Lynne | 13/07/2022 16:44:18 |
117 forum posts 32 photos | Hi All, Sometime ago now, I fitted a 4 digit rev.counter, so I could have some idea of the spindle speed when using the mill. It worked fine untill an unfortunate incident resulted in the Hall sensor bit being de-capitated. I have no wiring dia. of the kit I bought, but looking at the ones currently on ebay,it seemed I would need a NPN hall sensor,voltage range 6-40. I found one UK sourced. It's fitted and working, but I can't convince myself that the visual speed of the spindle is reflected in the rpm shown on the display. Was there some other factor that I should have been aware of? I've googled the couple of numbers that appear on the damaged sensor, but nothing comes up. So, electronics experts help me please. Regards Lynne
bernard towers | 13/07/2022 17:03:34 |
1221 forum posts 161 photos | For the price of a new kit is it worth the hassle? |
SillyOldDuffer | 13/07/2022 17:21:19 |
10668 forum posts 2415 photos | On my lathe the Hall Sensor is mounted perilously close to the magnets, of which there are four. They sit in shallow milled cavities about 3mm diameter. Suggestions:
Dave |
not done it yet | 13/07/2022 17:26:11 |
7517 forum posts 20 photos | Don't you know the full speed of the lathe? That should be easy enough to check. Possible alternatives: Borrow a rev counter from a friend? See if it the chuck strobes at expected speeds under fluorescent lighting? Slow the lead screw to its minimum and measure the rpm from timings and the reduction ratio? |
bernard towers | 13/07/2022 20:47:10 |
1221 forum posts 161 photos | why has your rev counter got 4 magnets? |
JasonB | 13/07/2022 20:52:03 |
![]() 25215 forum posts 3105 photos 1 articles | 4 Digit not Magnet so it can display upto 9999 |
Michael Gilligan | 13/07/2022 21:03:31 |
![]() 23121 forum posts 1360 photos | Posted by SillyOldDuffer on 13/07/2022 17:21:19:
On my lathe the Hall Sensor is mounted perilously close to the magnets, of which there are four. … . What am I missing, Jason ? MichaelG. |
Andrew Johnston | 13/07/2022 21:07:44 |
![]() 7061 forum posts 719 photos | It's badly worded but I think the comment refers to the four magnets referenced by SoD. The answer is it gives four pulses per rev.That can mean a number of things: * Faster response to a change of speed * Same update rate but better averaging ^ Better S/N ratio equals more robust in the event of noise Andrew Postscript: Beaten to it Edited By Andrew Johnston on 13/07/2022 21:08:05 |
JasonB | 13/07/2022 21:14:46 |
![]() 25215 forum posts 3105 photos 1 articles | Bit fuzzy with Covid at the moment but thought Bernard was questioning the OP |
Peter Cook 6 | 13/07/2022 21:30:36 |
462 forum posts 113 photos | Push the hall sensor closer to the centre. If the magnets are not quite on a perfect pitch circle it may be seeing 3 but missing the fourth. Edited By Peter Cook 6 on 13/07/2022 21:31:12 |
Peter Greene | 13/07/2022 22:00:47 |
865 forum posts 12 photos | Posted by not done it yet on 13/07/2022 17:26:11:
Don't you know the full speed of the lathe? ... or even the mill |
Huub | 13/07/2022 22:45:05 |
220 forum posts 20 photos | You can set the RPM at the lowest and count the revolutions manual. If you have an Arduino UNO, Mega, etc, use a proxy and a magnet to measure the RPM. There are a lot of examples on how to do this. Beware, the magnet polarity (N-S or S-N) must be OK and depends on the proxy used. If it doesn't work, flip the magnet. The led in the proxy signals if the magnet is detected. I have bought a cheap IR rpm meter from ebay. It doesn't work reliable on small diameters. I have made a DIY version using a TCRT5000, and an Arduino that works a lot better. My mill and lathe both have a RPM meter that uses 4 magnets
not done it yet | 14/07/2022 08:27:08 |
7517 forum posts 20 photos | Posted by Peter Greene 🇨🇦 on 13/07/2022 22:00:47:
Don't you know the full speed of the lathe? ... or even the mill Oops! I actually like my rpm indicator/counter on my lathe - one single magnet used. Not important but I fitted a dummy on the opposite side of the shaft to keep it balanced. My portable rpm counter is an optical machine - I can easily calibrate it from any mains socket with a neon indicator. I reckon the mains is close enough to 50Hz for anything I might need… My mill will run slow enough for me to count its revolutions on its slowest speed setting, when running at 50Hz.🙂 Edited By not done it yet on 14/07/2022 08:32:55 |
Joseph Noci 1 | 14/07/2022 08:49:55 |
1323 forum posts 1431 photos | RC flyers have some neat optical RPM sensors, handheld, that work quite well. Aimed at the plane's prop and it senses the break in rear lighting and seems to work well. They are also available in reflective type used often to find RPM of brushless outrunners by placing a 5mm or so section of black or silver tape on the motor housing and aiming at it. They are iffi at low RPM I find - below 20 rpm or so - I suspect mainly due to the jitter in RPM in sensorless brushless motors at such low RPM's - Ans IC RC engines may not work that well at 20rpm... Check the local hobby RC shops.. |
Howi | 14/07/2022 09:51:42 |
![]() 442 forum posts 19 photos | Posted by Lynne on 13/07/2022 16:44:18:
just replacing the Hall sensor would not alter the rev display unless you disturbed the magnets(if you have more than one). if you have more than one magnet (4), then rotate the spindle by hand and you should get 4 flashes of the led situated in the Hall sensor mounting (per revolution.) there is no need to go to all the elaborate procedures posted as a new rev counter (with Hall sensor) can be had for next to nothing from China. Edited By Howi on 14/07/2022 09:52:47 |
Mike Hurley | 14/07/2022 10:12:00 |
530 forum posts 89 photos | Agree with Howi - the unit widely advertised on line works great, Easy to set up and seems reliable (well mine is). Quite a range of prices for exactly the same unit so just hunt around a bit! Really not worth the bother fiddling with your existing setup in MHO regards, Mike |
noel shelley | 14/07/2022 10:16:03 |
2308 forum posts 33 photos | Hall sensors do not have an indicating LED on their own, if it has an LED it is part of a unit. There was an article and update in MEW about 2 years ago on this matter that may help you. A complete unit from the east is about £12. IF all you have done is change the hall effect device and the display reads, what makes you think it is reading incorrectly ? Noel. |
Lynne | 14/07/2022 13:18:24 |
117 forum posts 32 photos | S.O.D. N.D.I.Y.and others. Read my post. I refer to 'spindle speeds when using my mill' so why introduce things relating to lathes? My only question was, is there factor I should have considered when ordering the sensor, eg, frequency for example?. It was l ess hassle to fit just the sensor, than to have to get into the box I had made to house the controls for the VFD. I will look into investing in an optical RPM counter so as I can cross check the revs. When the mill was single phase, yes I knew the spindle speeds from the chart giving the pulley settings reqd. NOT now though. Noel, what makes me think it is not reading correctly, purely subjective really, 'That spindle does'nt look as though its doing 350revs. the reality is that it is doing just that. Anyway thanks to all Regards,Lynne |
SillyOldDuffer | 14/07/2022 14:41:44 |
10668 forum posts 2415 photos | Posted by Lynne on 14/07/2022 13:18:24:
S.O.D. N.D.I.Y.and others. Read my post. I refer to 'spindle speeds when using my mill' so why introduce things relating to lathes? ... I did read the post! Perhaps unfortunately I described the magnetic tachometer on my lathe rather than the optical tachometer unhelpfully fitted to my mill. But the machine is irrelevant: magnetic tachometers work the same way whatever they're fitted to: lathe or mill, similar answer. I hoped I'd answered the question by describing the three things likely to cause a magnetic tachometer to misread RPM. Frequency or other Hall Effect weirdness is unlikely. My co-defendant is innocent too! NDIY's neon light is the classic way of calibrating the RPM of any shaft; works OK on both mills and lathes. Other methods available, but probably easiest to buy a cheap RPM meter and compare results. Dave
not done it yet | 14/07/2022 17:22:07 |
7517 forum posts 20 photos | And I tried to just give you a method so that you could convince yourself. Sorry about the lathe - but that goes round , just like my mill, so the principles are exactly the same. My second post might have provided some more thought provoking info, but nevermind I failed.🙂 |
