Dr_GMJN | 05/02/2022 13:05:59 |
![]() 1602 forum posts | All, can anyone recommend a small magnifier for inspecting things like part centres in a lathe chuck, the accuracy of a centre punched workpiece, or the condition of a tool tip? My near point is getting ever further away. I've got an eye loupe, but I want something that I don't need to get my head right next to the part. I've also got a Sandvik loupe with a scale mounted under it, so you can estimate measurements, but this only really works of flat surfaces, and the scale obstructs whatever you're trying to put under it. For scale modelling, I've got a light-weight glasses type magnifier with long eye relief, but I don't want to be putting that kind of thing on just for a quick check of something. I've also got a larger reading type magifying lass, which it a bit bulky, and not really enough magnification. I'd think 5x-10x would be OK. Not after anything elaborate, just a decent quality small hand-held magnifier. Cheers. |
Frances IoM | 05/02/2022 13:11:58 |
1395 forum posts 30 photos | I'd consider a USB microscope - small easily mounted on a flexible arm - most households have an old laptop that can serve. Bit more expensive but useful elsewhere are the inspection camera with small detached monitor |
MikeK | 05/02/2022 14:40:25 |
226 forum posts 17 photos | Not hand held, but I like my Donegan OptiVisor. Easy on and off and frees both hands. |
Howard Lewis | 05/02/2022 14:48:48 |
7227 forum posts 21 photos | I use a folding 8x magnifier, to examine centres, tool tips / edges. held close to the eye it means being close to the subject, and has very shallow depth of field, but shows the subject very clearly. Ideally you will need to find a fairly old fashioned opticians, to get one from stock, but there is always the internet! Howard |
Kiwi Bloke | 06/02/2022 09:07:29 |
912 forum posts 3 photos | I have a few small folding hand-held magnifiers, 8X and 10X. There seems to be considerable difference between them, in terms of depth of field and consequent ease of use. The best one was my father's. He bought it for his philatelic obsession, and would not have bought something cheap and nasty. He was very proud of it, and I remember him demonstrating to a quite young me its freedom from chromatic aberration, and what an 'achromatic doublet' was, and how such things worked. Unfortunately, its working distance is probably closer than you want. My second-best wasn't cheap, but it shows colour fringes. Quality comes at a price... I was impressed by the magnifiers my dentist wears, which allow working at a comfortable distance. Alas, they are unaffordable. |
Bill Davies 2 | 06/02/2022 09:57:23 |
357 forum posts 13 photos | I find telescope/microscope eyepieces, used in reverse, very good for detailed closed-up work. Bill |
Nick Clarke 3 | 06/02/2022 09:58:18 |
![]() 1607 forum posts 69 photos | I use an older Eschenbach hand magnifier - 10x magnification and 35mm diameter. Illuminated and the newer versions like the picture below come with a stand. Cromwell sell them for about £45 + VAT and post and Amazon for about £70 presumably all in. |
Nick Clarke 3 | 06/02/2022 10:05:09 |
![]() 1607 forum posts 69 photos | Even with quality magnifiers; at 10x you are more than likely to get colour fringing. When teaching visually impaired children their use you always try to use the lowest magnification that was useful to give a wider field of view and longer viewing distance. An illuminated magnifier or excellent lighting is as important as the strength of the lens, and a coated lens is important too, to reduce flare. Edited By Nick Clarke 3 on 06/02/2022 10:05:32 |
Mike Hurley | 06/02/2022 10:10:30 |
530 forum posts 89 photos | What about the Steve Fletcher (The Repair Shop) approach of mutiple pairs of glasses? Variable magnifications & quite cheap if using 'readers' at £1 pair. P.s. and keeps both your hands free!
Edit for p.s. Edited By Mike Hurley on 06/02/2022 10:12:35 |
Nick Clarke 3 | 06/02/2022 10:15:26 |
![]() 1607 forum posts 69 photos | While I love watching Steve Fletcher at work with two or three pairs of glasses, why to I keep getting flashbacks to Professor Brainstawm in the Norman Hunter books? |
Mike Hurley | 06/02/2022 10:19:21 |
530 forum posts 89 photos | Absolutely Nick! Allways makes me chuckle. He does some fine work though Mike |
Martin Kyte | 06/02/2022 11:04:49 |
![]() 3445 forum posts 62 photos | Take a picture with your phone. regards Martin |
Dr_GMJN | 06/02/2022 18:41:04 |
![]() 1602 forum posts | Posted by Nick Clarke 3 on 06/02/2022 09:58:18:
Thanks Nick - spot-on. Bit more than I wanted to spend, but I'll try and find one. |
MikeK | 06/02/2022 18:58:28 |
226 forum posts 17 photos | Amazon has a similar one that this thread has prompted me to get: |
Peter Greene | 06/02/2022 19:43:24 |
865 forum posts 12 photos | That looks like a right handy device for the shop, Mike. I checked it out on the Canadian (and UK) Amazon sites as well - which you can usually do with Amazon by editing the .com to .ca or .co.uk. Granted our exchange rate is the pits right now but I was a bit appalled by the Canadian price. |
Peter Greene | 12/02/2022 17:17:34 |
865 forum posts 12 photos | I did find one of these at Amazon.ca for a better price here. I must say that it was a decent product. The plastic parts fit well (without reveals) and it looks much better than the price would suggest. I'm curious though: how is the magnification (" 10x " in this case) calculated for something like this? 'cause things sure ain't ten-times bigger. Two or three-times perhaps.
Andrew Tinsley | 12/02/2022 18:54:57 |
1817 forum posts 2 photos | The Eschenbach magnifiers are available from ZORO at a better price than Cromwell. Andrew. |
Bill Phinn | 12/02/2022 20:55:38 |
1076 forum posts 129 photos | Posted by Peter Greene 🇨🇦 on 12/02/2022 17:17:34:
They think of an impressive sounding round number and calculate most people aren't going to know any better. Yes, most economy magnifiers and loupes are definitely not the magnification they're claimed to be. I use a Schweizer magnifier, and Eschenbach and Belomo loupes. I have the Belomos in 8X, 10X, 12X, 15X, and 20X magnifications, though I only really use the 8X to 12X ones most of the time. Edited By Bill Phinn on 12/02/2022 20:56:30 |
Huub | 12/02/2022 22:55:29 |
220 forum posts 20 photos |
I use this 10X magnifier that has a scale to inspect tool tips and other small stuff. |
Paul L | 13/02/2022 08:37:59 |
![]() 87 forum posts 26 photos | You could have a look HERE The loupestore.co.uk they seem to cater for every need / budget. I have no affiliation, just a happy customer. |
