Reverse direction of shaft driven by toothed belt.
Peter Bell28/08/2022 10:00:50
399 forum posts
167 photos
Hello, nice simple question
I want to reverse the direction of rotation of a shaft driven by a toothed belt.
I assume I need to resort to gears to do this?
Thanks
JasonB28/08/2022 10:12:29
Unless you can move the driving motor to the opposite side of the belt.
Brian Wood28/08/2022 10:15:12
2742 forum posts
39 photos
Hello Peter,
I think you are correct.
In the old days of flat belts you could put a twist in the belt and where they crossed one just slid past the other. I don't know if that is possible with toothed belting without a snarl up of the teeth at the crossing. Might be interesting to test it out!
Edited By Brian Wood on 28/08/2022 10:16:13
Peter Bell28/08/2022 10:37:43
399 forum posts
167 photos
Thanks. It’s shaft driven by a shaft then the motor and never seen a twisted toothed belt (intentionally anyway!) before so assuming it’s not possible but just checking in case I’d missed something.
Peter
Kiwi Bloke28/08/2022 10:38:10
912 forum posts
Well, it's a bit nasty, but if the belt's run is long enough, and there's enough room for an idler to replace the motor's pulley (in a similar position), arrange for the belt to be driven from the middle of a long run, with the motor's axis at 90 degrees to the plane of the belt. To do this, the belt has to be twisted 90 degrees. Twist it one way, and drive it from the appropriate side, and it'll go one way; twist it the other way, so you can drive it from t'other side, and it will go in the opposite direction. You'd need to arrange suitable idlers to get enough belt wrap. Of course, this means arranging for the motor's axis to be rotated 90 degrees, so it's pointing at the side of the (untwisted) belt, ie at 90 degrees to the driven pulley's axis. Hope this is clear...
Otherwise, arrange idlers to provide a lot of belt wrap, and drive the belt from its 'outside', as if a flat belt.
Resorting to gears is probably not such a bad idea...
Peter Cook 628/08/2022 10:41:29
462 forum posts
113 photos
Reverse the motor?
Robin28/08/2022 10:48:55
678 forum posts
Can you still get double-sided tooth belts? That'd do it smiley
Tim Stevens28/08/2022 10:49:08
1779 forum posts
Sorry, my mistake ...
Tim
Edited By Tim Stevens on 28/08/2022 10:56:25
John P28/08/2022 10:56:52
451 forum posts
268 photos
Have a look on here for double sided toothed belts
https://www.bearingboys.co.uk/?catid=2564&display=&orderby=&att1=5.08mm+%3D+1%2F5inch&att2=&att3=&att4=&att5=
Anthony Knights28/08/2022 11:10:48
681 forum posts
260 photos
Seems to be getting over complicated here. Peter Cook 6 has the best suggestion- reverse the motor (KISS).
Hopper28/08/2022 11:28:04
7881 forum posts
397 photos
Bit more info on what exactly you want to reverse might bring out some more useful suggestions. Makes a big difference whether it is the leadscrew on a hobby lathe or the main drive on a 100HP snowmobile.
Paul Lousick28/08/2022 11:41:08
2276 forum posts
801 photos
How would a double sided tooth belt reverse the direction of the driven shaft ?
When a flat belt is twisted to reverse the direction, the same side of the belt is in contact with both pulleys.
not done it yet28/08/2022 11:48:30
7517 forum posts
20 photos
It might depend on how the belt is tensioned. If it has a separate tensioner it will be on the wrong side of the motor. If it is the motor that is moved, to apply the correct tension, no real bother - I think.
Peter Bell28/08/2022 12:17:07
399 forum posts
167 photos
Thanks for all the suggestions.
The motor drives the first shaft, and that shaft then drives the other shaft which is which is the one that that I want to reverse so I can’t just reverse the motor.
It’s only a 10mm belt so low power but it needs to be reasonably tight to avoid timing issues.
As it’s stepper motor driven had considered using another stepper and synchronising them on switch on but sounds complicated!
I see some reasonably priced Delrin change wheel gears on eBay, which looks like the solution.
Peter.
Michael Gilligan28/08/2022 12:26:58
23121 forum posts
1360 photos
Posted by Paul Lousick on 28/08/2022 11:41:08:
Briefly …
  • Motor drives an idler shaft [using the teeth on the inside of the belt]
  • Output is taken from the teeth on the outside of the belt.
