Neil Wyatt | 16/02/2021 18:00:44 |
![]() 19226 forum posts 749 photos 86 articles | |
Joseph Noci 1 | 16/02/2021 18:07:51 |
1323 forum posts 1431 photos | Nice One Neil! There are many utube videos with engine starts as the theme ( some steam as well) - from old aviation engines, tanks, trucks, ships, etc and, for some odd reason, I am hooked on watching them... Joe |
Bazyle | 16/02/2021 18:22:02 |
![]() 6956 forum posts 229 photos | wouldn't fancy having to do a push start |
Grizzly bear | 16/02/2021 18:35:52 |
337 forum posts 8 photos | Not much thought for the batteries and starter motor. Typical driver! |
V8Eng | 16/02/2021 18:37:13 |
1826 forum posts 1 photos | Should’ve got some decent Welsh steam coal. Edited By V8Eng on 16/02/2021 18:37:38 |
Mike Poole | 16/02/2021 18:39:58 |
![]() 3676 forum posts 82 photos | If it had to have an MOT it might be a bit marginal on the smoke test
Mike Edited By Mike Poole on 16/02/2021 18:40:14 |
Nick Clarke 3 | 16/02/2021 18:47:06 |
![]() 1607 forum posts 69 photos | One of the more senior members of our club was a fireman on the GWR and a driver on GWR and BR. He says that the multiple units would go flat overnight on shed so they were just left running instead! Edited By Nick Clarke 3 on 16/02/2021 18:47:32 |
Phil Whitley | 16/02/2021 18:52:10 |
![]() 1533 forum posts 147 photos | Kigas? Easystart? |
JohnF | 16/02/2021 19:01:46 |
![]() 1243 forum posts 202 photos | Should have had a lamp under the sump ! |
Howard Lewis | 16/02/2021 19:02:02 |
7227 forum posts 21 photos | Kigas, yes. Easystart NO. The ether tends to wash bores clear of oil. Have you seen film of an Alco loco starting, even under reasonable conditions? As bad if not worse than that Class 50. At -30C if an engine cranked for more than 30 seconds before first fire, it was deemed a failure. The electrician at Bognor depot once timed a bus that had stood outside overnight, cranking for SEVEN minutes before it self sustained! The starter and cables were too hot to touch by then I would imagine. Quite often, first fire raised the cranking speed, so that a second cylinder joined in, and as the cranking speed increased the others came in, in turn. The end result was a great cloud of unburned fuel from the late comers! Which is probably what we are seeing here. Howard |
Pete White | 16/02/2021 19:10:53 |
223 forum posts 16 photos | Posted by Phil Whitley on 16/02/2021 18:52:10:
Kigas? Easystart?
Once you needed Easy start it was the begining of the end, burnt all the crap out that was sealing your rings. I once had a Landrover with 2.2 BMC diesel fitted that fired up like that, cold Start button, that just chucked loads of fuel in, good for going up hill loaded Pete |
Mike Poole | 16/02/2021 19:11:11 |
![]() 3676 forum posts 82 photos | |
Pete White | 16/02/2021 19:11:54 |
223 forum posts 16 photos | Pilot error, dual post, I blame the internet.
Edited By Pete White on 16/02/2021 19:14:47 |
john halfpenny | 16/02/2021 19:12:59 |
314 forum posts 28 photos | One very cold morning I was instructed to hit the starter on an ancient double deck Leyland, and not release until told. The owner operator soaked rag in easy start, lit it with his fag, and threw it into the air intake. The engine clattered into life one cylinder at a time over nearly a minute. I was only then instructed to let go. A life lesson. |
Zan | 16/02/2021 19:23:40 |
356 forum posts 25 photos | Gee you can’t get decent coal these days I wonder where it came from?👻 |
Andy Stopford | 16/02/2021 19:40:51 |
241 forum posts 35 photos | Posted by Nick Clarke 3 on 16/02/2021 18:47:06:
One of the more senior members of our club was a fireman on the GWR and a driver on GWR and BR. He says that the multiple units would go flat overnight on shed so they were just left running instead! Edited By Nick Clarke 3 on 16/02/2021 18:47:32 They used to do this at Tonbridge with the Hastings Line DMUs - when the inevitable letters of complaint were printed in the local rag, a BR representative would explain that the engines were worn out and would be unstartable if left to cool down overnight.* Of course being left ticking over all night glazed the cylinder bores, making the engines even harder to start, and making them produce steam engine-like clouds of smoke. It wasn't limited to DMUs. BR was so cash-starved in its latter days that apparently they couldn't afford batteries for the big single unit diesels, and wrecked the engines by leaving them idling all night. Of course everyone involved with the motive power side of things knew this was a stupid thing to do, but ... politicians. *I seem to recall it was said that the Sulzer engines in these had negative clearances when cold, so the donkey engine, which was plumbed into the same cooling system had to be started a couple of hours in advance to warm the engine up so it could be cranked over. |
Jon Lawes | 16/02/2021 19:41:31 |
![]() 1078 forum posts | When they couldn't get the A&AEE Harvard started after the first few attempts you had to take the plugs out, whether for cleaning or replacing I don't know, but it's not a task that looked fun! |
Howard Lewis | 16/02/2021 19:44:26 |
7227 forum posts 21 photos | We once started a truck at MIRA by holding a flaming rag over the air intake (The injection pump provide excess fuel, for starting, but was so worn that when checked it was at normal running level). Once running it was still good for nearly 60 mph around the track. Didn't think that Land Rovers had excess fuel (No production DPA provided it) My Sries 2 relied on heater plugs. Substituting a CAV Thermostart which heated the ingoing air with a flame much improved cold starting! The Leyland PD2 and PD3 used a CAV fuel, injection pump fitted with a governor which provided excess fuel, and were ready cold starters. The same 0600 engine with a DPA without excess fuel was nothing like as good. A lot of modern engine ECUs keep the heaters energised after start up to prevent light load misfires and smoke. The fuel supplied has a great effect on starting, smoke and running. Cetane value and calorific value have a huge effect. Howard |
Jeff Dayman | 16/02/2021 20:09:04 |
2356 forum posts 47 photos | The last ditch engine start technique for temps here in Canada for days below -25 deg C at the family garage was to take a pint pouring can (with thin spout), put a few ounces of gasoline in it, light it, and pour fire directly into the open intake while cranking the engine. Extremely dangerous, not the done thing these days I am sure, but it worked, particularly on very large gasoline and diesel engines. Definitely worked better the older the engine was. We worked on cars trucks and tractors from the 1920's to the 1980's in the family shop. Nowadays you would be challenged on most cars and trucks to find a vertical intake hole of any kind to pour the fire into. We got many calls for "engine won't start" on such days, on locally used cars, mostly 1960's-1970's US made ones. Dad had rigged an extra long set of heater supply and return hoses into the 327 Chev V-8 in our service truck. He arranged end-of-hose valves and couplers so that on such calls he would disconnect the heater hoses from the car's engine block and connect in the long ones from the service truck's running engine. 5 minutes of hot circulating coolant and 9 out of 10 engines would start just fine. Another 5 minutes to disconnect hoses / fix car's coolant level , return to the garage where the phone was ringing off the wall, and then send a bill for $25 whole dollars. Without the hot coolant many cars just would not start at say -30 deg C regardless of what you tried or for how long. Edited By Jeff Dayman on 16/02/2021 20:09:29 |
John P | 16/02/2021 20:15:31 |
451 forum posts 268 photos | Hi John |
