John Smith 47 | 05/05/2021 18:14:31 |
393 forum posts 12 photos | Hello A) and
Edited By John Smith 47 on 05/05/2021 18:14:50 Edited By John Smith 47 on 05/05/2021 18:15:24 |
bernard towers | 05/05/2021 18:34:47 |
1221 forum posts 161 photos | Why not drill the handles of photo 1 and fit a threaded bar arrangement or a cam? |
DC31k | 05/05/2021 18:34:57 |
1186 forum posts 11 photos | Please see if any of these come close to your requirements. The last one in the list is stretching the specification a little. https://www.toolsntoolsuk.co.uk/shop/parallel-action-locking-pliers-jewelry-craft-hand-vise-smooth-flat-brass-jaws-6/ https://www.misterworker.com/en-gb/stahlwille/parallel-jaw-self-grip-wrench-6562/8994.html https://www.tooltique.co.uk/shop/vintage-speetog-parallel-jaw-adjustable-locking-plier-clamp-good-condition/ https://www.riogrande.com/product/swanstrom-self-locking-parallel-action-pliers/111649 https://www.cromwell.co.uk/shop/hand-tools/locking-pliers-and-grips/255mm-10inch-parallel-plus-grip-wrench/p/KEN5587250K |
Ady1 | 05/05/2021 18:35:42 |
![]() 6137 forum posts 893 photos | If you get stuck then compress two 3mm plates in molegrips and tack weld them on |
Martin Connelly | 05/05/2021 18:39:04 |
![]() 2549 forum posts 235 photos | Deleted because I typed a bit slower than others. Martin C Edited By Martin Connelly on 05/05/2021 18:39:57 |
Brian H | 05/05/2021 18:47:07 |
![]() 2312 forum posts 112 photos | I have a couple of parallel jawed pliers that lock onto the item being gripped. They are called Speetog plier clamps and they look like this; The screw on top closes the jaw and determined the amount of holding force. They don't appear to be made any more but sometimes turn up on ebay etc. Brian |
Clive Foster | 05/05/2021 19:02:14 |
3630 forum posts 128 photos | I've had a CK Parallel-Grip Perfect for many years which does have true parallel jaw movement but only a sliding sleeve to set size relying on friction to hold it in place. Grip is decent but not as good as the real thing. Appears to be discontinued. The Stahlwille 65622250 in the misterworker link from DC31k has the same pivot geometry so should be properly parallel. Geodore do a similar one as type 137 P with, apparently the same pivot arrangment. Looks to be a bit more expensive than the Stahlwille. The one in the Cromwell link isn't parallel grip. The general give-away for parallel action is three visible pivots arranged in a triangle. One on the handle, one on the jaw and one on the body. There is a forth pivot hidden inside that just peeks into view when fully open. The ordinary, arcuate opening type only have two visible pivots. One on the handle and one on the body, both passing through the jaw forging. Clive |
Robin Dufton | 05/05/2021 19:12:59 |
38 forum posts 10 photos | Posted by bernard towers on 05/05/2021 18:34:47:
Why not drill the handles of photo 1 and fit a threaded bar arrangement or a cam? That would be an expensive and elaborate toolmakers clamp. We have some of these hanging around for clamping sheets and blocks together for marking out and drilling. https://www.diy.com/departments/magnusson-20mm-spring-clamp/1782641_BQ.prd |
John Smith 47 | 05/05/2021 22:28:24 |
393 forum posts 12 photos | I may well be incorrect, but I am pretty sure that none of the products linked to involve genuinely parallel jaw movement. My original image A) does have genuinely parallel jaw movement because it has FOUR pivot points when are arranged parallel to each other in a rectangular/square design. All the other product seem to have jaws in fact rotating around a pivot point. Although the impact may be subtle, at different degrees of jaw opening there amount of pressure on the part will be different at one end of the part compared to the other end of the part. Either way, in order to minimise damage to the part I would like flat, not toothed jaws.
Either way I just don't like those teeth. But maybe one could get soft jaws for it. (Or yes, build if I have to!)
Edited By John Smith 47 on 05/05/2021 22:53:20 |
Michael Gilligan | 05/05/2021 23:13:34 |
![]() 23121 forum posts 1360 photos | Posted by John Smith 47 on 05/05/2021 22:28:24:
. . You might find this review video of interest: **LINK** https://youtu.be/QEEcppQYqPs MichaelG. . ... and here’s a patent from 1945: https://www.datamp.org//patents/displayPatent.php?pn=2388580&id=13778 ... I wonder if anyone is still making that design Edited By Michael Gilligan on 05/05/2021 23:22:13 |
John Smith 47 | 05/05/2021 23:26:15 |
393 forum posts 12 photos | Btw, what do you think would happen if they fused Part A with Part B? |
John Smith 47 | 05/05/2021 23:57:10 |
393 forum posts 12 photos | @MichaelG - yes, I found that video too. |
Pete. | 06/05/2021 00:07:25 |
![]() 910 forum posts 303 photos | What are you intending to hold, and what do you intend to do with the part once its held in your parallel hand clamp? |
Pete. | 06/05/2021 00:35:41 |
![]() 910 forum posts 303 photos | Without knowing what they're for it's hard to know what is suitable, when you're asking for very specific tools, you should give the very specific use so people can understand what you're trying to do. These two pictures sound like what you are describing. Also knipex pliers wrench close completely parallel, and the jaw force is magnified ten fold from how hard you squeeze the handles, they're like a hand held vice, I use them for squeezing things together. |
Michael Gilligan | 06/05/2021 07:16:21 |
![]() 23121 forum posts 1360 photos | Posted by John Smith 47 on 05/05/2021 23:57:10:
. […] . ... then I am surprised by your musings of 23:26:15 MichaelG. |
DC31k | 06/05/2021 07:34:50 |
1186 forum posts 11 photos | There are very subtle distinctions in the mechanisms above. Some have parallel jaws; some have parallel action; one (the original photo) has, for want of a better term, perpendicular approach. With parallel jaws, at any one point (i.e. when they are gripped onto the object), the jaws are parallel. As they move towards this point, the jaws may not move perpendicular to each other. All the ones above have this function. With parallel action, the jaws stay parallel to each other while they are moving. The first one in the original post and the Stahlwille one have this function, as does anything with pivoting jaws. With perpendicular approach, the jaws do not translate laterally as they close (so they are just like a vise). Only the first one does this. Please consider the possibilities of these: https://www.toolsntoolsuk.co.uk/shop/140-mm-side-screw-parallel-action-flat-nose-nylon-jaws-pliers-jewelry-extra-jaws/ The adjustment screw on them means that the distance between the ends of the handles can always be the same no matter what thickness they are gripping. You would have to make a locking device, but that can be as simple as a loop of metal, similar to that used by blacksmiths for a tong lock. |
Clive Foster | 06/05/2021 08:08:18 |
3630 forum posts 128 photos | John The Stahlwille and Geodore products have the same mechanism as may CK ones. The slight shear movement is an inevitable consequence of finite, relatively small, distances between the pivots. The shear is not an issue in practice because the actual movement between a firm touch when the jaws start to grip and clamp is small. The slight slack in the pivots needed for free movement also tends to compensate. Fundamentally a bodgers tool. By the time mine come out I'm usually past caring about small marks on the job. Stilsons are the next step! Assuming they are the same size as mine there are no strength issues. These things are significantly bigger and considerably heavier than the common Mole wrench. Maybe one and a half times as heavy as the equivalent size. Clive |
John Smith 47 | 06/05/2021 10:50:40 |
393 forum posts 12 photos | @Pete - It seems I wasn't clear enough. Like I say, the problem with all plier that have freely hinged jaw faces is that it is almost impossible to apply the same pressure to both end of the jaws at the same time. Indeed the ONLY way that you could achieve this would be to insert a part EXACTLY between the two hinges. i.e. You have to locate a part at Position A.
OK to put my quest another way, I would like to have "a hand tool that is a fine-nosed vice - with a true parallel jaw action, and no irritating protrusion near the business end". Probably not worth much more time thinking about this thread. Maybe what I seek hasn't been invented yet? Edited By John Smith 47 on 06/05/2021 10:51:32 |
Dave Halford | 06/05/2021 11:38:00 |
2536 forum posts 24 photos | Posted by John Smith 47 on 06/05/2021 10:50:40: Probably not worth much more time thinking about this thread. Maybe what I seek hasn't been invented yet? Edited By John Smith 47 on 06/05/2021 10:51:32 It does seem to be a common theme in your threads. Try to make one |
John Smith 47 | 06/05/2021 11:48:06 |
393 forum posts 12 photos | Posted by Dave Halford on 06/05/2021 11:38:00:
Posted by John Smith 47 on 06/05/2021 10:50:40: Probably not worth much more time thinking about this thread. Maybe what I seek hasn't been invented yet? Edited By John Smith 47 on 06/05/2021 10:51:32 It does seem to be a common theme in your threads. Try to make one Yes, when I have time, I shall. Edited By John Smith 47 on 06/05/2021 11:51:57 |
