.He wasn't trying to establish a rule for all cycloids, as we are. dave8 Further to this - We had an example on this site where totally unnecessary dimensions can be specified , which could ne misinterpretd. when I enquired on the "general" forum for the best way to produce a 39" curve, I was required to give 3-dimensions for the part. They wheren't needed, but arbitrary sizes where given just so the problem could be visualised. Perhaps that is why Huygens gave his 1/2 pendulum size for producing a cycloid. dave8 |
08/09/2023 01:11:46 |
I don't think Huygens suggested that the cylinder had to be half pendulum size in diameter. It was just convenient. He was just using that to present his proof for his particular pendulum. Others since him have mis-interpreted his intentions.He wasn't trying to establish a rule for all cycloids, as we are. dave8 |
