What size are my nipples
Dell03/04/2022 15:52:58
230 forum posts
44 photos
Hi all
i am trying to find replacement oil nipples for my Pultra 17/70 I think the thread is 0 BA because a tap seems to thread in but is there anything else that is that close that they could be , also I am having trouble locating 0BA nipples most seem to be 2BA .
Thanks Dell
Clive Foster03/04/2022 16:02:55
3630 forum posts
128 photos
0 BA and 1/4" BSF are dangerously close in size and pitch. 14 thou difference in outside diameter, 12 thou in core diameter, 0.38 tpi difference in pitch. 0 BA being smaller and finer.
Depending on the tolerances involved both will screw onto the other with varying degrees of ease and slack. Despite the difference in thread form. Such mis-fits dangerously reduce the ultimate tensile strength of the joint so pull out stresses will be much lower, probably around 1/4 of a properly mated pair.
Nigel Bennett03/04/2022 16:16:20
500 forum posts
31 photos
M6 is the same size and pitch as 0BA; just the thread angles are different.
derek hall 103/04/2022 17:06:34
322 forum posts
Nearly choked on my cup of tea when I read the title of the thread!
KWIL03/04/2022 17:16:15
3681 forum posts
70 photos
But the OP is Dell Boy?
Dell03/04/2022 17:57:33
230 forum posts
44 photos
Thanks for reply’s
I thought when I wrote title I would get some quick looks and hopefully replies.
Dell
noel shelley03/04/2022 18:07:59
2308 forum posts
33 photos
0BA, 1/4" BSF, 1/4" UNF, 6mmX1 all posible. How many do you need, Straight,45* and 90*. Noel.'
Tim Stevens03/04/2022 18:14:51
1779 forum posts
The answer, as usual, is 'it all depends'. This time, identifying a thread depends first on where it was made, and secondly, when.
Anything made in North America will generally have 'unified' threads unless it was made before WW2 or after 2000.
Before, there were SAE threads and American Threads, mostly the same as unified. A clue is that the hexagons fit AF (inch) spanners. After, there might be Metric or even ISO metric threads and mm spanner sizes.
Europe except UK, and Japan, will be metric in one form or another, and post ww2 generally ISO metric.
The UK has a wide range of options, with Whitworth and BSF etc up to about 1950, then Unified, and Metric from about 1990. BA is rather a special case, still in UK use for some things, mainly electrical switches, plugs etc, and with their own range of spanners.
The main clue, I suggest, for grease nipples is the size of the relevant spanner.
Sorry - if it was easy you would be taught it at school.
Cheers, Tim
Michael Gilligan03/04/2022 18:33:27
23121 forum posts
1360 photos
Posted by Tim Stevens on 03/04/2022 18:14:51:
Anything made in North America will […]
There is a high probability that a Pultra 17/70 was made in England
0BA does seem most likely to me, Dell …
When you have identified the thread with more confidence, try here:
**LINK** : https://www.hle.co.uk
Clive Foster03/04/2022 18:58:39
3630 forum posts
128 photos
Cheers, Tim
Spanner sizes?
Measured across flats in ascending order
M6................0.394"........................10.00 mm
0 BA.............0.413"........................10.50 mm
1/4" UNF.......0.438".........7/16".......11.11 mm
1/4" BSF.......0.525"........................13.34 mm
(assuming the spreadsheet I found ages ago is right)
Of course grease and oil nipples often use undersize hexagons.
BSF marginally more likely on a Pultra think.
Edited By Clive Foster on 03/04/2022 18:59:24
Dell03/04/2022 18:59:45
230 forum posts
44 photos
It is a 1940’s Pultra made in Manchester uk and a 2BA spanner is a good fit to the hex and most of the small nuts to adjust the crosslide gibb are BA that what makes me think it’s BA but I can’t find anyone selling any let alone brass ones that I would prefer , I have two 17/70’s to do so I need 4 and I have managed to find the paint code to the original cream colour.
bernard towers03/04/2022 19:10:41
1221 forum posts
161 photos
id' go for 0ba as it would not be m6 in 1940s Britain
duncan webster03/04/2022 19:11:14
5307 forum posts
83 photos
So buy M6 Iif you can get them) and run an 0ba die down, it's hardy a critical holding thread
Dell03/04/2022 19:20:16
230 forum posts
44 photos
Found some 6 mm that are similar looking but if I can’t find 0BA I will give them a try not a lot of money and as Duncan said it’s not exactly critical.
Peter Greene03/04/2022 19:24:05
865 forum posts
12 photos
Posted by duncan webster on 03/04/2022 19:11:14:
⬆️ Wot e sez. Don't overcomplicate it.
Edited By Peter Greene 🇨🇦 on 03/04/2022 19:24:39
Michael Gilligan03/04/2022 22:33:28
23121 forum posts
1360 photos
I doubt if this is any help … but it may be of interest:
I am almost sure that the ‘Garland’ oilers illustrated on this page are original :
http://www.lathes.co.uk/pultra1750photoessay/page2.html
and that the oilers shown here bear the same Patent number:
https://www.vintageccm.com/content/ccm-nickel-etc
Which leads us to:
https://worldwide.espacenet.com/patent/search?q=pn%3DGB576408A
Edited By Michael Gilligan on 03/04/2022 22:34:07
Dell04/04/2022 09:24:23
230 forum posts
44 photos
Posted by noel shelley on 03/04/2022 18:07:59:
Hi Noel
i need 4 straight 2 for each lathe.
Dell
noel shelley04/04/2022 09:35:17
2308 forum posts
33 photos
I have a large range though no 0 BA. Ihave sent you a PM. Noel
Tim Stevens04/04/2022 10:31:11
1779 forum posts
Further to Clive's helpful list of spanner sizes, there is 1/8 Whitworth -
0.340 inches = 8.636 mm.
This is the nominal size of the hexagon, so in practice it might be rather smaller. Stahlwille say their 1/8W spanners are (or rather were, sadly) 8.70 - 8.80 mm between flats.
I'm sorry I did not add the size details to my original response - I was imagining that engineers might have the spanners to hand. [The lowest form of wit, I suggest, is better than no wit at all.]
As regards a source of old-fashioned-sized nipples, I would try the various suppliers of stuff for vintage cars and motor bicycles. They tend to have old-stock supplies for restoration pedants, but some of these firms, organised by owners clubs, limit their clients to club members only.
Cheers, Tim
larry phelan 104/04/2022 12:17:47
1346 forum posts
15 photos
Not sure, I never checked them !cheeky
