Member postings for stuart jones 2
Here is a list of all the postings stuart jones 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Mystery discs - what are they?
20/03/2022 10:55:24
I've seen similar rings used In drafting to produce a offset line inside or outside a straight or irregular shape ,it works the same as the offset tool in AutoCAD by putting a pen or scriber inside the ring and rolling it around the shape ,I have used it on jobs and it works well
Thread: unknown thread of this tap
27/01/2022 21:28:36
It might be for threading rifle bores looking at the long lead at the front maybe to fit a smaller bore possibility an airgun /rifle
Thread: Drilling brass.
14/12/2021 22:00:44
At work I drilled lot of aluminium bronze ,as mentioned grinding a negative rake on the drill is the way to go.and reduce the web at the point.
When drilling deep holes the drill tended to tighten and seize up in the hole ,to overcome this I would use a smaller drill and grind the point slightly offset Which worked well, also avoid a poilet hole if possible.good luck
Edited By stuart jones 2 on 14/12/2021 22:10:24
Thread: Hello from Bromsgrove
14/12/2021 20:59:53
Sorry Vic but I've got my heart set on a bandsaw I found it more useful when I worked in a toolroom
Thread: Sets of parallels
14/12/2021 13:24:19
If you 3d print with pla they will melt if you get them worm
14/12/2021 11:54:23
I think you may be right Mike i seem to be finding it harder to find time to potter but I'm in no rush
Hope every one stays healthy and fit and have a good christmas all
14/12/2021 08:49:47
I don't have any plans to build models at the moment , it's to cold in the garage to work but it gives me time to decide on a design for the bandsaw which I will need to build models or what ever. having not long retired Bill I don't know how much time I will have,the wife has plans to ?
13/12/2021 21:44:06
Looking at the small type bandsaws Dave ,I think would not work for me long term I'll will need something bigger.
They look good value but building my own appeals to me.Tony foale video gives me some ideas but what I end up with God knows . well I know where to come when I get stuck
Edited By stuart jones 2 on 13/12/2021 21:45:26
13/12/2021 11:17:52
Thanks for the feedback ,the clarkes saw looks like a good option ,a bit pricey but takes up floor space i don't have ,if i could find solid well made old bandsaw to rebuild i would go for that ,if not its back to the drawing board
12/12/2021 16:08:57
Thanks for the welcome lads .the problem with cheap and small bandsaws is that they tend to run to fast to cut steel and I don't have the room for a full-size job so making one gives me a project .l have a old Wick's one but it's not worth trying to convert it ,it may take some time but I am retired ?
11/12/2021 20:48:03
Hi all I'm a retired toolmaker I've worked in the screw trade ,spring trade ,tube bending tooling,and press tooling.
I got myself a mini mill just to keep my hand in and am thinking of building a band saw so advice would be welcome thanks
11/12/2021 11:20:18
Just joined and am looking forward to learning new skills ,tips and ideas from the helpful people on this forum
Thread: Digital Caliper - again, sorry
09/12/2021 18:30:34
I use my old vernier calliper for general use if i can find my glasses ? And my cheap digital callipers for closer work. And take out the battery when not in use. More hassle but the battery lasts longer
