It would be nice to know........
Me.09/09/2021 09:46:57
147 forum posts
30 photos
Why does a milling machine have a reversing motor.... I can't see any reason why I would run the spindle on mine in reverse, but what do i know......
I'm sure there is some logical reason or am i just missing something obvious.
David Colwill09/09/2021 09:51:02
782 forum posts
40 photos
When power tapping would be the obvious one.
Regards.
David.
Nicholas Farr09/09/2021 09:54:06
3988 forum posts
1799 photos
Hi Me., slitting saws and other similar types of cutters can be used in either direction, is one example, left hand drills and taps another.
Regards Nick.
Martin Whittle09/09/2021 09:54:27
102 forum posts
12 photos
So you can use a left hand drill bit to drill out broken or damaged screws - it can help to 'unstick' the screw from the hole.
For when you have fitted the slitting saw the wrong way round frown
Michael Cox 109/09/2021 10:01:01
555 forum posts
27 photos
I usually run the cutter backwards in order to locate the edge on the material to be machined. Running the cutter backwards does not remove any metal and give a very clear audio indication when the rotating cutter touches the edge.
Andrew Johnston09/09/2021 10:10:09
7061 forum posts
719 photos
All my milling machines have reverse and all the above apply. I use reverse for tapping on the CNC mill. I have reversing tapping heads for the vertical mill, although I have used reverse and handraulic control when It wasn't worth setting up a tapping head. I also use reverse on the vertical and horizontal mills depending upon which way it is convenient to run cutters and boring heads, like this:
My vertical mill has a single stage backgear reduction, so to keep tool rotation the same the motor needs to run in reverse when backgear is engaged.
Michael Gilligan09/09/2021 10:36:09
23121 forum posts
1360 photos
… for spot-facing/counter-boring a lower surface, using a left-hand tool and ‘pulling’ in Z
Bo'sun09/09/2021 10:44:56
754 forum posts
I think you need to consider cutter heads, that have "screw on" arbours. Running in reverse may cause them to unscrew.
John Haine09/09/2021 10:48:13
5563 forum posts
322 photos
As Andrew says, for tapping - most of my tapping is now done on the manual mill using the VFD to reverse the tap out of the hole at low speed.
And the Hemingway speed increaser kit to improve usage of small cutters in normal mills also reverses the direction, so you need to run the main spindle in reverse.
Dave S09/09/2021 12:53:31
433 forum posts
95 photos
Last time I used mine in reverse was when I accidentally made a left handed cutting tool to create the spaces on an escape wheel.
Didn't realise I had it reversed until I got the whole thing setup in the mil and ready to run - then a bit of a 'hang on... something is not right here' moment.
Glad to have reverse for that - the cutter took a while to make.
Mark Simpson 109/09/2021 14:55:40
115 forum posts
30 photos
All bridgeports and clones motors have to run in reverse when in low gear... You would have thought than an idler somewhere would have been cheaper than the switch gear; but that's how they are...
Andrew Johnston09/09/2021 15:01:58
7061 forum posts
719 photos
Posted by Mark Simpson 1 on 09/09/2021 14:55:40:
You would have thought than an idler somewhere would have been cheaper than the switch gear......
An OTS switch is way simpler and, cheaper, than trying to fit an idler into the head, especially without making the head bigger. Why do import lathes/mills use variable speed drives? Not because they're inherently better but because electronics is way cheaper than gears or belts and pulleys.
Mick B109/09/2021 17:13:34
2444 forum posts
139 photos
The obvious reason - apart from tap reversing and LH threads - is that the machine is intended as a general purpose resource where the maker can't realistically anticipate all the purposes the end user may put it to.
Reversing motors are easily available - it would simply be unnecessarily restrictive not to fit one.
