Rich2502 | 26/05/2021 13:19:23 |
83 forum posts 3 photos | I want to cast some new copper inserts for my copper faced hammers, how can I make a mould from easily available materials for just a one time basic casting?
JasonB | 26/05/2021 13:23:06 |
![]() 25215 forum posts 3105 photos 1 articles | Bit of tube cut in half and hold together with Jubilee clips would make it easy to get apart. |
Ady1 | 26/05/2021 14:16:57 |
![]() 6137 forum posts 893 photos | Now that you mention it I have never ever read or heard about anyone casting copper All sorts of other stuff yes |
not done it yet | 26/05/2021 14:21:35 |
7517 forum posts 20 photos | Plural ‘inserts’ and one time casting does not equate too well. Better cast in situ, I might think? |
Dave Halford | 26/05/2021 14:43:31 |
2536 forum posts 24 photos | You don't say which hammer, but for example a 1&3/4" copper head insert is £6 +vat. Why bother? |
robin coleman | 27/05/2021 06:20:27 |
18 forum posts | You could make them by copper spinning method and fill with molten lead.
Simon Williams 3 | 27/05/2021 16:23:00 |
728 forum posts 90 photos | I tried this experiment, and found (thanks to a similar question here) that the cast head of the hammer is crimped around the copper insert to hold it in place. Being cast, it's not malleable, so the crimp is a one time event, and the edges of the socket are liable to split if you try and ease them out enough to allow a new insert to be (ahem) inserted. So I cast lead inserts in situ. Here's a link to the escapade in question: |
John Haine | 27/05/2021 19:51:51 |
5563 forum posts 322 photos | Use copper tube for the mould? Becomes part of the end product. |
Luker | 28/05/2021 07:19:46 |
![]() 230 forum posts 172 photos | I would push a bar of the correct diameter in some sand and cast as normal. Copper tends to react with oxides so casting into any pipe needs to be done with the pipe very clean, and don't stand over the pipe when casting. Once poured, cover the top of the copper with coal dust, otherwise it "boils". Sand mix: 3% water 10% bentonite (from beauty shop-face mask) 5%coal dust 5%starch (cake flour) rem sand With such a simple mould you'll probably get away with 3% water and 10% starch (rem sand) I'm surprised copper isn't cast more often, a number of the older models had copper chimney stacks... |
noel shelley | 28/05/2021 09:55:41 |
2308 forum posts 33 photos | Casting a new copper head into the old iron holder would work BUT only if the hide face was removed and also the wooden handle. I have never successfully fitted a new copper face - even though you can buy them ! IF you are menting copper start with a handful of charcoal in the crucible as a deoxydiser, then melt as normal, for the mold allow 1/16" for shrinkage on diameter, or heavily rap the pattern before removing from the sand mold. Luker has given a mix for the sand. Good luck. Noel. |
