Member postings for Henry Bainbridge
Here is a list of all the postings Henry Bainbridge has made in our forums. Click on a thread name to jump to the thread.
Thread: Is it possible to machine a lathe more accurate than the one you machine it on? If so, how?
01/11/2021 11:19:49
Posted by John P on 31/10/2021 16:50:21:
Getting back "How did you know"
Your posting here 28/10/2021 19:33:03
The relevant bit i have put in brackets.
Hi there, just posting so I can see classifieds.
I will stop by again (if I get a lathe), and I have
some genuine queries
D'0h! You got me!
31/10/2021 16:06:18
Posted by Chuck Taper on 30/10/2021 10:40:07:
The following, perhaps not directly relevant to OP, but......etc.
The machine that made everything.
FC
It's a piece of the puzzle, and it led me to this one: https://www.youtube.com/watch?v=gNRnrn5DE58 another good video from Machine Thinking to go with the one John P referenced, all about the origins of precision
31/10/2021 14:21:36
Posted by John P on 30/10/2021 11:50:29:
Whilst the OP was just getting enough postings just to look at the classifieds
and has yet to get a lathe and asked the opening question.
Hey! How did you know I don't have a lathe? The pedant in my says actually I have owned and operated a lathe every day of my working life for the last 18 years, albeit a disc mastering lathe, so not quite the same thing I grant you, but still.
You are right though, I don't have a lathe yet, hence my visit to the classifieds, but I am not a total novice when it comes to metalwork lathes either, I learnt on a Colchester Student (I think) at school back in the 1980s as well as a woodworking lathe I don't recall. Incidentally I came across this photo of the wood workshop at my school (in the 1940s I am guessing?), it had the same benches I used! https://images.app.goo.gl/DHLLz81mUnf7K8ht5
Anyway, back to the matter. I spend several hours a day using a lathe that can turn at precisely 33.33rpm across the entire face of a disc for 20+ minutes, while varying the pitch to keep the grooves as close together as possible, without so much as kissing each other (let alone twining). Bearing in mind the grooves are rarely wider than 100 microns (50 deep), the amplitude of the signal is constantly varying with >60dB of range and comprises two orthogonal forces being exerted on the disc at the same time. Added to that, if you speak too loudly next to the lathe when its running, your voice will be transferred onto the disc, so the lathe must operate as close to silent as possible. And you only have one pass per side. A mistake on either side means you have to bin the whole disc.
I wonder if that qualifies as not sitting in an armchair?
How that machinery is made is an exquisite problem I can't help wondering about, and I often come across this forum when looking for answers, so I can assure my interest in accuracy is not just a vehicle to seeing the classifieds.
31/10/2021 13:07:56
Posted by Michael Gilligan on 29/10/2021 19:41:23:
Whilst you were posting that, Henry … I was digging through some old posts of mine, and unearthed this from 2012:
__________
The full text of Jesse Ramsden's paper is available here: **LINK**
and an excellent commentary, here: **LINK**
Both thanks to the expert Mr Morris
___________
These may or may not be the same links that you found yourself, but I’m mentioning them anyway in case anyone else is interested. You will discover that various aspects of ‘Dividing’ feature quite frequently on this forum.
Yes, that's the one, I was going to point out the broken link, but see you already did that.
I found a really nice high-res copy of the illustration in a Sotheby's auction (now printed on A3 for the wall).
https://www.sothebys.com/en/auctions/ecatalogue/2018/the-library-of-erwin-tomash-l18409/lot.539.html
29/10/2021 19:23:32
Posted by Michael Gilligan on 29/10/2021 10:58:25:
If you want a particularly good example of ‘making something more accurate than the tools you are using’ … read about Jesse Ramsden’s creation of the Dividing Engine.
It is inspirational.
That is really fascinating. The wikipedia page doesn't actually say how it works, but luckily I found a .pdf online of the original 18th-century description by the man himself. In order to get his share of the longitude prize, he had to share how it worked, so its good to see he is still true to his word
29/10/2021 18:52:13
Right, now to check out the classifieds
29/10/2021 18:50:53
Posted by Howard Lewis on 29/10/2021 06:53:15:
The very first lathes were probably made using purely manual methods.
Having produced a crude lathe, it would have been used to make a second generation none, of greater accuracy based on the skill of the operator.
The first shaft would have been filed or chiseled as round as possible, The work produced from that machine would have been "rounder" and less tapered, so could then be used to turn ODs and bores more accurately than by hand.
Re iterating this, MANY times, results in the machines that we and industry use today. Obviously industrial machine are heavier, more rigid and more consistently accurate than our hobby machines. They are vastly more expensive!
That is not to say that hobby machines cannot produce accurate work. It may result in more scrap before the operator produces the desired degree of accuracy, but bit can be done if the operator has the skill and patience.
Interesting to note that things tend to get more accurate the more times you repeat them. It seems that the key to making that happen is to keep making more tools, not just more things with the tools you have.
29/10/2021 18:47:01
Posted by Oily Rag on 29/10/2021 07:43:42:
I endorse Michael G's post above - a very good question!
JA's post to look up the life and work of Henry Maudsley is a good starting point. The follow up to that would be to visit the Birmingham Centre Point which hopefully still has Joseph Whitworth's first lead screws, all three of them, (made from three screws hand chiselled and filed then each fitted to a lathe to remove error in the time old A-B, B-C, A-C. Don't bet on it though as some significant exhibits haven't seen the light of day for years!
A word here about what used to be the Birmingham Science Museum, now partially housed in the Centre Point building alongside City of Birmingham University (note: Not Birmingham University - that's in Edgbaston ). This facility is a shadow of the old Museum and some of that is down to its juxta-positioning to the C-o-B Media Studies and Performing Arts faculty next door. It has been dumbed down to now little more than a TV screen which alongside the exhibits does nothing to inform you of the object but rather berates the social injustices perpetrated on the 'victims' of capitalism forced to work in dingy work places!
As for more modern examples, when I was an apprentice at AH Ltd,. I worked on a Cincinnati vertical mill which had been fished out of the hold of the ship bringing it from the USA in 1941 (the ship had been sunk in Liverpool docks ) It had so much wear having been flogged to death by day and night shifts that the only way to accurately use it was by use of dial indicators and dead length bars (an early version of DRO, but actually ARO! ). This machine was used almost exclusively for 'fitters returns' where we 'fettled' parts which would not fit correctly due to some error. It often included easing a gearbox mating face by '0 thou, 3 thou, 8 thou, and 2 thou on the 4 corner mating edges. Another job was a lengthened leadscrew for a special machine which needed an extension shaft which had also to run in a housing at the point of the join - this meant the shaft had to be 'tongued and grooved' to an accuracy of 2 tenths of a thou runout between the two components.
I got a bar of chocolate off the foreman for that job.
The other machine I worked on was a No. 16 Universal which was part of an order in 1916 for Tsarist Russia, it had been rejected by the Russian on site Inspectors as being out of limits, so in Herbert tradition was put to work in making parts for there own machine tools! One component was the intricate drum cams for the cam auto machines Herbert's made. Backlash was eliminated by a wire rope and a sack of scrap iron hanging over a roller at the end of the table.
Martin
Edited By Oily Rag on 29/10/2021 07:51:48
OK I definitely need to find out more about this A-B, B-C, A-C idea. Seems like this thought experiment is throwing up some good general advice about how to do accurate work. Where there is a will there is a way!
29/10/2021 18:40:15
Posted by Bill Pudney on 29/10/2021 00:28:31:
The concensus of the people that I used to work with, was that the accuracy achieved by a manual machine depended on the skill of the user, not so much on the machine.
This is encouraging
29/10/2021 18:38:27
Posted by John Olsen on 29/10/2021 00:17:57:
Maybe worth mentioning a couple of techniques.
Accurate flats and straight edges can be made by making three at a time. if you hand scrape a single flat, you need another to compare it to. (using engineers blue.) If you scrape two, they end up matching but not necessarily flat. If you do three, and keep comparing A to B, B to C, and A to C, then eventually they all end up flat. This also applies to straight edges, so you can make an accurate straight bed with enough patience
OK that makes sense, so accuracy comes about by iteration, comparison and as Bazyle says, averaging.
Then we will want a leadscrew. One technique is to draw some wire through a diamond die, which can give you a nice long length of wire of a consistent diameter. This is then wound around a mandrel which you have turned parallel. As implied by others above, this can be done by hand turning between centres. Then wind the wire around the long mandrel, and now you have a leadscrew. Coat it with some graphite and cast a lead nut around this, then use it to make a master leadscrew quick before you wear it out. As mentioned above, you can also correct errors in a leadscrew if you have the means to determine what they are.
That reminds me of a ballscrew I have that seems to be a track wound around a shaft, rather than being cut into it like a thread. Seems pretty accurate!
If you can get hold of the Gingery books, they give quite a lot of information about how you can make a set of machine tools without having access to other machine tools. The problem with using other machine tools to make the new ones is of course that usually the new machine will be smaller than the one you have, when the usual problem we have is that we want a bigger one.
Thanks I will try and hunt them down.
29/10/2021 17:50:30
Posted by JA on 28/10/2021 22:51:23:
Henry Maudslay.
JA
Henry, sorry for the glib answer, just follow the name. [I don't usually post anything late at night].
Edited By JA on 28/10/2021 22:54:13
Googled Maudsley, wondered where you were going with that. Re-googled Maudslay with an A, faith restored. Thanks for the tip.
29/10/2021 17:47:16
Posted by John P on 28/10/2021 21:25:18:
"Is it possible to machine a lathe more accurate than the one you machine it on If so, how?"
I suppose the question here is posed incorrectly and perhaps should be.
Is it possible to produce a machine that will produce more accurate work
that the machine 's that it was made on.
If that is so then it is here is one
This cylindrical grinder was made in just that way ,the cylindrical square here
held between centres is within 1 um along the entire length and stands
square on a surface plate to within the thickness of 1 um clock gauge
indicator needle in any 4 places around the diameter.
As for the how, ME have had the construction article for the last 7+ years
or so if they haven't lost it again.
I am not sure what you mean by incorrect. I posed a recursive question deliberately because AFAIK there are some parts of a lathe that can only be made by a lathe and I wondered how that can be. I take your point though, so for the sake of argument let's say the thought experiment is about how some tools are recursive in nature, and that being so, how accuracy comes about.
29/10/2021 17:20:12
Posted by Michael Gilligan on 28/10/2021 20:16:16:
Thanks for actually contributing something to the forum, instead of just making dummy posts yes
I wasn't even expecting an answer, and I got more than I have ever had on a forum anywhere. Looks like its alive and kicking yes thanks everyone.
28/10/2021 19:38:50
Hi, just trying to get in to the classifieds, but thought I might as well ask, since its always intrigued me.
