Stephen Follows | 19/05/2022 12:18:08 |
![]() 119 forum posts 3 photos | I have gone through two Dremel grinders and a cheapo lookalike in three years. The Dremels failed due to speed control burning out and the motor burning out on the second. The cheapo gearbox fell to bits. I don't use them heavily and only occasionally. Thought I'd treat myself to a Proxon, read a lot of very good reviews, not seen a bad one. Having got one and used it for light sanding it suffers the problem of over heat. Gets very hot very quickly. Too hot to hold in a matter of minutes. Don't know how long this one will last. I've come to the conclusion that there isn't a good make out there. |
SillyOldDuffer | 19/05/2022 13:22:26 |
10668 forum posts 2415 photos | Posted by Stephen Follows on 19/05/2022 12:18:08:
I have gone through two Dremel grinders and a cheapo lookalike in three years. The Dremels failed due to speed control burning out and the motor burning out on the second. The cheapo gearbox fell to bits. I don't use them heavily and only occasionally. Thought I'd treat myself to a Proxon, read a lot of very good reviews, not seen a bad one. Having got one and used it for light sanding it suffers the problem of over heat. Gets very hot very quickly. Too hot to hold in a matter of minutes. Don't know how long this one will last. I've come to the conclusion that there isn't a good make out there. Four of these tools in trouble suggests severe bad luck or they're being pushed too hard for what they are. What do you mean by "I don't use them heavily"? My Dremel shows no signs of distress, but it's only used once or twice every few months for relatively light duties - cutting and polishing small parts etc. In my workshop 10 minutes 'at it' with the Dremel is considered heavy use, and then I let it cool off for at least 10 minutes before starting again. The industrial equivalent has a separate motor spinning a chuck on the end of a bowden cable-thingy. The motor is considerably bigger than the one in a hand-held Dremel. Watched a stone mason using the same sort of tool except his was driven by compressed air - no risk of overheating but it wasn't half noisy! Dave |
Paul Lousick | 19/05/2022 13:34:33 |
2276 forum posts 801 photos | I have had my Dremel for 5+ years, is used regularly and still works OK but it is only used for light work with cutting wheels, small grinding stones and polishers. For heavy work I use a 450W electric die grinder. |
JasonB | 19/05/2022 13:39:32 |
![]() 25215 forum posts 3105 photos 1 articles | Same here my Dremel mostly gets used to tidy up castings, first lasted 10yrs or so and the current one is 4-5yrs old. If your needs are heavy enough to wear them out or make them hot then maybe a commercial electric die grinder would be a better option as your compressor won't be up to powering an air driven one. The Makita ones are good but should be for a bit over £200. |
not done it yet | 19/05/2022 14:59:46 |
7517 forum posts 20 photos | Posted by JasonB on 19/05/2022 13:39:32:
Same here my Dremel mostly gets used to tidy up castings, first lasted 10yrs or so and the current one is 4-5yrs old. If your needs are heavy enough to wear them out or make them hot then maybe a commercial electric die grinder would be a better option as your compressor won't be up to powering an air driven one. The Makita ones are good but should be for a bit over £200. Most are only 4 cfm. Even screwfix’s 100mm angle grinder quotes only 4cfm (but likely a bit of a joke). |
ega | 19/05/2022 15:04:36 |
2805 forum posts 219 photos | JasonB: I've been eyeing up the Makita range of corded die grinders and notice that one at least is stated to be "slow speed". Have you any comments as to the relative merits of these as opposed to the normal 24,000 RPM or so? |
Graham Stoppani | 19/05/2022 15:41:42 |
![]() 157 forum posts 29 photos | Posted by Stephen Follows on 19/05/2022 12:18:08:
I have gone through two Dremel grinders and a cheapo lookalike in three years. The Dremels failed due to speed control burning out and the motor burning out on the second. I replaced the speed control on my venerable Dremel last year for £3.83 with a pattern part from China bought on eBay. Works well except for the RF interference. |
JasonB | 19/05/2022 15:52:32 |
![]() 25215 forum posts 3105 photos 1 articles | Ega Which one were you looking at I was thinking of the 24-29K rpm ones like this NDIY The Screwfix 100mm angle grinder is shown as needing 170lts/min, that's 6cfm. Die Grinders are a bit less. |
not done it yet | 19/05/2022 16:44:09 |
7517 forum posts 20 photos | Sorry, it was the Toolstation one at a mere thirty quid which quoted 4cfm. |
ega | 19/05/2022 16:56:35 |
2805 forum posts 219 photos | JasonB: There's a 7000 RPM model on the same site: https://www.lawson-his.co.uk/makita-gd0811c-750w-8mm-die-grinder-7000-rpm-gd0811c I suppose that the relatively slow speed will allow larger tools to be used but be too slow for efficient cutting with the smaller sizes. |
JasonB | 19/05/2022 18:22:31 |
![]() 25215 forum posts 3105 photos 1 articles | Yes that's for larger dia tools, not that fast if you are using smallish carbide burrs or stones. Probably similar motor speed but with a gear reduction to keep the torque high rather than the others which are variable speed so would loose a bit of grunt with a flap wheel or similar when run towards the bottom of their speed range. |
William Chitham | 19/05/2022 18:55:52 |
156 forum posts 56 photos | Never used one but a pencil type air powered die grinder might be an option, maybe they don't use so much air as the standard sized ones. Very fast and not too expensive if you already have a compressor. I noticed this one in MSC's last advantage sale: William. |
AJAX | 19/05/2022 20:20:45 |
433 forum posts 42 photos | I use one of those pencil type air die grinders. Cheap ebay job. Works really well, and I've given it some abuse. 30 to 50k rpm if I remember correctly. Doesn't use much air at all. |
John P | 19/05/2022 20:47:06 |
451 forum posts 268 photos | Posted by William Chitham 19/05/2022 18:55:52 Never used one but a pencil type air powered die grinder might be an option, Jupiter Micro Die Grinder William. -------------------------------------------------- |
PatJ | 20/05/2022 02:40:37 |
![]() 613 forum posts 817 photos | I got tired of burning out Dremel's. They are only good for extremely light work. I guess I burned out 3 of them. I finally broke down and bought a tool-and-die grinder (photo below), and a carbide bit set. It is rather a beast, and you have to really hang onto it, since it won't stop of you happen to snag it on something. It works very well, but it is much larger and heavier than a dremel. It really comes into its own when I use a 2" rotoloc sanding disc, followed by a 2" ceramic sponge. The work you can do with it using the sanding disc and sponge is impressive. It won't burn out even under heavy load. Don't be fooled by the photo, it is big. Edited By PatJ on 20/05/2022 02:45:08 |
Paul Lousick | 20/05/2022 04:35:41 |
2276 forum posts 801 photos | I have the identical die grinder and needs both hands to hold it and the motor will not stall when taking heavy cuts with a 12mm dia. carbide burr on the edge of a 12mm thick steel plate. Like other cutters, rotary burrs come in different grades and it is worth paying a bit more for a quality carbide burr that will remain sharp under use. Edited By Paul Lousick on 20/05/2022 04:38:35 |
ega | 20/05/2022 10:59:48 |
2805 forum posts 219 photos | John P: Is that a Quorn spindle in your photo? |
ega | 20/05/2022 11:02:04 |
2805 forum posts 219 photos | Posted by PatJ on 20/05/2022 02:40:37:...
It is rather a beast, and you have to really hang onto it, since it won't stop of you happen to snag it on something. ...I have seen some which claim to stop if they sense a jam. |
John P | 20/05/2022 11:39:26 |
451 forum posts 268 photos | Posted by ega 20/05/2022 10:59:48 John P: Is that a Quorn spindle in your photo? ---------------------------------- No, it is 1 of 3 spindles made for this machine as internal John |
Juddy | 20/05/2022 11:53:43 |
![]() 131 forum posts | I've got one of these: KATSU Die Grinder Variable Speed 6mm 320w (aimtools.co.uk) for the price is great doesn't get hot at all the same company do this as well: KATSU Electric Straight Die Grinder 6mm 101730 (aimtools.co.uk)
