Blue Heeler | 29/03/2021 05:47:36 |
![]() 342 forum posts | My easy solution to No More Clogged Spray Paint Rattle Cans
not done it yet | 29/03/2021 08:40:39 |
7517 forum posts 20 photos | Isn’t the nozzle cleared by a quick press with the can inverted? |
Brian Baker 1 | 29/03/2021 09:02:40 |
![]() 229 forum posts 40 photos | Greetings, I find that the ball in the valve at the top of the can gets clogged. Regards BB |
mechman48 | 29/03/2021 12:07:01 |
![]() 2947 forum posts 468 photos | You can use mini paint spray gun thinners as well. George. |
CHAS LIPSCOMBE | 29/03/2021 14:37:26 |
50 forum posts 3 photos | A great solution that I will definitely try. My solution is less elegant but so far has worked for me, is that after clearing the nozzle by a quick press with the can inverted (which as Blue Heeler says does not work too well for long-term storage) is to push a fine wire into the spray hole and leave it there until the spray can is used again. I have kept a clapped-out wire brush for use as a fine wire donor. Chas |
Steviegtr | 29/03/2021 15:45:45 |
![]() 2668 forum posts 352 photos | I always use gun wash, which is a cheap cellulose thinner. Around a fiver for a gallon. Used for cleaning spray guns. Steve. |
bernard towers | 29/03/2021 23:45:41 |
1221 forum posts 161 photos | Let me know where you get it for a fiver a gallon |
Blue Heeler | 29/03/2021 23:59:04 |
![]() 342 forum posts | Posted by not done it yet on 29/03/2021 08:40:39:
Isn’t the nozzle cleared by a quick press with the can inverted? As explained in the video I spray lots of small parts. There's no way there's going to be enough propellent in the can to keep cleaning the nozzle by inverting it each time I spray something. |
Hopper | 30/03/2021 06:45:21 |
![]() 7881 forum posts 397 photos | My usual method is poking a bristle from a wire brush down the small spray hole and swearing a lot. |
Nicholas Farr | 30/03/2021 07:57:53 |
![]() 3988 forum posts 1799 photos | Hi, not so long ago, I had one of these rattle cans with zinc based paint for galvanise repairs / touch-up, and like has been said, very often was used just for one or two small areas to paint and although turning turning upside down each time, the nozzle blocked. After cleaning out the nozzle and trying again, it just kind of spat a few drops of paint and then stopped again, so I tried a brand new nozzle from an unused can and it still just spat a few drops and stopped. I think the can only had about a quarter of it's contents left but this paint was a bit pricy, so I was loathed to discard it, to cut a long story short, it turned out that it would only spray the paint when shook and then turned upside down and sprayed, but I only got short burst of spray each time and it never did spray the correct way up again, but at least the paint wasn't wasted, but seemed very strange why it wouldn't spray in the correct manner. Regards Nick. |
Blue Heeler | 30/03/2021 08:01:09 |
![]() 342 forum posts | Posted by Hopper on 30/03/2021 06:45:21:
My usual method is poking a bristle from a wire brush down the small spray hole and swearing a lot. G'day Hopper, been there mate as well. My swearing came from the next time I went to spray something though because of the big droplets coming out because I'd deformed the nozzle outlet with the wire |
IanT | 30/03/2021 10:54:37 |
2147 forum posts 222 photos | Good idea - I'll try that next time around. Thank you. IanT |
Steviegtr | 30/03/2021 11:38:22 |
![]() 2668 forum posts 352 photos | Posted by bernard towers on 29/03/2021 23:45:41:
Let me know where you get it for a fiver a gallon Steve Monie paint supplies. Whitehall road . Leeds. Can on the left. Steve. Edited By Steviegtr on 30/03/2021 11:39:00 |
Blue Heeler | 30/03/2021 22:41:41 |
![]() 342 forum posts | Posted by IanT on 30/03/2021 10:54:37:
Good idea - I'll try that next time around. Thank you. IanT Cheers Ian hope it works as easy for you as it does for me. |
Morty | 31/03/2021 00:00:40 |
![]() 94 forum posts 101 photos | Hi there! I just pop My nozzles in a jar of thinners after use, fish them out when needed,give them a quick wipe with paper towel. Pop them back on the can and spray a little paint through before starting the job proper. Cheers, Pete
Blue Heeler | 31/03/2021 00:07:24 |
![]() 342 forum posts | Posted by Morty on 31/03/2021 00:00:40:
G'day I like my idea better I have so many different brands of cans and nearly every nozzle is different, this was I know the right nozzle is with the right can. And did you notice that each time I blew the turps out the nozzle it went further as the paint cleared internally? But whatever works best for you....its better than full cans of paint that are blocked! |
