Steven Corston | 01/04/2022 00:36:24 |
17 forum posts | I understand that the centre in the headstock end is a live centre and that in the tailstock is a dead centre. The live centre is soft whereas the dead centre is harder, or if you prefer, stiffer. Is this because rigor-mortis has set in? One of my lathes claims to be a precision lathe. What modifications do I need to make to do non precision work on it? And is it easy to convert it back to precision should I need to? Have I been scammed by lathe manufacturers? On the front of my lathes there is what the makers describe as a lead screw. On close inspection I find that this component is in fact made of steel and not lead. Why is it called a cross slide when it goes backwards and forwards? Nor does it seem any angrier than the rest of the lathe. This next one affects all of my lathes and so it must be a common problem. If I run the lathes forwards they cut metal off with no problem, BUT if I run them backwards they just will not put metal back on. Do I need to fit the tool upside down or back to front-? |
Paul Lousick | 01/04/2022 00:51:19 |
2276 forum posts 801 photos | It is the 1st of April |
Grindstone Cowboy | 01/04/2022 01:18:56 |
1160 forum posts 73 photos | Hang on a minute... these sort of questions sound a bit familiar Nice one Steven. Rob |
Mike Rogers 2 | 01/04/2022 04:48:54 |
1 forum posts | I've got a QCTP on my lathe. Is it necessary to change over to the lantern tool post when machining at night? Mike |
jimmy b | 01/04/2022 05:29:13 |
![]() 857 forum posts 45 photos | Thank you Steven, put a smile on my face! Jim |
Nick Clarke 3 | 01/04/2022 09:11:48 |
![]() 1607 forum posts 69 photos | Like most others my lathe has a head stock and a tail stock. But a word of warning to others - both head stock and tail stock make appalling soup. |
john halfpenny | 01/04/2022 09:14:52 |
314 forum posts 28 photos | Yes Mike, you do need a lantern tool post at night - but don't forget you will also need a matching lantern chuck Edited By john halfpenny on 01/04/2022 09:15:18 |
Dave Halford | 01/04/2022 09:22:54 |
2536 forum posts 24 photos | Given the cost of power these days the lantern tool post or better still an original Victorian candle tool post if you can find one could save you a great deal of money. |
Speedy Builder5 | 01/04/2022 09:33:05 |
2878 forum posts 248 photos | My drill won't fit into my chuck, the battery and motor stick out too far - what am I doing wrong? I Diot |
john halfpenny | 01/04/2022 10:03:27 |
314 forum posts 28 photos | Very illuminating Dave, but surely only suitable for light machining. |
Steven Corston | 01/04/2022 10:09:14 |
17 forum posts | I thought a lantern tool post was just for light machining. |
Nick Wheeler | 01/04/2022 10:10:13 |
1227 forum posts 101 photos | Not if you use bright steel. |
Dalboy | 01/04/2022 10:16:35 |
![]() 1009 forum posts 305 photos | Hot rolled steel is used to keep the workshop warm |
Nigel Bennett | 01/04/2022 10:39:11 |
![]() 500 forum posts 31 photos | Oh give it a rest... steady on! |
Dave Halford | 01/04/2022 11:05:57 |
2536 forum posts 24 photos | Free machining steel comes with free electricity vouchers. |
Howard Lewis | 01/04/2022 16:36:06 |
7227 forum posts 21 photos | Ah! Thats why I had an argument with the stockist over being charged for free machining steel! And I thought that pig iron always produced curly swarf! Howard |
larry phelan 1 | 01/04/2022 16:49:14 |
1346 forum posts 15 photos | Nice to get a new angle on these things, but how much is true ? I think some of it is a bit rough, but maybe thats the drill. |
David Millar 3 | 01/04/2022 16:49:35 |
28 forum posts | Does steel wool come from hydraulic rams? |
Grindstone Cowboy | 01/04/2022 16:53:33 |
1160 forum posts 73 photos | Apparently the customs papers for a chap importing hydraulic rams into Zimbabwe were maked "Livestock" Rob |
Howard Lewis | 01/04/2022 16:56:26 |
7227 forum posts 21 photos | Seriously, I believe that someone in the far east translated "Hydraulic Ram" as "Water Buffalo"! Talk about being lost in translation! Howard |
