How to prevent chatter?
Bo'sun | 27/02/2021 11:22:46 |
754 forum posts 2 photos | Good morning, When using HSS "rose" style countersink bits to countersink and chamfer holes in mild steel, how do I prevent them chattering? It occurs with both machine and hand operations. It doesn't happen all the time, but when it does, it's impossible to correct. I guess speed and lubrication might be the main considerations. |
Michael Gilligan | 27/02/2021 11:27:10 |
![]() 23121 forum posts 1360 photos | Try putting a small piece of thin cotton fabric between the cutter and the work. MichaelG. . P.S. 1, 2 or 3 flute cutters are usually less troublesome Edited By Michael Gilligan on 27/02/2021 11:30:15 |
Rod Renshaw | 27/02/2021 11:30:42 |
438 forum posts 2 photos | I think I read somewhere that rose bits were really woodworkers' tools. Single cutting edge countersink bits, of which there are several patterns, cut mild steel without chattering. Rod |
Bo'sun | 27/02/2021 11:43:15 |
754 forum posts 2 photos | Thank you Michael. Now you mention it, I remember one of the guys at work using a piece of spent emery cloth. Rod. I did try the "snail" type bits, and they worked realy well, but they didn't appear to be very hard. Probably meant for woodwork. I'll do a search and see if I can find them in HSS. |
Howard Lewis | 27/02/2021 11:44:35 |
7227 forum posts 21 photos | In my experience, Chamfering tools chatter unless the speed is kept low, and fed very gently. The 1/2 " one is better than the 3/4" when they are used in the 3 MT Tailstock.. Howard |
Emgee | 27/02/2021 11:47:48 |
2610 forum posts 312 photos | Posted by Bo'sun on 27/02/2021 11:22:46:
Good morning, When using HSS "rose" style countersink bits to countersink and chamfer holes in mild steel, how do I prevent them chattering? It occurs with both machine and hand operations. It doesn't happen all the time, but when it does, it's impossible to correct. I guess speed and lubrication might be the main considerations. Hi Bo'sun I have experienced the same but found low speed (200) and lube with 1 good hit does the job and leaves a smooth finish if countersinking, for de-burring of small holes I use the same cutter but held in a chuck and operated by hand. Emgee
Mike Hurley | 27/02/2021 12:06:45 |
530 forum posts 89 photos | After years getting oval, off centre or chattered countersinks with these type of cutters, I now get pretty well 100% success with the following 'rules' 1. Work firmly clamped down 2. Slow speed 3. (Probably the key one) be decisive! By this I mean, decide on your depth of countersink, set your stop on the drill press or equivalent on lathe/mill, then 'drill' in ONE FIRM motion to full depth. It always seemed to be the intermittent and 'bit less / or a tiny bit more' approach that causes issues. regards. Mike |
Hollowpoint | 27/02/2021 12:13:09 |
550 forum posts 77 photos | While we are on the topic of countersink bits does anyone have any recommendations for good value/performance? I always found the cheap ones are shockingly bad and the good ones are shockingly expensive. |
Emgee | 27/02/2021 12:30:18 |
2610 forum posts 312 photos | Posted by Hollowpoint on 27/02/2021 12:13:09:
While we are on the topic of countersink bits does anyone have any recommendations for good value/performance? I always found the cheap ones are shockingly bad and the good ones are shockingly expensive. You can make your own single point from silver steel hardened of course, just make sure you back off to give clearance. Or if you have access to a tool grinder do the same from HSS. Emgee |
Bill Phinn | 27/02/2021 12:38:32 |
1076 forum posts 129 photos | Posted by Hollowpoint on 27/02/2021 12:13:09:
While we are on the topic of countersink bits does anyone have any recommendations for good value/performance? I always found the cheap ones are shockingly bad and the good ones are shockingly expensive. The range of Sherwood single-flute csks from Zoro are excellent in performance and value. Alpen three-flute csks give very good performance as well though are a little pricier. Machine countersinking shouldn't cause chattering as long as you keep the speed and downfeed pressure low, and have good stiffness in the set-up. I tend to use Vactra no.2 as a lubricant, when I do use a lubricant.
Edited By Bill Phinn on 27/02/2021 12:46:23 |
bernard towers | 27/02/2021 12:54:26 |
1221 forum posts 161 photos | I use the through hole ones in various sizes as I have zero success with any that have more than one cutting edge, and speed is definitely a factor. |
Philip Rowe | 27/02/2021 13:41:43 |
248 forum posts 33 photos | Since I switched to using spotting drills instead of centre drills, I have found that they also make excellent countersink bits with no chatter at all. Phil |
Douglas Johnston | 27/02/2021 14:26:55 |
![]() 814 forum posts 36 photos | Posted by Philip Rowe on 27/02/2021 13:41:43:
+1 for that. I discovered this quite recently after buying a set of various diameter 90 degree spotting drills on the bay. They cut a treat and give a very neat countersink if you pick one just a tad bigger than the screwhead. Doug
Martin Dowing | 27/02/2021 16:13:26 |
![]() 356 forum posts 8 photos | There are *asymmetrical* countersinks where 3 segments with cutting edges are at different angles to each other. This design is implemmented explicitly to reduce / prevent chatter. Martin |
Henry Brown | 27/02/2021 17:47:25 |
![]() 618 forum posts 122 photos | The RDG 3 flute ones are good. I've got a few, 25mm is the largest, they need to be run slowly with lots of cutting oil, I use CT90. |
Georgineer | 27/02/2021 18:25:48 |
652 forum posts 33 photos | Posted by Martin Dowing on 27/02/2021 16:13:26:
There are *asymmetrical* countersinks where 3 segments with cutting edges are at different angles to each other. This design is implemmented explicitly to reduce / prevent chatter. Martin Dad had one he made when he was an apprentice which had just one 'tooth' at a different angle from the others. It was a delight to use. I think one of my brothers had it when we sorted out Dad's workshop. George B. |
