Chris Mate | 14/12/2021 06:14:23 |
325 forum posts 52 photos |
Hi, my new vice jaws are 29mm high. The place I usually buy stuff from has two sets of parrallels 1/4" & 1/2" thick. However the hights confuse me a bit, most of the set will be too high for the jaws. Contents include: |
Speedy Builder5 | 14/12/2021 06:41:12 |
2878 forum posts 248 photos | Its fairly obvious that the set is not for you, there are other sets out there. Its a matter of looking around. |
JasonB | 14/12/2021 07:21:33 |
![]() 25215 forum posts 3105 photos 1 articles | I have several vices collected over time some with taller jaws than others so get to use most of my 1/2" to 2" set, I also regularly use the taller ones for packing up work mounted directly on the mill table or lathe cross slide so although the bigger ones may not get used so often they can be useful to have. The 80mm versatile that I use on the CNC has the shortest jaws and I just keep one of the economy sets by that which do for most jobs and save having to fetch the main set from the other workshop, only ground on the two edges but that's all you use. If your vice is reasonably small as the 29mm jaw height suggests you are mostly going to be working on smaller parts so I would suggest the thinner of the two as you will find with a thick parallel in place you can't close the jaws down on it unless additional side packing is added. The wavy parallels are good in this respect as you can squash them right down to almost nothing. |
HOWARDT | 14/12/2021 07:21:35 |
1081 forum posts 39 photos | Parallels should match width of jaws as well as fitting within the height. Sets usually either 4 or 6 inch, some can be bought as 1/8 th thick set so tend to be lower height. |
not done it yet | 14/12/2021 08:12:31 |
7517 forum posts 20 photos | I think those that Arceuro sell are metric, but should suit jaws that are metric high.🙂 |
Baz | 14/12/2021 08:18:24 |
1033 forum posts 2 photos | Warco do a nice set that are 100mm long and range from 5mm to 25mm high in various thicknesses. |
Tony Pratt 1 | 14/12/2021 09:09:18 |
2319 forum posts 13 photos | You have to buy parallels to suit your particular vice. Tony |
Journeyman | 14/12/2021 09:15:41 |
![]() 1257 forum posts 264 photos | You could try these *** LINK *** haven't used myself but might be worth a go! Going a bit 'off piste' as it were, I wonder if 3D printed parallels would be any good. Of course these would not be precision or long lasting but might suffice for the odd job and 3D printing can be surprisingly accurate with a good set-up. John Edited By Journeyman on 14/12/2021 09:21:45 |
Chris Mate | 14/12/2021 09:15:59 |
325 forum posts 52 photos | Thanks for the advice, I think I settle for 3mm x 150mm 12.5Kg set as example a dealer send me, however the 150mm is not right, so I am trying to get 100mmx 3mm set from them from Vertex(Same as vice). |
JasonB | 14/12/2021 09:43:10 |
![]() 25215 forum posts 3105 photos 1 articles | I use 6" on sin my 4" vertex all the time what is not right about that? Also use them in my other 90mm and 80mm and even the 35mm vices when they come out. Rather than 3D printed ones to get you out of trouble any bit of flat bar or tool bit will do, I managed for quite a while like that. I'd look for something that allows you to hold work 1mm to 1.5mm below your vice jaws as it's often useful when working on small parts, I'd find the 25mm high set a bit limiting in 29mm jaws.
Edited By JasonB on 14/12/2021 09:50:57 |
Bazyle | 14/12/2021 11:26:23 |
![]() 6956 forum posts 229 photos | Posted by Journeyman on 14/12/2021 09:15:41:
I wonder if 3D printed parallels would be any good. Edited By Journeyman on 14/12/2021 09:21:45 I think a decent bit of hardwood would be better. Especially off an old well seasoned furniture. Worth having some around that you can mill down when you want to set something small and need a support just below the jaws. I think 3D printing might be better for making a compliant (squidgy) custom jaw to grip an awkward shape. |
David Caunt | 14/12/2021 11:31:42 |
![]() 110 forum posts 40 photos | Chris. I made a set of parallels but then found I needed thinner parallels so bought a set of Precision Wavy Parallel 8pc Metric Set from Arc.... They get used all the time. Dave |
Nicholas Farr | 14/12/2021 12:24:38 |
![]() 3988 forum posts 1799 photos | Posted by HOWARDT on 14/12/2021 07:21:35:
Parallels should match width of jaws as well as fitting within the height. Sets usually either 4 or 6 inch, some can be bought as 1/8 th thick set so tend to be lower height. Hi HowardT, I can't se why they have to match the width of the jaws, as long as they are long enough for the work envelope on the piece you are machining on, where's the problem and like JasonB says, I've got a pair of those that he linked to, at the moment, which are longer than the jaws and the piece they are holding to the correct height. I have made two pairs, one 16mm high and one 22mm high & 4mm thick, which are 80mm long, these were made from a scrap cast iron baffle from a lorry engine (don't know what it did, but had a nice flat section) which I just milled to the highs mentioned within a small amount, but each pair was milled together, OK, I don't profess them to be precision, but they are the next best thing and they do well for many jobs, but like Jason has said, decent flat bar will do many jobs that don't require precision work. Regards Nick. Edited By Nicholas Farr on 14/12/2021 12:26:15 |
Tony Pratt 1 | 14/12/2021 12:40:53 |
2319 forum posts 13 photos | 3D printing is not the way to go, I can't think of anything less suitable for parallels than plastic. Tony |
Bill Phinn | 14/12/2021 13:10:41 |
1076 forum posts 129 photos | There is a 100mm-long twenty-pair set floating around out there. Arceurotrade and Amadeal among others sell, or at least sold, them. They may not necessarily be of the same quality at different suppliers. They were the only set I used for a while, and often I obtained the height I wanted by doubling up parallels. As long as you seat the parallels and work carefully, I can't see any reason why placing parallels on top of one another to obtain a target height should be regarded as bad practice. One good feature of the set is the variation in thickness - something that, inexplicably, isn't very common with sets of parallels. The spec. of the 20 pair set is as follows: 2mm width (5, 10, 15 & 20mm height)
3mm width (6, 11, 16 & 21mm height) 4mm width (7, 12, 17 & 22mm height) 5mm width ( 8, 13, 18 & 23mm height) 6mm width (9, 14, 19 & 24mm height) |
John Haine | 14/12/2021 13:17:43 |
5563 forum posts 322 photos | Absolutely no reason why their length has to match the jaw. Thinner ones are better, up (down that is!) to a point, as you can clamp thinner work. A tip, put a single parallel diagonally across the vice opening, put the work on top of it and carefully clamp - will work fine in most cases if the work is thinner than two parallels but thicker than 1. I think Harold Hall explains how to make them in his book (maybe on website?), clamp steel strip to angle plate in pairs, resting on an improvised parallel, with the top of the strips above the top edge of the plate. Mill the two edges flat as one; then turn over end for end to mill the other edges. This must make them parallel, even if the one they are resting on isn't. |
not done it yet | 14/12/2021 13:18:40 |
7517 forum posts 20 photos | Posted by Tony Pratt 1 on 14/12/2021 12:40:53:
3D printing is not the way to go, I can't think of anything less suitable for parallels than plastic. Tony Ooh, I don’t know about that. Certainly not the usual ‘starter’ plastic but there are some ‘reinforced’ filament materials available these days. As usual, the precision needs to be less than that which the part(s) is (are) being made to and certainly not less than that which would allow repeat parts in spec. I have a set ex-Arc, but any in the future will be home-made, heat treatment/finish dependent on how long I would expect them to last. |
stuart jones 2 | 14/12/2021 13:24:19 |
13 forum posts | If you 3d print with pla they will melt if you get them worm |
Journeyman | 14/12/2021 13:27:55 |
![]() 1257 forum posts 264 photos | Well someone on Thingiverse got there before me *** LINK *** John |
JasonB | 14/12/2021 14:25:55 |
![]() 25215 forum posts 3105 photos 1 articles | Another very good tip I saw in ME that the MEW readers may have missed is to write down on the rack or box where you store your parallels the depth below the jaws that each pair give rather than just their height. This saves trying one or two pairs to get that particular part just where you want it, all you do is pick a parallel that gives a depth just less than the thickness of what's being held. Must get round to doing it myself 3D printed would be handy for specific angles or as said nesting jaws. |
