Could do with a hand if anyone can help?
James Frankland | 25/02/2021 22:03:38 |
![]() 14 forum posts 5 photos | Hi All I havent posted an update for a while, but if anyone can shed any light on this id be really grateful. Hope this is in the right place for this sort of question? I have an old TWIN Mill\Drill. Its been great for years and is trammed up lovely. When I bought it, the guy said the quill heated up "a bit". It always has but seemed to be ok. However, now it heats up a lot. I know it probably needs lubricating, but i cant see for the life of me where to get oil\grease to the main bearing. Ive tried everything. Believe me. I thought it might also be that the bearing is cramped too tight, but loosening things off for an experiment doesnt make any difference. Im thinking that the bearing is shot and needs replacing. I did take the whole head off a while ago and couldnt get the bearing out, but to be fair i didnt make that much effort. Ive never seen a machine like this anywhere, not even on the internet (only lathes.co.uk). Its such a good machine i really need to sort it out. See pics. Any help\advice\tips much appreciated. Thanks James
Edited By James Frankland on 25/02/2021 22:04:21 |
Emgee | 25/02/2021 22:16:46 |
2610 forum posts 312 photos | Hi James Are there any screws in the quill casting that don't seem to do anything ? if there are screws removing may reveal an oiling point. Or it's likely the bearings were grease filled on assembly and the grease has now migrated from the bearing surfaces, cure is dismantle and re-grease. Strong and useful looking machine. Emgee |
not done it yet | 25/02/2021 22:49:30 |
7517 forum posts 20 photos | It may be a sealed bearing? If so, there would not be any lube point. Bearing is likely past its best and needs replacing. |
James Frankland | 26/02/2021 17:27:15 |
![]() 14 forum posts 5 photos | Thanks guys. I suspect your correct. I did take it apart once so i could see the bearing but couldnt get it out. I think its sealed. I'll take it to bits tomorrow and have a look at getting the bearing out somehow. I seem to remember I couldnt get the pulley off the top which needed to come off. Anyway, will investigate more tomorrow.
Dave Halford | 26/02/2021 17:50:09 |
2536 forum posts 24 photos | Lathes says taper rollers, you may need to drive or push the spindle out. There will probably be spacers and or preload nuts of some kind to remove first. Use a gear puller on the pulley carefully they are sometimes fragile or bendable |
john fletcher 1 | 26/02/2021 18:06:39 |
893 forum posts | I have a Naerok drill / mill ( made in Korea and is Korean in reverse), the spindle pulley is on a taper, it needs warming up to expand before it will release off the taper. I used a hot air gun for maybe ten minutes, then very carefully used a three leg puller. The so called Chinese crap by some, is light years better than my Naerok drill / mill, I'm never the less happy with what I have got. John |
Brian Morehen | 26/02/2021 18:28:08 |
![]() 191 forum posts 11 photos | A great friend of mine no longer with us . I well remember him saying a man must have put it together we just have to get it in bits to repair it. Good luck Bee M |
Steviegtr | 26/02/2021 18:57:03 |
![]() 2668 forum posts 352 photos | As said above check for grub screws / holding bolts etc. Also the possibility of circlips. Steve. |
James Frankland | 07/03/2021 20:29:17 |
![]() 14 forum posts 5 photos | Hi All, Thanks for the comments. I took it apart but still have to get the bearings out. I did a video which you can see here. https://www.youtube.com/watch?v=pBVsZYpL7u0 Anyone have any ideas how to get the bearings out? There is a sleeve at the top that seems pressed or tapered on. That must have to come off. Thanks all. Regards James https://www.youtube.com/watch?v=pBVsZYpL7u0
Dave Halford | 07/03/2021 21:02:07 |
2536 forum posts 24 photos | Might be like a car rear half shaft bearing - a pressed on retaining ring, If the hole doesn't have a grubscrew in it |
Emgee | 07/03/2021 21:04:19 |
2610 forum posts 312 photos | James Perhaps the hole is for a C spanner to remove the nut, take care though it may just be a locking nut to retain the main nut and pre-load, the spindle will then perhaps pass down through both the top and bottom bearings. If the bottom bearing is a tapered roller bearing the inner will no doubt be shrunk fit onto the spindle. Emgee |
James Frankland | 07/03/2021 21:04:36 |
![]() 14 forum posts 5 photos | That ring at the top of the bearing, the thing that i said needs to come off did have a single, small grub screw in it. ?? |
noel shelley | 07/03/2021 21:11:11 |
2308 forum posts 33 photos | If you can see the bearing and it's sealed, you may be able to pop the seal out with a very small screwdriver, re grease it and pop the seal back in. Worth a try ? Noel |
James Frankland | 08/03/2021 12:32:44 |
![]() 14 forum posts 5 photos | Hi Noel That was my initial thought, to re-pack the bearing, but its a metal cased bearing and ive already buckled it trying to lever off what i thought was a rubber seal. Not that it matters, its got to come off.... |
Ian P | 08/03/2021 12:47:57 |
![]() 2747 forum posts 123 photos | Posted by James Frankland on 07/03/2021 21:04:36:
That ring at the top of the bearing, the thing that i said needs to come off did have a single, small grub screw in it. ?? Its possible that there is a brass pad under the grubscrew as the ring/collar may actually be a nut that sets the bearing preload. If it is a nut then the grubscrew hole may double as a recess for a peg/C spanner. I would look very closely (magnifying glass) where the shaft emerges from the nut/collar. Ian P |
Dave Halford | 08/03/2021 14:41:05 |
2536 forum posts 24 photos | Posted by James Frankland on 08/03/2021 12:32:44:
Hi Noel That was my initial thought, to re-pack the bearing, but its a metal cased bearing and ive already buckled it trying to lever off what i thought was a rubber seal. Not that it matters, its got to come off.... Actually it did matter and no it doesn't have to come off. The shield is an integral part of the bearing pressed on during assembly, you can't get them any other way. The idea is to keep the grease they come with inside the bearing when there is no other way to get fresh grease in there. also known as 'sealed for life bearings'. You need to get the shaft out of the bearing once the ring is removed then you can decide which bearing is stiff, probably both. Just buy new ones, the number is engraved on the bearing. |
not done it yet | 08/03/2021 18:45:01 |
7517 forum posts 20 photos | Re the comment on your vid. The bearing outer race will not be a shrink fit in the casing - it will be a simple press fit. |
James Frankland | 08/03/2021 21:06:06 |
![]() 14 forum posts 5 photos | Thank you all. I wanted to go and try a C spanner this evening but ran out of time. I will try tomorrow. Carefully of course. Ill take some pics\video. Thanks again, your advice\opinion is much appreciated. James |
James Frankland | 10/03/2021 19:34:24 |
![]() 14 forum posts 5 photos | Hi All. Thanks, it was in fact a screw on retainer as several people suggested. Here is a video of removing the bearing and shells. https://www.youtube.com/watch?v=rHWNePA_ptY In the video, i dont remove the bottom shell, but that is now out. I just tapped it out using a steel tube that almost fit. Also, i removed the bearing race from around the spindle by heating the bearing and it slid over the cold spindle. Only problem is that the bearings seem perfectly ok. However, i think that they may have been stiff. Then i pumped in so much grease that i might have made it worse by completely filling the quill chamber with grease. Maybe? Anyway, whatever, im going to replace the bearings of course. James |
Emgee | 10/03/2021 19:54:39 |
2610 forum posts 312 photos | James Looks like a well designed spindle but may have been stiff if there was too much pre-load put on the bearings by the retaining nut, and as you say the grease around the spindle would cause drag. Emgee |
