Vic | 12/02/2021 14:25:09 |
3453 forum posts 23 photos | I’ve often thought this would be a handy addition for my milling machine. Anyone got one, what do you think of it? |
IanT | 12/02/2021 14:52:14 |
2147 forum posts 222 photos | I have a small one Vic - it's a good solid small vice and seems well made but frankly I've never used the self-centring aspect of it as such, although it might be useful. For instance my small Taig head has a ER16 collet (max 10mm). So in theory I could hold a 10mm rod in the collet, grip it in the vice, then bolt the vice in position and then place (say) a 30mm piece in the vice and it would be 'automatically' centred. I'm not sure how accurate this would be in practice though. Probably in the "near enough" category for most things I would think but I don't know for sure. I guess I'll have to test it now... Regards, IanT |
Dalboy | 12/02/2021 15:10:28 |
![]() 1009 forum posts 305 photos | Having seen self centering vices there seems more moving parts so therefore I would not use them for accurate work. |
Vic | 12/02/2021 21:30:07 |
3453 forum posts 23 photos | Posted by IanT on 12/02/2021 14:52:14:I
I'm not sure how accurate this would be in practice though. Probably in the "near enough" category for most things I would think but I don't know for sure. I guess I'll have to test it now... Regards, IanT let me know if you do ... |
Martin Kyte | 12/02/2021 21:56:20 |
![]() 3445 forum posts 62 photos | I don't see it would help at all unless I'm missing something. For a start you lose the benifit of a reference jaw you get with a standard milling vice. With a clocked Jaw corner and a DRO you can quickly reference a workpiece and Drill or machine wherever you choose. As I said please tell me if I have missed something. regards Martin |
Peter Greene | 12/02/2021 22:24:25 |
865 forum posts 12 photos | Presumably you get a reference centre instead of an edge which I, for one, would find useful in some circumstances. There are several ways to do any job. Everyone has their own preference(s) but it's usually worth keeping an open mind. I've looked at self-centering vices and - like others I suppose - wondered just how accurate they are. It would be nice to have a feel for that. |
Vic | 12/02/2021 22:34:11 |
3453 forum posts 23 photos | If a job needs the accuracy then I work off the fixed jaw. Some jobs though are “near enough” in this case if I want for example to centre drill a 12mm rod I’ll put a 12mm piece of short stock in the Chuck and then move the vice until it just touches the bar. I can then replace the bar with a drill bit and drill the hole. This is pretty quick and pretty accurate. Sometimes though the piece to be drilled is not a size, often too big, that I can put in the Chuck. If the SCV is reasonably well made (I’m not sure it necessarily would be) then it could come in handy for any size up to its max capacity. |
Peter Greene | 13/02/2021 01:54:59 |
865 forum posts 12 photos | The jaw positions are controlled by LH-thread and RH-thread leadscrews. As far as I can see, the positional/centring accuracy is determined wholly by the accuracy of those threads. Other accuracy/precision determinants (jaw-alignment; parallelism etc) would be as for any other vice I suppose. Edited By Peter Greene on 13/02/2021 01:55:24 |
JasonB | 13/02/2021 07:08:11 |
![]() 25215 forum posts 3105 photos 1 articles | The CNC boys love them, Ideal if machining all around a rough block, if it's size varies you still take equal amounts off both sides. As with everything what you pay is what you get and the CNC ones come out more expensive than say the Warco offering. Unless there is a need to machine a varying range of parts centrally without disturbing the vice I don't see much use for them otherwise. |
colin hawes | 13/02/2021 12:40:09 |
570 forum posts 18 photos | I always prefer measuring and working from one known datum edge in x and y axes. A vice with both jaws moving would not satisfy this condition. Colin |
Vic | 13/02/2021 15:39:30 |
3453 forum posts 23 photos | Bit outside my price range ...
old mart | 13/02/2021 16:42:13 |
4655 forum posts 304 photos | They can be very useful for repetitive work with a drill press, but not so much with a milling machine. |
Vic | 13/02/2021 17:41:55 |
3453 forum posts 23 photos | I found it quite surprising how little of the blank is actually gripped in this video. The mill was taking some sizeable cuts as well. |
Michael Gilligan | 13/02/2021 17:54:51 |
![]() 23121 forum posts 1360 photos | Posted by Vic on 13/02/2021 17:41:55:
I found it quite surprising how little of the blank is actually gripped in this video. The mill was taking some sizeable cuts as well. . Astonishing ! ... Don’t try this at home folks. MichaelG. |
JasonB | 13/02/2021 18:19:13 |
![]() 25215 forum posts 3105 photos 1 articles | The hardened jaws have small "teeth" that actually bite into the work or another option is to pre machine a small dovetail along two sides of the blank. Once all 4 sides and the top have been machined the part will then often go into a second vice with custom nesting jaws that grip the machined shape of the part which is then decked to remove the waste from the bottom and do any other machining on that side which removes the jaw marks from the second operation. You can buy replacement jaws for your "Kurt" clone type vice that will take the hardend serrated jaws if you can't stretch to a full blown CNC vice. Also worth noting the vices are quiet tall which is to allow all round access when using a 5 axis machine. |
Vic | 13/02/2021 20:08:18 |
3453 forum posts 23 photos | Posted by old mart on 13/02/2021 16:42:13:
They can be very useful for repetitive work with a drill press, but not so much with a milling machine. Which vice do you have? |
old mart | 13/02/2021 20:19:54 |
4655 forum posts 304 photos | I don't have a self centring vise, I don't have a use for one. |
Vic | 13/02/2021 22:04:30 |
3453 forum posts 23 photos | Posted by old mart on 13/02/2021 20:19:54:
I don't have a self centring vise, I don't have a use for one. I see, so you don’t have one but you say: “They can be very useful for repetitive work with a drill press, but not so much with a milling machine” |
DMB | 13/02/2021 22:49:06 |
1585 forum posts 1 photos | They come under the heading of gimmicks as far as I'm concerned since you can't beat a fixed jaw to ref to in all 3 axis, then you know where you are. As said above, heavily dependent on the accuracy of not one but two leadscrew threads, two moving jaws with the possibility of both rising up (probably by varying amounts) as the are tightened. Good idea at first sight but fails on many points. Even if made to 'aero' tolerances, wear would soon put paid to manufacturing accuracy. Not got one, dont want one, not even free gift. Likely to be more trouble than it's worth and I'm too long in the tooth therefore lacking strength to loose my rag and chuck it over the hedge! |
Peter Greene | 13/02/2021 23:03:28 |
865 forum posts 12 photos | Can't imagine they'll sell many of these then. Edited By Peter Greene on 13/02/2021 23:06:33 |
