Here is a list of all the postings colin hamilton has made in our forums. Click on a thread name to jump to the thread.
Thread: Optical bore guage |
02/10/2023 17:03:23 |
Posted by Michael Gilligan on 02/10/2023 09:02:46:
Just thought you might like to see this on ebay, Colin **LINK** https://www.ebay.co.uk/itm/394734119321 They also have a metric one MichaelG. Blimey I did get a bargin!! But I think mine might be an older model
Edited By colin hamilton on 02/10/2023 17:05:12 |
01/10/2023 14:56:26 |
I was down the car boot today and got 4 optical guages made by a company called Technica A-G. I have never come across them before but they are fantastic. There is a small plunger that pops out and measure the bore. There is a small window which you peer into and can read the measurement directly if a vernier scale, which is very cool. Unfortunately two of them are faulty. One has the plunger stuck in and the other has thevplunger stuck out I'm hoping the just need a bit of a clean. Does anyone know how I would go about freeing them?
Thanks Colin |
Thread: Capacitor selection |
16/09/2023 23:32:49 |
Posted by Robert Atkinson 2 on 16/09/2023 13:08:08:
As long as the centrifugal switch is working and the motor is not getting hot the bigger capacitor may not be a problem. It is mainly purpose is to provide a phase shift. The current depends on both the capacitor and the winding. Robert.
Sounds good. I may just let it be for a while and see what happens |
16/09/2023 12:40:44 |
Update no 2: It turns out the capacitor was sealed inside a can. It's actually 20uF so with my 200uF I'm guessing the windings won't last long. I'll get another ordered. |
15/09/2023 19:10:01 |
Posted by not done it yet on 15/09/2023 18:42:44:
Posted by noel shelley on 15/09/2023 16:04:04:
It's good to hear that all is well again. Thank you for letting us know. As you use it just check that it does NOT run to hot, warm is fine. Noel It should not be in circuit for long as a ‘starting’ capacitor? I'm pretty sure I can hear the centrifugal switch disconnecting it shorty after starting. I only know about centrifugal switches thanks to this thread!!!! |
15/09/2023 15:33:47 |
Quick update: I've just connected a 450V 200uF and it runs like a dream. Thanks for all your input. Cheers Colin |
11/09/2023 06:06:17 |
Posted by Simon Williams 3 on 10/09/2023 23:22:19:
Solution of the circuit for Vc depends on the upstream resistance of the supply as well as all the other stuff. Inrush current of a single phase motor on start-up is about 9 times the Full Load Current, which is why single phase motors are a beast to start on a generator. With an upstream source resistance of typically a few ohms you can very soon see a significant voltage droop at the motor L-N terminals. So the answer is always going to be an approximation. To a first guess, the squirrel cage rotor is a short circuit when stationary. This is magnetically coupled to the start and run windings, so they also look like a near short circuit until the rotor starts to turn. IF you've got enough oomph in the supply to get the rotor rolling. If the start winding is effectively short circuited something approaching the full supply voltage appears at the terminals of the start capacitor, which is why it should be rated for the full supply voltage, Incoming supply is nominally 230 volts RMS, so peak instantaneous supply voltage as experienced by the capacitor is 1.414 times 230 volts = 325 volts as near as the model needs. However, as a related train of thought I found myself repairing a tumble drier recently, which resolved itself into replacing the series capacitor in a little pcb which controlled the power button latch function. Essentially the capacitor (0.22uF) was in series with the 24volts DC coil of a miniature relay and a bridge rectifier (no smoothing) with 230 volt mains applied to the circuit. So the capacitor was the dropper resistor. Measuring the capacitor revealed it was no longer a 0.22 uF one it had become 0.1 uF and the coil of the latch relay now had about 8 volts dc on it. I can't remember the RMS to Peak conversion factor for a full wave rectified waveform but any which way this wasn't enough to pull in the relay. The capacitor was marked 250 V and one would expect this to be the peak dc voltage rating. I tried a higher voltage capacitor, but it wouldn't fit the pcb, so against my better judgement I fitted an exact replacement. It's famous last words but it hasn't gone bang yet. Which I offer as anecdotal evidence that the voltage ratings on these capacitors are conservative, though I guess one ought to consider the effects of the circulating currents the capacitor sees, and therefore the effects of heat generated by these currents and the internal resistance of the capacitor, So any old capacitor won't do, it needs to be a motor start capacitor designed for the duty. Rgds to all Simon
So any suggestions to what I should buy? Thanks Colin |
10/09/2023 19:24:28 |
Thanks everyone. I'm going to have a look at the centrifugal switch first and if that looks OK I'm going to go for a 400v 200uf and see what happens!! |
10/09/2023 18:07:51 |
Posted by Clive Foster on 10/09/2023 17:24:32:
For a 1/2 hp motor the generic start capacitor recommendations from several sources range from 150 to 250 µF. That said exact value doesn't usually matter too much unless you are starting a significant load. I'd try 200 µF. Give that large numbers of aged single phase motors are still starting just fine 50 or more years after they were made you hafta wonder how close the current values of capacitance are to the brand new figures. Clive Sounds good thanks
10/09/2023 17:19:24 |
Posted by noel shelley on 10/09/2023 15:43:04:
IF your luck is in and you look VERY carefully you should find the value of the one you have stampted on the tin tube, on the end and painted over ! Note that the voltage may well be 400V. It is possible with the right meter to check the value it currently is ! Or has the centrifugal switch failed ? Good Luck Noel. I had a good look but couldn't see any trace of markings. The plate is stamped 230V and it runs well on the domestic mains once started. What makes you think it could be 400V? Thanks Colin |
10/09/2023 14:37:31 |
I picked up a motor at a local auction. Its a single phase 0.5hp induction motor. It doesn't self start but runs fine if I give the output a spin. I'm assuming the starter capacitor is faulty. Could someone push me in the direction of a suitable replacement (size and type). Thanks Colin
Thread: Help identify collet chuck |
27/08/2023 13:52:01 |
Thanks everyone. I'll have a look at the various raper specs. If I can identify it I will try and sell on. If not I'll have a go at turning the taper down. |
Thread: Counterbore as facemill? |
27/08/2023 13:50:07 |
I reckon I'm just going to find some projects that need a whole load of various counterbores |
Thread: What are these for? |
27/08/2023 13:48:06 |
Thanks everyone. So it looks like they are for wood working. I'll stick them on a shelf somewhere and forget that I have them!! |
27/08/2023 13:47:55 |
26/08/2023 07:53:21 |
Help identifying these would be appreciated. They are thread m10 on the end
Thanks Colin
26/08/2023 07:46:09 |
Posted by Thor 🇳🇴 on 26/08/2023 07:13:22:
Hi Colin, Nice find, why not try one of the larger counterbores and see how it works as a face-mill. Thor Thanks. I will do but given how much they cost I wanted to check I won't just trash them |
25/08/2023 19:47:43 |
I bought a joblot of machine tooling and it included these tools. It turns out they are granlund counterbores. I nearly had a heartattack when i saw how much they cost!! They vary in size up to 50mm. I'm never going to need a counterbore anywhere near that big so was wondering if I could use the larger ones as facemills or given the price of them better to sell them on. Cheers Colin Edited By colin hamilton on 25/08/2023 19:48:21 |
25/08/2023 18:11:41 |
I bought a mixed lot of machine tooling and was hoping to get some help identifying this collet chuck. What collets are they? And what taper is the it? I've got a brideport so this obviously doesn't fit but I was wondering it I could machine the taper parallel to fit a suitable R8 collet? Thanks Colin
Thread: Needle roller bearings |
01/08/2023 21:46:00 |
Thanks everyone, I have found a bearing supplier who can help |
