Member postings for Robin Dufton
Here is a list of all the postings Robin Dufton has made in our forums. Click on a thread name to jump to the thread.
Thread: digi phase converter for 10 machines.....
02/10/2023 16:58:06
Posted by SillyOldDuffer on 02/10/2023 16:42:26:
One per machine VFDs are small, simple, cheap, and efficient but fitting 10 of them is a big job. Could be the right answer though.
On the low end one 3kw VFD is £300, for a sort of trusted brand, and I buy Eaton ones for ~£500. Eaton 550w VFDs cost me £110 a piece. So across 10 machines of varying power requirements you're well over half way to the British made 20hp phase converter. Add in enclosures, switches, cable and time, you're well down.
In 2019 the cost for three phase for us was £1400. £900 of that was the permits and permissions required to dig up a 300mm square bit of pavement at the edge of the property. I know it is now triple that as more and more people want it for EV charging.
02/10/2023 15:57:06
Why would you need a 20hp phase convertor if your largest machine is 4hp? The single phase supply you would need to run 20hp would likely raise more questions from the electricity board than what you would be doing with three phase. We recommend a 40A supply for when we supply machines running 5.5kw VFDs on single phase, and 20hp is pretty much three times that.
I know my house has a 100A supply, but I know new builds are lower, something like 63A rings a bell, so they would probably like to know why you would want a 100A supply. I'd go with the diesel generator suggestion if I needed that much beef and couldn't get three phase.
Thread: Coventry Diehead
03/08/2023 19:32:09
Posted by Baz on 02/08/2023 16:53:29:
Make them a bit slack and over the short length required you may get away with 5/32 x 40 ME. Easy enough though to screwcut, it going out to the workshop to check because it is chucking it down but I am sure Myfords QC box cuts 42 tpi.
If you're going to do that you might as well put an M4 tap in the hole and use M4 screws. Having had a 1/4 die head I can't see why the body would be hardened and prevent doing it.
Edited By Robin Dufton on 03/08/2023 19:33:30
Thread: Meddings Dril Tru - What to do?
30/07/2023 00:06:23
To drag up an old thread although it might help anyone searching for the same info.
I've rebuilt a few Meddings over the years and have found the spindle pulley from the generic Chinese 16 speed drills to be a close match to the LT and M2 pulleys. The bore is 24mm, so needs taking out, and a keyway needs cutting. Also the smallest step is the same size as the 2nd step on the Meddings and the top step is exactly the same, so the highest or lowest speed is a few percent out while the opposite end speed stays the same. They're also £8 from Machine Mart for the Clarke version and £15 for the Draper, depending on who has them in stock.
The generic type A pulleys don't fit under the cover as they're 80+mm. The 16 speed pulleys are a lot closer to the originals and just fit.
Edited By Robin Dufton on 30/07/2023 00:07:16
Thread: 2 Inch Ransomes
11/07/2021 07:23:36
Ok. I guessed there would have been more interest in this, especially the steel boiler to our design, as we must be doing something wrong. I guess we'll go back to building it behind closed doors.
Thread: advice old British motorcycle
07/07/2021 00:01:54
I've always liked the look of the Sunbeam S7 Deluxe for the American styling although they're over budget. £5k is a bit tight for a decent classic bike as even Noddy bikes are £2k. I have my well used RGV250 up for sale at the moment for £6k, and mint bikes are over £9k, as classic bikes prices are through the roof at the moment.
06/07/2021 15:26:31
We've been a bit light on progress recently as we've had a fair bit of work to get through. The last of the riveting. 700 rivets in total between the tender and belly tank.
Thread: Milling machines - western-made s/h recommendations up to £2k
04/07/2021 21:03:55
We've used Matt in the past to shift stuff and been very happy. https://www.1tonne.com/
You say it's 15' x 8' and have ruled out a large knee mill. The manual machine space in our workshop is that size and has two lathes, drill and a Bridgeport type mill. If the small lathe were gone you have bench space and our walkway is free space to put something like a saw. The mill cost considerably less than £2000 and is like new. It came from a company who repaired weaving looms that had shut down, and had spent it's life making small brass parts. Two of us moved it in our Transit van with an engine crane.
Thread: Fowler Build
27/06/2021 21:28:05
Posted by Paul Kemp on 27/06/2021 20:16:48:
Nice to see some common sense on stay spacing there Robin instead of the usual hysteria! As Jason said steel for the 3" for the OP makes far more sense than copper.
Paul.
There seems to be a lot of pearl clutching when it comes to steel boilers. I've seen it in old model engineering books that a steel boiler should be 1/4" thick with no evidence to back it up other than best guess or rule of thumb. Our boiler could be 0.27mm thick and take it's working pressure, plus 1mm for waisting, so 1.27mm total. 3mm is plenty. The ASME regs, which I found after doing my calcs and sending them to the boiler inspector, backed up my calcs.
The only thing the boiler inspector questioned was using 3mm thick steel for the firebox and he requested 4mm. I'm happy that 3mm would be fine, although it is 4mm as we're not going to argue or upset anyone, especially someone that experienced and helpful.
27/06/2021 15:34:20
Posted by JasonB on 27/06/2021 10:09:56:
The other advantage of going for steel is you can get the pressure up a lot higher which will help with the R3 being a compound.
When I did the calculations for the Ransomes boiler I also worked out the yield stress for Haining's copper design and it was below the 2x test pressure, something like 11bar without looking at my notes, vs 12 or so. The yield stress for my steel design is at 40bar and it would reach it's UTS at 70bar. At working pressure the sides between the stays moves outwards by 5 microns, it could have just about passed a 16bar 2x pressure test with no stays.
We settled on 8bar, even though it could have been run at 15-20bar, as we made the pump to his design so it seemed like a reasonable compromise and it is 30% higher than the copper design anyway. We could have redesigned the pump although we've changed enough of the design already.
Edited By Robin Dufton on 27/06/2021 15:35:58
26/06/2021 20:21:38
Tony Baldwin of AJB has retired and he was also Bell Boilers, as when I rang him the caller id said Bell Boilers. What scale is it?
Rather than worrying about leaks you should really focus on getting started. Things like that can be solved when it's finished. If you're doing it odd evenings and weekends you're a couple of years away from it being finished.
Edited By Robin Dufton on 26/06/2021 20:23:51
Thread: AEW VICEROY HORIZON MILLING MACHINE
18/06/2021 19:46:56
Posted by Roderick Jenkins on 18/06/2021 10:18:43:
It looks like the maximum speed of the mill is 3000rpm which is slightly faster than mine, so definitely worth a try.
I wouldn't bother without a spindle speeder and they do occasionally come up second hand. 3mm is pushing it on a manual mill, trying to cut with a 1mm cutter would be pissing in to the wind, but then people use face mills in little Chinese mill drills.
Thread: Calculating Diameter
12/06/2021 17:08:36
I guess you want to know the minor diameter. If it's metric just subtract the pitch. Pocket Ref
Thread: Best choice of material
11/06/2021 23:46:39
I've never understood this idea that top slides lack rigidity. There will be a screw to lock it against the gib strip. Take it out and replace it with a handle.
Thread: Cyclemaster engine rubber bushings
09/06/2021 21:42:02
Posted by J Hancock on 06/06/2021 13:45:50:
If you visit a decent electrical distributor , you should be able to buy a two-pack self-setting hard rubber compound that would do that job perfectly.
Potting compound wouldn't be ideal as it's often a hard setting epoxy.
We use this stuff for reproducing NLA rubber parts on vintage bikes, just pick a suitable hardness and make a mould. Give it a few days to cure and you're good to go. Link
One piece of advice with castable PU. To reduce the chance of getting bubbles when you mix the two parts, put the bottles in warm water before pouring it out.
Edited By Robin Dufton on 09/06/2021 21:44:01
Thread: Dividing head - Beval gear ?
08/06/2021 21:52:11
I remember reading something like the worms on small dividing heads and rotary tables are peened in the factory to reduce backlash, as they're too small to fit in any other way of eliminating it. Even with a new worm gear it may be more hassle than it's worth getting it set up correctly because of that.
If it's a well made unit from a decent company that has a few parts missing, and worth saving, there is the option of buying a foreign copy and stripping it for parts.
Edited By Robin Dufton on 08/06/2021 21:52:26
07/06/2021 16:15:32
More progress. Finished the rear wheels and crankshaft, just some tidying up to do on the counterweights from being laser cut. We also managed to work out a system for building the wheels and them ending up straight, unfortunately we only worked it out on the last one, so if the others don't look so brilliant when it's running we may redo them although they're all within 0.25mm in all directions.
Edited By Robin Dufton on 07/06/2021 16:19:18
Edited By Robin Dufton on 07/06/2021 16:19:37
27/05/2021 17:29:34
I can't see 4 inch steel tube in anything other than 1/2" wall thickness on there.
27/05/2021 16:13:19
Posted by br on 27/05/2021 16:03:40:
Bought my last lot of 4 inch from Joe at maccmodels . I see he has it in stock
Has always been helpful and will cut to non listed lengths
bill
Didn't think to ask one of the model suppliers. The fire tube material is coming from them so we should have asked about tube, although the only stuff I can see on there is 1/2" thick.
27/05/2021 15:24:42
Finally got all the bits together for the boiler. Getting 4 inch tube was an absolute nightmare.
