Drill a Small Diameter hole
Brian | 20/02/2021 14:14:49 |
40 forum posts 1 photos | I need to drill a very small 0.03mm diameter hole in steel to form a pilot hole light for a propane gas burner. Can it be drilled and what sort of equipment would be required. |
Tony Pratt 1 | 20/02/2021 14:23:01 |
2319 forum posts 13 photos | I didn't know you could get .03 mm drill/milling cutters but you can @ £200 plus! You would need a super fast machine & a very accurate method of holding the drill as a minimum. Be interesting what others say. Tony |
Ian Parkin | 20/02/2021 14:27:23 |
![]() 1174 forum posts 303 photos | I think i would look for a pilot jet in brass and drill and tap your hole in the steel to take the jet |
Clive Brown 1 | 20/02/2021 14:31:12 |
1050 forum posts 56 photos | Post removed, I thnk that I was over optimistic. Edited By Clive Brown 1 on 20/02/2021 14:39:05 |
Bill Phinn | 20/02/2021 14:40:14 |
1076 forum posts 129 photos | Brian, don't you mean 0.3mm? |
Brian | 20/02/2021 14:46:24 |
40 forum posts 1 photos | Thanks Bill, Its an age thing, the diameter should read 0.3mm. |
Bill Phinn | 20/02/2021 15:10:51 |
1076 forum posts 129 photos | Ideally, Brian, you'd use a high spindle speed and have good stiffness in the set-up. Jewellery-makers working free-hand tend to use micromotors to drill very small holes, though the metals drilled tend to be softer than steel. I would probably attempt your job with either one of my micromotors (Foredom and Saeyang) or my Proxxon MF70.
I forgot to ask: how deep is the hole to be drilled? Edited By Bill Phinn on 20/02/2021 15:11:37 |
noel shelley | 20/02/2021 15:16:10 |
2308 forum posts 33 photos | I would go with Ians idea. Buy a jet and screw it in. Noel |
Turbine Guy | 20/02/2021 15:21:30 |
541 forum posts 578 photos | One of my tool suppliers in the USA, McMaster-Carr, has drill point counter sinks that have drill points as small as 0.010" (0.25mm). These are what I use to drill holes this small. |
David Colwill | 20/02/2021 15:27:09 |
782 forum posts 40 photos | Carbide circuit board drills go down that and are pretty cheap RS do one for £13.50 (RS Stock No.:198-4678) but there are cheaper offerings on eBay etc. Be warned you can snap one by merely looking at it. I have used them at low speeds (3000 rpm) on my CNC mill but be prepared to lose a few. I have just had a look and I have a pack of 0.3mm if you pm me your address I will put a couple in the post. David.
pgk pgk | 20/02/2021 15:31:22 |
2661 forum posts 294 photos | If you can set it up in the lathe then Joe Pieczynski showed a technique that could work demonstrated with a 26thou drill through s/s https://www.youtube.com/watch?v=PqU5wS0J4MU pgk |
Brian | 20/02/2021 15:58:12 |
40 forum posts 1 photos | Gentlemen, thank you for you help and direction. Brian |
John P | 20/02/2021 16:48:58 |
451 forum posts 268 photos | Hi Get a 24 gauge hypodermic needle has a bore of John |
Oven Man | 20/02/2021 17:06:02 |
![]() 204 forum posts 37 photos | How about a 0.3mm diameter nozzle from a 3D printer. They are inexpensive and easily come by. Peter |
John Shepherd | 20/02/2021 17:07:12 |
222 forum posts 7 photos | Re J Pieczynski Youtube video Arc sell a micro drill adaptor that works on the same principle. I think I have saved the cost of it by reducing the number of broken drills |
Howard Lewis | 20/02/2021 17:28:00 |
7227 forum posts 21 photos | 0.3 mm (0.0118" in old money ) is the lower end of the size of holes drilled in Diesel fuel Injectors. CAV at Sudbury used to drill the hole and measure it before saying what the drill size was! Memories, Martin? Howard
