sources
brian jones 11 | 18/08/2021 21:44:41 |
347 forum posts 62 photos | Does anyone know of a source of short toothed (cogged) belts suitable for a lead screw drive. I thought this would be a simple Ebay search but spent an hour to no good result Maybe I am using the wrong keywords? Any ideas pls Brian |
Howard Lewis | 18/08/2021 21:51:20 |
7227 forum posts 21 photos | Suppliers of "pulleys" for cogged belts, such Davall Gears, Reliance Gears, HPC Gears etc? Howard |
Manofkent | 18/08/2021 21:58:28 |
145 forum posts 29 photos | If it is a cnc belt have a look at cnc4you webpages. There is a lot of info, they sell belts and pulleys.
John |
V8Eng | 18/08/2021 21:59:52 |
1826 forum posts 1 photos | simplybearings.co.uk are worth checking out for those. |
Emgee | 18/08/2021 22:20:53 |
2610 forum posts 312 photos | +1 for Simply Bearings Emgee |
Paul Lousick | 19/08/2021 00:03:01 |
2276 forum posts 801 photos | Try searching for timing belts. I just did a search on ebay for 16mm (and 20mm) timing belts and found dozens of examples of belts and pulleys. Paul |
DC31k | 19/08/2021 06:20:36 |
1186 forum posts 11 photos | It is not clear from your post whether you want belts that run on smooth pulleys (known as asynchronous) or belts that run on toothed pulleys (known as synchronous). A good place to start to survey the market is manufacturer's websites: Gates (not Gareth or Bill), Fenner (not Dave or Keith), Mitsuboshi (sic, not the car maker). |
Paul Lousick | 19/08/2021 07:36:28 |
2276 forum posts 801 photos | The question was for a " toothed (cogged) belt suitable for a lead screw drive". I would assume (I know, should never do that) that it is not for a smooth pulley. All of the electronic lead screw projects that I have seen use a timing belt, especially if used with a stepper motor for CNC. |
not done it yet | 19/08/2021 08:13:24 |
7517 forum posts 20 photos | There is one on my Bosch PHO 2-82 planer. I’ve only needed to change it once in about 30 years of ownership. |
Mike Poole | 19/08/2021 09:53:20 |
![]() 3676 forum posts 82 photos | I often use Bearing Boys for belts of all sorts, what you are looking for are timing belts which they list under transmissions. I wanted a smaller belt than the range they supply for the encoder drive but I got the belt and pulleys from them for the stepper drive. I have no connection other than a satisfied customer with the company. Service has been prompt and although I have not chased the absolute lowest price for items I have found their prices very acceptable. Mike |
brian jones 11 | 19/08/2021 10:05:38 |
347 forum posts 62 photos | Posted by Manofkent on 18/08/2021 21:58:28:
John thats more like it, they sell the SS belt and the sprocket (small 1" dia) presumably one would need to make a larger driven wheel say 75mm dia oneself hmm another chalenge would one calculate the pcd and drill a set of teeth with a 5mm drill (or less probably) in an ally blank probably be noisy I will have to check torque requirements Bed speed I think a max of 3" per min down to say 0.3/min (must recheck) so 10 tpi gives 30 rpm max on the lead screw. |
JasonB | 19/08/2021 10:14:32 |
![]() 25215 forum posts 3105 photos 1 articles | Why would you need to make the 75mm pulley when they are available, something like this for XL size belts or this for T5 size belts and just modify to suit though you could make if you wanted to but you don't seem too keen to do that. Not sure where you get your max an min bed speeds from but the minimum on mine is more like 3" and the max something like 12-15" ideal for rapid return and my spindle speeds are not any higher than yours. Simple way to work out what you need is to mount up a cutter and a bit of metal and mill it, make a note of how many times you turn the handwheel in 60secs to get rpm, Unlikely you take 20seconds to do one revolution unless you have something seriously wrong with your chip loading. Edited By JasonB on 19/08/2021 10:18:36 |
John P | 19/08/2021 10:23:37 |
451 forum posts 268 photos | If you are able to find a copy of MEW 164 there is an article in there "form John |
John Haine | 19/08/2021 10:25:05 |
5563 forum posts 322 photos | RS and Farnell/CPC |
brian jones 11 | 19/08/2021 10:40:18 |
347 forum posts 62 photos | Thnx JB as you can see I was looking in the wrong place with the wrong keywords - its in the aesthetic world of CNC and timing belts etc. but prices I saw for large driven cogs were silly money for a hobbyist £50 Industrial suppliers will also have unaffordable prices.
so a new door has opened for me and I have acquired an electric window assy for a tenner - well its a start and I agree that going to stepper motors really is overkill for this duty. |
Trevor Drabble | 19/08/2021 12:48:31 |
![]() 339 forum posts 7 photos | SHG Marine supply many items for model boats , including XL belts and pulleys , all at reasonable prices . No connection with company other than as a satisfied customer . |
Nick Hughes | 19/08/2021 15:33:49 |
![]() 307 forum posts 150 photos | Another supplier that I've used quite a few times is Belting Online Always had good service from them. |
John Hinkley | 19/08/2021 16:21:28 |
![]() 1545 forum posts 484 photos | I've just stumbled upon this thread and, like Nick Hughes, I been using Belting Online for all my belt and pulley purchases. Their prices are what I consider very reasonable and delivery is as quick as 2nd class postie takes. I'm using a 60 tooth XL pulley on the leadscrew driven by a 20 tooth on the servo motor. The spindle encoder doesn't take much in the way of torque, so I've settled for 26 tooth pulleys and HTD3 belting, 9mm wide. John
