Lee Reynolds 1 | 31/07/2022 13:32:21 |
11 forum posts 6 photos | As a far too avid watcher of certain YouTube channels the use of 4140 whenever a stronger, tougher material was required seems very common. Even Kurtis of Banana fame is guilty. I know there are exact UK and EU equivalents but no E number obviously. EN19 has been suggested as an alternative but seems only available in a few sizes. Another thing that confuses me (not difficult now) is "stressproof" In spite of a lifetime of dealing with Boeing English (a checklist is a read and do thing, NOT a list to make sure things have been done etc. etc.) this one has me stumped. Any thoughts you esteemed Gentlemen have will be of interest. Lee |
JasonB | 31/07/2022 13:55:34 |
![]() 25215 forum posts 3105 photos 1 articles | It's not so much the toughness or strength that it gets used for it is the fact it is unlikely to distort when cuts are not balanced hence it gets used for things like crankshafts. The "stressproof" is due to it being heat treated (normalised) after rolling to remove any inbuilt stresses which are what cause other bright metals move when cut Edited By JasonB on 31/07/2022 13:56:39 |
Ady1 | 31/07/2022 14:02:54 |
![]() 6137 forum posts 893 photos | Sounds like seasoned castings which would lie in a backyard for 9 months to de-stress But 4140 is instantly available and fits in to our modern just-in-time mass production world |
Dalboy | 31/07/2022 14:03:07 |
![]() 1009 forum posts 305 photos | From what I gather 708M40 is the equivalent to 4140 and looking up 708M40 as you have said is equivalent to EN19 |
JasonB | 31/07/2022 14:23:39 |
![]() 25215 forum posts 3105 photos 1 articles | Also worth mentioning that "stressproof" is a trade name so has to be made buy that particular mill and usually applies to 1144 |
mike T | 31/07/2022 17:30:58 |
221 forum posts 1 photos | Be careful, It is possible to find an alternative steel with similar mechanical properties and composition, several have already been suggested. However, when you order 4140 "stressproof", you are specifying the material's post heat treatment condition. As Jason pointed out; The "stressproof" part is due to the steel being carefully heat treated (normalised) after rolling to remove any inbuilt stresses which are what cause other bright metals move when cut. The"stressproof" treatment makes the material less likely to distort when cuts are not balanced; hence it gets used for things like crankshafts. It's not so much the type of steel, it's all about the stress relief after rolling Mike |
Cabinet Enforcer | 31/07/2022 18:50:14 |
121 forum posts 4 photos | It seems that in the US, where most u-toobers hail from, 4140 is just the standard goto grade when something stronger is wanted, as you have noted EN19 or in a more modern nomenclature 708M40 is equivalent. Here in the UK I think the grade of choice when you need something a bit spicy is typically EN24, which is another cro-moly steel. |
Paul Lousick | 31/07/2022 23:40:14 |
2276 forum posts 801 photos | 4140 is the general, go-to material for shafts and axles in Australia when a higher strength material is required. It is normally supplied as bright or ground bar and machines OK but costs about 50% more than 1020/1030 grade (mild steel) bar. 1030 bright bar has a tensile strength of ~500MPa, 4140 ~900Mpa.
John Reese | 01/08/2022 02:43:05 |
![]() 1071 forum posts | Stressproof or 1144 is a re-sulfurized plain carbon steel with a nominal .44 % carbon. The sulfur makes it great for machining but not so great dor welding. |
Hopper | 01/08/2022 04:16:11 |
![]() 7881 forum posts 397 photos | And you can "stressproof" steel yourself by heating to a dull red and letting it cool slowly. I bury mine in a bucket of powdered lime to let it cool slowly and normalise. Seems to work well, even with welded fabrications such as my Versatile Dividing Head body arc welded up from steel pieces. Was very easy to machine and several years later, no sign of distortion. My local steel merchant sells two grades of steel only, 1020 and 4140. I rarely find any use for the latter in model type work, other than I might use it for an upcoming new spindle for my Drummond lathe. |
Lee Reynolds 1 | 01/08/2022 10:45:39 |
11 forum posts 6 photos | Jason, thank you for your explanation of stressproof - it makes perfect sense and explained why the grade of steel is never mentioned as it is clearly implied. The 4140 discussion suggests to me that Australia uses the AISI system of steel grading (which is why I couldn't find an AUS one). The use of the term 4140 is therefore completely normal. Thanks to all Lee |
SillyOldDuffer | 01/08/2022 12:21:17 |
10668 forum posts 2415 photos | Posted by Lee Reynolds 1 on 01/08/2022 10:45:39: ...The 4140 discussion suggests to me that Australia uses the AISI system of steel grading (which is why I couldn't find an AUS one). The use of the term 4140 is therefore completely normal. ...Not sure anything about naming steels is normal! Most steel making nations had, and maybe still have, their own naming systems, and repeated attempts to rationalise them have mostly failed. AISI is well-known in the USA, less so abroad, but we all have tables of equivalents: if in Australia you want AISI 4140, BS970-659M15, or SAE J403 there's probably a local equivalent. In the UK we still buy steel using the "Emergency Number" system introduced during WW2, even though the system was replaced in 1972! My local supplier looks blank if I ask for 220M07 but smiles if I ask EN1A. As no-one makes EN1A, he's selling me 220M07 or similar, and someone in the supply chain relabelled it to suit conservative Brits! The metal could have come from anywhere. More likely Chinese or EU made than American, but it might be Indian, Russian, German, South Korean, Turkish, Brazilian or whatever... The naming problem got worse with the internet because folk around the world specify what they know, probably not realising their understanding doesn't travel well. Faced with an unfamiliar specification number, you have to find an equivalent that your local stockist keeps. My local metal retailers aren't switched on to equivalents so I do my own research. Fortunately the internet is good at identifying alternatives that a local shop can supply. Frankly, it's a mess! Dave
