Replacing chuck
Michael Brett 1 | 15/06/2022 21:33:23 |
59 forum posts 6 photos | I have a Black and Decker KR100RE 1000W hammer drill. Drill works fine but chuck is knackered. First problem is I cannot remove the chuck. I have taken out the screw which holds it on but chuck still not moving. Second problem is finding a stockist for spare parts. Do I have to think of buying a new one, I hope not as this has been a good drill up to now. Any ideas folkes. Mike |
bernard towers | 15/06/2022 21:47:37 |
1221 forum posts 161 photos | I would have thought if your locking screw was LH the chuck is 3/8 or 1/2 RH UNF. put a piece of bar in one of the chuck key holes arrest on the bench and give the bar a good whack it should loosen your chuck. |
JohnF | 15/06/2022 21:48:16 |
![]() 1243 forum posts 202 photos | Not familiar with your drill and it depends how old it is ? However all the ones I have has occasion to work on the chuck is fitted on a right hand 3/8" UNF thread several had a screw inside the chuck body to lock it in place -- hope this helps John |
Pete. | 15/06/2022 21:52:34 |
![]() 910 forum posts 303 photos | If you have a cordless impact driver, put a 50mm driver bit in the impact driver, then tighten the drill chuck on the same hex bit, always takes them straight off for me. |
Howard Lewis | 15/06/2022 21:55:44 |
7227 forum posts 21 photos | In my limited experience, it is likely to be a 1/2 x 20 UNF main thread, locked for reverse running by the central L H screw. Once that is out, the usual brutal method is to insert the chuck key and git a hearty wallop in the direction to unscrew the chuck. A replacement chuck should be available. I got one, a Jacobs, (From a local hardware stockist ) for my big Bosch pistol drill, from a local stockist.. So any Black and Decker or Bosch stockist ought to be able to supply a replacement. Howard |
Alexander Smith 1 | 15/06/2022 22:11:20 |
52 forum posts 27 photos | Rather than hitting the chuck key to loosen the chuck which tends to knacker the holes, I use a big allen key in the chuck. Lock the chuck on the short end and hit the long end with a lump of wood. Works for me but, I like the idea of the impact driver. Sandy |
Michael Brett 1 | 16/06/2022 08:43:34 |
59 forum posts 6 photos | Thanks for help. I did not realise chuck was threaded on, chuck is now of and am looking for replacement. Cheers Mike |
john fletcher 1 | 16/06/2022 14:17:18 |
893 forum posts | Not sure if this idea is applicable. I was given a really good cordless drill with two good battery packs and a badly damaged chuck. The original owner had made thing worse, as he had mangle up the screw head, so out came the angle grinder. I did a bit of grinding every day for 10 minutes or so for a week, slowly slowly as things get hot. Got there in the end, and bought a new chuck. You might like to try my idea. John |
Dalboy | 16/06/2022 14:32:01 |
![]() 1009 forum posts 305 photos | I know that you have now got it off but I use the same method as Sandy put the largest allen key that will fit and tighten it up and then give it a good tap to release that is assuming that you can tighten the chuck . |
mark costello 1 | 16/06/2022 20:16:42 |
![]() 800 forum posts 16 photos | You could put the drill under a drill press and try drilling the screw head off. |
