Help with car boot finds
colin hamilton14/11/2021 09:45:44
186 forum posts
94 photos
Now that I'm trying to get into machining I'm always on the look out for car boot treasure. I think I did well today getting this lot for £7.
I've got a couple of questions. How best to clean up the micrometer. It' works fine but has some surface rust and the markings are faint. I'm worried that by trying to sort the rust I'm likely to make the markings fainter.
Also how should I be setting the dti up? The little bracket doesn't seem to fit the post and the dti. Am I missing some bits?
Thor 🇳🇴14/11/2021 10:09:15
1766 forum posts
46 photos
Hi Colin,
Not sure if you need to do much with your micrometer if it is working OK, wipe with an oil soaked rag may be, there is more about micrometer maintenance here.
In your third photo it seems to me that the bracket grips around the moving part (plunger) of the dial indicator? If so it should grip closer to the dial around the stem.
Thor
Edited By Thor 🇳🇴 on 14/11/2021 10:10:43
Michael Gilligan14/11/2021 10:18:16
23121 forum posts
1360 photos
Posted by colin hamilton on 14/11/2021 09:45:44:
dont know
As noted by Thor ^^^
vic newey14/11/2021 11:36:36
347 forum posts
173 photos
Does the dial indicator return to zero if you release it from a short distance? faulty one often return from a full press but fail from a 1/4 press etc.
Martin King 214/11/2021 11:47:04
1129 forum posts
An excellent haul for £7!
Where did you say this car boot was??? winkwink
Well done!
Martin
peak414/11/2021 12:14:33
2207 forum posts
210 photos
I do like the bell crank to the right of the DTI in the box, I've been keeping an eye out for one for ages.
Bill
colin hamilton14/11/2021 14:50:45
186 forum posts
94 photos
Posted by Thor 🇳🇴 on 14/11/2021
Thor
That's the problem. It is to narrow to go round the stem.
colin hamilton14/11/2021 14:52:03
186 forum posts
94 photos
Posted by vic newey on 14/11/2021 11:36:36:
Thanks for the tip. Yes all returns to zero
Michael Gilligan14/11/2021 14:55:42
23121 forum posts
1360 photos
Posted by colin hamilton on 14/11/2021 14:50:45:
Then presumably the wrong clamp has crept into the box
[ there are several variants ]
Howard Lewis14/11/2021 15:07:48
7227 forum posts
21 photos
A splendid haul for £7!
The clamp block should fit around the fixed stem, NOT the plunger, of the DTI, to clamp it to the rod on the G clamp, or the holder in the RH bottom corner of the box.
If the "Monkey Block" will mot do this, you can always make a suitable clamp in your shop.
Use a piece of 1/2" or 12 mm square bar and with a bit of drilling, tapping and hacksawing yo will have a bespoke one! If you want to make a really neat job, copy the existing one, to amended dimensions, to clamp the DTI to the rods, and make a really smart job by knurling the thumb screw.
The lever arrangement is particularly useful. It will clamp around the stem of the DTI and allow it to be used to clock bores.
Another project to go on the Round Tuit!
If the centres won't clean up particularly well, they can always be used to centre work in a 4 jaw chuck using the "Two Centres" method. Assuming that there is a centre drilling in the rear end of each one.
(There's a picture of this on the front cover of Tubal Cain's "Simple Workshop Devices" No. 28 in the Workshop Practice Series. )
Maurice Taylor14/11/2021 16:14:01
275 forum posts
39 photos
Hi, I’ve recently cleaned rusty tools in white vinegar ,soak overnight or longer ,then use wire brush ,steel wool or scotchbrite .
Maurice
Thor 🇳🇴14/11/2021 19:23:08
1766 forum posts
46 photos
Thor
OK. Seems to me that it should be possible to either make a new clamp that will fit the stem or make a new part for the existing clamp with a hole that fit the stem. I have made similar clamps myself, not difficult.
Thor
colin hamilton14/11/2021 19:49:35
186 forum posts
94 photos
Thanks everyone. I love the fact every time I buy a tool I end up making a tool!!
Grindstone Cowboy14/11/2021 23:37:49
1160 forum posts
73 photos
If there is a lug on the back of that indicator, then you just need to make a shouldered stud that will attach through the lug, secured with a nice knurled nut, and with the protruding plain shank of a diameter to fit the hole in the clamp you already have.
I've probably not explained that very well indecision
Rob
Grindstone Cowboy15/11/2021 01:18:31
1160 forum posts
73 photos
Something like this
colin hamilton16/11/2021 15:55:10
186 forum posts
94 photos
Posted by Grindstone Cowboy on 15/11/2021 01:18:31:
Something like this
It does have a lug and your suggestion is fantastic as is your model. Thanks for the advice
Oldiron16/11/2021 16:41:19
1193 forum posts
59 photos
Posted by peak4 on 14/11/2021 12:14:33:
Bill
See your messages Bill
regards
Grindstone Cowboy16/11/2021 19:33:58
1160 forum posts
73 photos
Posted by colin hamilton on 16/11/2021 15:55:10:
Thank you, I'm teaching myself how to use Solid Edge, so thought I'd try to draw something useful for a change - there's no doubt a proper way to do threads, but I've not got that far yet wink
Rob
