DRO scale Modification
Me.18/09/2021 21:12:16
147 forum posts
30 photos
Finally i'm getting around to fitting my new DRO to my mill. The smallest scale I could buy for my Y axis was 300mm - It really needs to be 250mm and if it was it would fit on the table much easier without sticking out which could potentially get damaged.
Is it possible to cut the scale shorter - and if so can any of the knowledgable out there describe the method.
David George 118/09/2021 21:24:24
2110 forum posts
565 photos
What scale are you using is it a glass scale or magnetic. Make may help
David
Me.18/09/2021 22:11:38
147 forum posts
30 photos
Brought them from Chronos - there the Glass type - If I could reduce the length by 50mm it would fit so much easier.
DiogenesII19/09/2021 08:41:09
859 forum posts
268 photos
See this thread
Cutting down a glass DRO encoder..
elanman19/09/2021 08:41:49
47 forum posts
4 photos
I have shortened a glass scale, but not a chronos one so you may need to adapt the method.
On the end that you are going to chop off, remove the end piece. Slide the read head to the other end. Fill the scale with cotton wool or tissue to try and stop grinding dust into the read head. Slide this packing upto the read head making sure that it's past the cut point. Mark the cut point on the outside case of the scale. I used an angle grinder with a 1mm thick cutting disc. Cut it so that the glass is supported by the metal in the direction that you are going to cut. Then go for it. Take it easy and do not force it though.
Just stick the end piece back on with sealer.
Best of luck.
Cheers
Edit , I see some has typed faster than me and posted a better desciption with pics.
Edited By elanman on 19/09/2021 08:45:15
Me.19/09/2021 09:33:09
147 forum posts
30 photos
Great - thanks all for the Link and the shorter description elanman - I think I will give it a go....... Maybe..... ?
Bizibilder19/09/2021 10:01:24
173 forum posts
8 photos
Have a look on Youtube - there are several videos. Have a look at a few of them and you should find a method that suits you and your available tools.
Edited By Bizibilder on 19/09/2021 10:03:19
not done it yet19/09/2021 10:09:26
7517 forum posts
20 photos
Get advice from Chronos?
Dave Halford19/09/2021 12:15:21
2536 forum posts
24 photos
There is no need to leave the read head on, they are easy enough to re fit.
I assume you have checked that the head still has enough travel, some heads need 75mm total extra travel more than the read distance. In other words if your table travel is 250mm the scale must be 325mm long.
A 50mm diamond disc in an ordinary hand drill will cut the glass, the 25mm size are too small to reach all of an angled glass scale.
Me.19/09/2021 13:09:50
147 forum posts
30 photos
Thanks for the reply. Yes I’m pretty sure if my measurements and 50mm off the end will make it much more usable.
my glass strip is vertical in its slot and not angled like the ones in the YT videos. But I’m sure that won’t make a difference.
Dave Halford19/09/2021 15:33:08
2536 forum posts
24 photos
Posted by Me. on 19/09/2021 13:09:50:
The vertical ones are easier to do smiley
