Is it possible to machine a lathe more accurate than the one you machine it on? If so, how?
Henry Bainbridge28/10/2021 19:38:50
16 forum posts
Hi, just trying to get in to the classifieds, but thought I might as well ask, since its always intrigued me.
Michael Gilligan28/10/2021 20:16:16
23121 forum posts
1360 photos
It depends how you define accuracy
The ‘first’ lathe need not have anything recognisably accurate about it … It could be the simple bodger’s lathe, or the watchmaker’s turns : both of which are little more than a couple of centres and a hand-rest.
Thanks for actually contributing something to the forum, instead of just making dummy posts yes
Rod Renshaw28/10/2021 20:43:54
438 forum posts
I don't really know, but logic suggests that the earliest makers of lathes must have used some sort of dead centre lathe with hand held tools ( as Michael suggests), to make at least the turned parts of what we might recognise as the first type of lathe having any kind of similarity to what we would call a machine lathe today.
If the parts produced were not as good as wanted they may have been corrected by hand tool methods and then built into a new machine better than the one they were turned on.
I understand the very finest watchmakers' work is still done on primitive looking dead centre "turns"
I remember reading someone who had an Ornamental Turning lathe saying that all the screws holding his lathe together had centres in the ends showing that they must have been turned between centres, perhaps using a single point hand held "threading tool" to cut the threads, no wonder the screws were not interchangeable.
I should think that making an accurate lathe bed would have been very challenging until planers (or similar) were developed which begs the question "how did they make the planer bed?"
Rod
John P28/10/2021 21:25:18
451 forum posts
268 photos
"Is it possible to machine a lathe more accurate than the one you machine it on If so, how?"
I suppose the question here is posed incorrectly and perhaps should be.
Is it possible to produce a machine that will produce more accurate work
that the machine 's that it was made on.
If that is so then it is here is one
This cylindrical grinder was made in just that way ,the cylindrical square here
held between centres is within 1 um along the entire length and stands
square on a surface plate to within the thickness of 1 um clock gauge
indicator needle in any 4 places around the diameter.
As for the how, ME have had the construction article for the last 7+ years
or so if they haven't lost it again.
JA28/10/2021 22:51:23
1605 forum posts
83 photos
Henry Maudslay.
JA
Henry, sorry for the glib answer, just follow the name. [I don't usually post anything late at night].
Edited By JA on 28/10/2021 22:54:13
Bazyle28/10/2021 23:34:49
6956 forum posts
229 photos
If you decide which part of the first lathe is letting it down you can use the lathe to make either a new part or a another machine that helps you make the new, better, part.
An easy example is the leadscrew. Lathes were made that averaged the errors of the leadscrew while making a new screw. Loop that back into the lathe and repeat.
Farmboy28/10/2021 23:56:51
171 forum posts
"Is it possible to machine a lathe more accurate than the one you machine it on?"
Surely the underlying principle behind all human development for a couple of million years . . . nerd
John Olsen29/10/2021 00:17:57
1294 forum posts
108 photos
Maybe worth mentioning a couple of techniques.
Accurate flats and straight edges can be made by making three at a time. if you hand scrape a single flat, you need another to compare it to. (using engineers blue.) If you scrape two, they end up matching but not necessarily flat. If you do three, and keep comparing A to B, B to C, and A to C, then eventually they all end up flat. This also applies to straight edges, so you can make an accurate straight bed with enough patience.
Then we will want a leadscrew. One technique is to draw some wire through a diamond die, which can give you a nice long length of wire of a consistent diameter. This is then wound around a mandrel which you have turned parallel. As implied by others above, this can be done by hand turning between centres. Then wind the wire around the long mandrel, and now you have a leadscrew. Coat it with some graphite and cast a lead nut around this, then use it to make a master leadscrew quick before you wear it out. As mentioned above, you can also correct errors in a leadscrew if you have the means to determine what they are.
If you can get hold of the Gingery books, they give quite a lot of information about how you can make a set of machine tools without having access to other machine tools. The problem with using other machine tools to make the new ones is of course that usually the new machine will be smaller than the one you have, when the usual problem we have is that we want a bigger one.
The other useful thing to look at is the Handmaiden series in ME by Tubal Cain, where he built a stationary steam engine using nothing but hand tools.
regards
Bill Pudney29/10/2021 00:28:31
622 forum posts
24 photos
The concensus of the people that I used to work with, was that the accuracy achieved by a manual machine depended on the skill of the user, not so much on the machine. The accuracy achieved by an CNC machine was determined by the design of the machine, not so much on the user, or "button pusher" in the cruel parlance sometimes used by those who should know better.
Obviously as with all sweeping generalisations this is open to debate!!!!!
cheers
Bill
Howard Lewis29/10/2021 06:53:15
7227 forum posts
21 photos
The very first lathes were probably made using purely manual methods.
Having produced a crude lathe, it would have been used to make a second generation none, of greater accuracy based on the skill of the operator.
The first shaft would have been filed or chiseled as round as possible, The work produced from that machine would have been "rounder" and less tapered, so could then be used to turn ODs and bores more accurately than by hand.
Re iterating this, MANY times, results in the machines that we and industry use today. Obviously industrial machine are heavier, more rigid and more consistently accurate than our hobby machines. They are vastly more expensive!
That is not to say that hobby machines cannot produce accurate work. It may result in more scrap before the operator produces the desired degree of accuracy, but bit can be done if the operator has the skill and patience.
Oily Rag29/10/2021 07:43:42
550 forum posts
190 photos
I endorse Michael G's post above - a very good question!
JA's post to look up the life and work of Henry Maudsley is a good starting point. The follow up to that would be to visit the Birmingham Centre Point which hopefully still has Joseph Whitworth's first lead screws, all three of them, (made from three screws hand chiselled and filed then each fitted to a lathe to remove error in the time old A-B, B-C, A-C. Don't bet on it though as some significant exhibits haven't seen the light of day for years!
A word here about what used to be the Birmingham Science Museum, now partially housed in the Centre Point building alongside City of Birmingham University (note: Not Birmingham University - that's in Edgbaston ). This facility is a shadow of the old Museum and some of that is down to its juxta-positioning to the C-o-B Media Studies and Performing Arts faculty next door. It has been dumbed down to now little more than a TV screen which alongside the exhibits does nothing to inform you of the object but rather berates the social injustices perpetrated on the 'victims' of capitalism forced to work in dingy work places!
As for more modern examples, when I was an apprentice at AH Ltd,. I worked on a Cincinnati vertical mill which had been fished out of the hold of the ship bringing it from the USA in 1941 (the ship had been sunk in Liverpool docks ) It had so much wear having been flogged to death by day and night shifts that the only way to accurately use it was by use of dial indicators and dead length bars (an early version of DRO, but actually ARO! ). This machine was used almost exclusively for 'fitters returns' where we 'fettled' parts which would not fit correctly due to some error. It often included easing a gearbox mating face by '0 thou, 3 thou, 8 thou, and 2 thou on the 4 corner mating edges. Another job was a lengthened leadscrew for a special machine which needed an extension shaft which had also to run in a housing at the point of the join - this meant the shaft had to be 'tongued and grooved' to an accuracy of 2 tenths of a thou runout between the two components.
I got a bar of chocolate off the foreman for that job.
The other machine I worked on was a No. 16 Universal which was part of an order in 1916 for Tsarist Russia, it had been rejected by the Russian on site Inspectors as being out of limits, so in Herbert tradition was put to work in making parts for there own machine tools! One component was the intricate drum cams for the cam auto machines Herbert's made. Backlash was eliminated by a wire rope and a sack of scrap iron hanging over a roller at the end of the table.
Martin
Edited By Oily Rag on 29/10/2021 07:51:48
Michael Gilligan29/10/2021 10:58:25
23121 forum posts
1360 photos
If you want a particularly good example of ‘making something more accurate than the tools you are using’ … read about Jesse Ramsden’s creation of the Dividing Engine.
It is inspirational.
Martin Kyte29/10/2021 11:32:14
3445 forum posts
62 photos
Yes.
As an aside George Thomas stated that accurate work can be produced on a worn lathe provided you know what the shortcoming are and act accordingly.
regards Martin
larry phelan 129/10/2021 16:43:39
1346 forum posts
15 photos
Oily Rag, I seem to remember that trick of the cord and the weight from somewhere else, dont remember where, but I did use it.
Howard Lewis29/10/2021 17:03:01
7227 forum posts
21 photos
A weight on a string wrapped around a suitable round component is a usual way of either taking up backlash or measuring torque to rotate, such as when preloading bearings in a Headstock or the differential for a vehicle.
At one company where I worked Torque Wrenches were checked by hanging weights on a hanger on a thin wire around a 24" diameter pulley, to give a direct reading.of lb ft.
Henry Bainbridge29/10/2021 17:20:12
16 forum posts
Posted by Michael Gilligan on 28/10/2021 20:16:16:
I wasn't even expecting an answer, and I got more than I have ever had on a forum anywhere. Looks like its alive and kicking yes thanks everyone.
Henry Bainbridge29/10/2021 17:47:16
16 forum posts
Posted by John P on 28/10/2021 21:25:18:
I am not sure what you mean by incorrect. I posed a recursive question deliberately because AFAIK there are some parts of a lathe that can only be made by a lathe and I wondered how that can be. I take your point though, so for the sake of argument let's say the thought experiment is about how some tools are recursive in nature, and that being so, how accuracy comes about.
Henry Bainbridge29/10/2021 17:50:30
16 forum posts
Posted by JA on 28/10/2021 22:51:23:
Henry Maudslay.
JA
Googled Maudsley, wondered where you were going with that. Re-googled Maudslay with an A, faith restored. Thanks for the tip.
Henry Bainbridge29/10/2021 18:38:27
16 forum posts
Posted by John Olsen on 29/10/2021 00:17:57:
OK that makes sense, so accuracy comes about by iteration, comparison and as Bazyle says, averaging.
That reminds me of a ballscrew I have that seems to be a track wound around a shaft, rather than being cut into it like a thread. Seems pretty accurate!
Thanks I will try and hunt them down.
Henry Bainbridge29/10/2021 18:40:15
16 forum posts
Posted by Bill Pudney on 29/10/2021 00:28:31:
This is encouraging
