work slipping while threading ...
BASS 66617/04/2022 00:11:54
49 forum posts
38 photos
myford ml7 with 3 jaw chuck ...
i'm having bother threading mild steel with a tailstock die holder and the stock being held in the chuck ..
i turned a bar down yesterday to 9.5mm for a 3/8x24 die and it was in the chuck but when i try to thread it using the die holder the work just slips no matter how much i tighten the chuck ..
it will make the first small part of thread then just slip even with a good chamfer ...
yes i can take it out and finish in the vice but i would rather do it on the lathe .. is there a way to make the chuck grip tighter ?
the only thing i can think of is maybe a soft collar using two halfs ??
any input guys ? thanks ..
Jeff Dayman17/04/2022 00:15:55
2356 forum posts
47 photos
Piece of ordinary paper between work and jaws can make a big difference in grip. Same for work held in a mill vise or clamped to a machine table.
Emgee17/04/2022 00:20:31
2610 forum posts
312 photos
If the chuck is well used perhaps the jaws have become bell mouthed, this drastically reduces the gripping area.
Emgee
BASS 66617/04/2022 00:29:11
49 forum posts
38 photos
the chuck is worn a fair bit i think because i needed a 12mm hole through 6 penny washers so i put them in the chuck to bore through them with a drill and the washers closest to the outer edge of the chuck fell out when i tightened it ..
i done them 3 at a time ..
Ady117/04/2022 00:34:52
6137 forum posts
893 photos
You need to cut a deeper start thread on the lathe, your die is doing too much work
do most of the threading work on the lathe, the die finishes off, 10mm is medium-big work
Edited By Ady1 on 17/04/2022 00:43:34
BASS 66617/04/2022 00:47:10
49 forum posts
38 photos
Posted by Ady1 on 17/04/2022 00:34:52:
i can't cut threads on a lathe yet and the die works perfect in the vice ...
Hopper17/04/2022 00:56:47
7881 forum posts
397 photos
You have a bellmouthed chuck as your washers proved. It needs regrinding or replacing.
Meanwhile you can make life easier by reducing the diameter of your steel bar by 5 thou or more. Die goes on much easier and thread is just as strong.
And try wrapping a piece of emery paper around the job where the jaws grip.
Calum Galleitch17/04/2022 00:58:50
195 forum posts
65 photos
Assuming you are not peeling off tenths with your turning tools, you're applying as much force with a cutting tool as you are with a die, or thereabouts.
The two obvious things to me, besides checking the chuck is in good order, are (a) is it definitely mild steel and (b) is it definitely a 3/8" die and it hasn't been cranked up tight by the Incredible Hulk?
Ady117/04/2022 00:59:44
6137 forum posts
893 photos
Your die will survive a lot longer if you do most of the work on the lathe
All you're doing is stressing out your 3 jaw and die
You can make a roundbar holder or split collet for the vice which won't mark the stock so much
10-12mm is too much for a die without some precut
BASS 66617/04/2022 01:10:04
49 forum posts
38 photos
i will take this all on board and try the things mentioned .. might have a go at grinding the chuck jaws as well ...
Ady117/04/2022 01:24:31
6137 forum posts
893 photos
Everything takes forever to start with, until you get organised and get experience
It's a steep curve at the start but well worth the effort
oldvelo17/04/2022 03:40:42
297 forum posts
56 photos
An old mentor of mine back in time used to say. "To Tighten a three jaw chuck use the key in all of four holes".
It will be so tight you may need an extension on the chuck key handle to loosen it.
Never use an extension to tighten the chuck.
Martin Connelly17/04/2022 08:02:36
2549 forum posts
235 photos
Slightly off topic but I once had an apprentice complain about drills slipping in a pillar drill chuck, I told him to use the chuck key in all three positions on the chuck to tighten it. He was surprised how much the second tightening in the second position moved the jaws.
The point is that with any self centring chuck, lathe or drill, unless everything involved in tightening it is glass smooth and lubricated there will be some mechanical effort wasted due to leverage and friction. The easiest way to overcome the low leverage on the far side of each key position is to move around each position and tighten until loaded movement of the key stops.
Martin C
jimmy b17/04/2022 08:13:12
857 forum posts
45 photos
Holding in a collet would be the most secure.
Threading with a die is much more pressure than a turning tool!
Jim
Hopper17/04/2022 08:24:29
7881 forum posts
397 photos
Posted by oldvelo on 17/04/2022 03:40:42:
I do this as a matter of course on the old chuck on my Myford and it works well. But I have never had to use an extension to get it undone. Although, a good bump with the heel of the hand on the chuck key handle is often necessary.
Martin Kyte17/04/2022 09:23:09
3445 forum posts
62 photos
Stick it in the 4 Jaw
regards Martin
SillyOldDuffer17/04/2022 09:32:07
10668 forum posts
2415 photos
Washers falling out strongly suggest the chuck jaws are worn, and it's not getting a good grip on the blank rod. Regrinding them is an option, how to do it is worth starting another thread.
Otherwise:
  • It's usual for screws to be cut on a smaller diameter than nominal, up to 1% less, so 9.43mm rather than 9.525.
  • Cutting fluid is essential,
  • Dies tend to push metal as well as cut it, so threading can cause a pile up especially in softish metals. Ordinary mild steel is a bit smeary and the effect is much worse if the die is blunt, or a split die is over tightened. Never assume a second-hand die is sharp, and not all new ones are trustworthy!
  • Some dies without a split are intended to tidy up existing threads rather than cut new ones. They work, but can't be tweaked to cut tight or loose like a split die, and are more likely to get into trouble cutting a new thread.
  • 10mm is about the maximum I'd cut in a lathe without using the lathe to single-point a starter thread. Cutting a three-quarter deep thread with the lathe creates an accurate spiral for a die to follow and much reduces the work it has to do. Best of both worlds - the lathe does the grunt work and provides an accurate spiral, while the die shapes the thread's valley, flank, and crest to the correct form. The tendency of a die to squeeze rather than cut metal is reduced too. On the other hand, completely die cut threads are usually plenty good enough, and cutting a starter thread with a lathe might be considered a waste of time.
Hopper17/04/2022 10:10:20
7881 forum posts
397 photos
Has been threads on here before and article(s) in MEW on regrinding chuck jaws. It just needs a clover leaf plate, or three small bits of flat bar to push the outer ends of the jaws OUTWARDS while regrinding with a Dremel held in the toolpost.
picture 11. chuck regrinding. stop grinding when all three jaws are evenly ground..jpg
BASS 66617/04/2022 11:10:53
49 forum posts
38 photos
thanks for all the advice guys ...
Mark Rand17/04/2022 13:44:57
1505 forum posts
56 photos
In the meantime:-
  1. Have you got a drive dog that you could clamp around the part to give a bit of extra torque?
  2. Could you file three flats on the part to give the jaws a better grip?
  3. Could you drill a radial hole into the part and insert a pin to give a drive against a chuck jaw?
And last, but not least. Is the die opened up as far as it will go? Is it the right way around? Are you uing cutting oil with it?
