Help: Cordless angle grinder keeps shutting down?
Simon Robinson 409/06/2022 18:18:55
102 forum posts
When I switch on my cordless angle grinder it keeps shutting down seconds later, especially when I touch my piece of work. It was working ok yesterday but occasionally in the past it shuts down. Now it’s doing it every time I switch it on.
The battery is well charged and healthy
Thanks in advance for any replies.
DiogenesII09/06/2022 18:50:18
859 forum posts
268 photos
How many charge cycles has the battery done?
john halfpenny09/06/2022 19:02:33
314 forum posts
28 photos
I don't thnk you can 'know' that the battery is healthy when under load, notwithstanding a long charge and good voltage on a voltmeter Can you try another battery to rule out a fault with the grinder? Symptoms are those of a failing battery, as hinted.
Edited By john halfpenny on 09/06/2022 19:03:02
Spurry09/06/2022 19:23:26
227 forum posts
72 photos
I have a Makita one, and the larger capacity packs are recommended. They do tend to pull quite a bit of power, so normally use a 5 or 6Ah one.
MichaelR09/06/2022 19:27:14
528 forum posts
79 photos
Maybe your grinder has a built in automatic safety protection, which could be faulty.
MichaelR
DC31k09/06/2022 19:28:16
1186 forum posts
11 photos
Please can you tell us the make and model of grinder.
Do you have any other tools that take the same battery? Does the battery work well _under_ _load_in the other tool?
Does it have a momentary switch that you need to keep pressed to operate it? Or is it a latching on-off switch? When it shuts down, if you switch it off and then back on again, does it resume working?
If it is easy to do so, open it up and check for loose connections, intermittantly broken wires or dry solder joints.
Simon Robinson 409/06/2022 20:09:26
102 forum posts
Posted by DC31k on 09/06/2022 19:28:16:
If it is easy to do so, open it up and check for loose connections, intermittantly broken wires or dry solder joints. Actually I’ve used it a lot and it’s not needed a full charge so maybe the battery capacity is reduced.
its a Parkside grinder I got from Lidl. The battery seems to reach full charge quite quickly. Less than 20 minutes.
I think it’s a latching on off switch that slides forward. It doesn’t need to be pressed all the time.
Sometimes it starts up again after shutting down by switching it on.
Edited By Simon Robinson 4 on 09/06/2022 20:11:37
Neil Lickfold09/06/2022 20:11:17
1025 forum posts
204 photos
I have Ryobi 18v system. The dropsaw that I have will not work with their new 9amp battery. The newest drop saw does work with the 9amp battery. Apparently in the battery is a current draw control circuit. The new models have some form of ramping the start and reduces the current draw at start up. I have found that the 4amp/h batteries seem to be able to take a higher current draw. So I have only stuck with those. My circular saw from 2003 is also a high current starter, as it was from the days of Nicad batteries. It also did not start on the 9amp battery. Would just turn over and before full rpm, it shut down like the battery is not charged .
DiogenesII09/06/2022 20:56:02
859 forum posts
268 photos
Posted by Simon Robinson 4 on 09/06/2022 20:09:26:
..Are you sure the switch latches - one of the newer grinders I've had have a kind of 'dead-mans-handle' switch that cuts off if you relax your grip even a bit - it needs a strangle hold to keep it on..
...'though after checking, I find it does latch if I wring it's neck - probably best to disregard this post - apologies.. smiley
Edited By DiogenesII on 09/06/2022 20:57:06
Edited By DiogenesII on 09/06/2022 21:00:10
Dalboy09/06/2022 21:37:03
1009 forum posts
305 photos
When you switch on and push the switch to the on position try holding it there with a little pressure if the machine then continues to run then a faulty switch probabily dirty
Paul Lousick09/06/2022 23:32:09
2276 forum posts
801 photos
Angle grinders use a lot more power than a drill. I have a Ryobi angle grinder which would only work for 3-4 minutes with a fully charged 2ah battery. When I use a 5ah battery I can get more than 10 minutes of heavy use.
Hopper10/06/2022 01:24:18
7881 forum posts
397 photos
Sticky brushes? Try tapping on body to free them up and see it it then starts.
Paul Lousick10/06/2022 03:25:33
2276 forum posts
801 photos
Simon says it starts but shuts down when applying a load.
Ed Duffner13/06/2022 19:15:19
863 forum posts
104 photos
If it's recently new, Lidl, Aldi and similar shops tend to have quite generous warranties, possibly 3 years. I'd be tempted to take it back if this is the case.
If it does exactly! the same pattern of starting, then cutting out every time, I'd say it's more a controller fault (if it has one). Parts for Parkside tools don't seem to be readily available.
If intermittent or the run/stop action is not exactly the same very time, then as others have said, check the brushes and holders.
If it has a wound field coil, check where the ends of the coils are terminated into spade connectors. These enamelled wires can sometimes burn out but may still appear to be connected. Not always obvious.
If it has a permanent magnet field, check that the magnets are secured to their outer sleeve, they sometimes become loose.
Also check the battery connector has good connections, no loose spades or broken solder joints inside heat-shrink.
Ed.
