Square hole & Rose index.
Oldiron | 16/01/2021 17:07:45 |
1193 forum posts 59 photos | Never too old to learn I say. Saw this on the interweb today. Cannot say that I ever remember seeing a Rose index in use. Handy method if you have no broaches. mrpete video. Next shop project maybe ? regards |
Bo'sun | 17/01/2021 10:48:06 |
754 forum posts 2 photos | Interesting. Watched it last night. |
Hopper | 17/01/2021 11:02:55 |
![]() 7881 forum posts 397 photos | Looks pretty handy. I have not come across the Rose Index before. I only found one supplier online, Lakeshore Carbide in the USA. $149 for the 2" version MrPete is using. Wow!!! But it looks simple enough to make one that would do the job. |
David Colwill | 17/01/2021 12:20:37 |
782 forum posts 40 photos | Posted by Hopper on 17/01/2021 11:02:55:
Looks pretty handy. I have not come across the Rose Index before. I only found one supplier online, Lakeshore Carbide in the USA. $149 for the 2" version MrPete is using. Wow!!! But it looks simple enough to make one that would do the job. 5c or er32 collet blocks are a good option if you have them. I also use vee blocks for larger stuff but this is limited to 90 degrees. Regards. David. |
Iain Downs | 17/01/2021 12:25:44 |
976 forum posts 805 photos | I was slightly amused to find that the best way of making a square hole involved buying a $150 rose index rather than a $150 broach... However, it does look like a handy piece of kit - though quite expensive (even before the carriage). It's gone on my todo list!
Iain |
Graham Titman | 17/01/2021 12:39:04 |
![]() 158 forum posts 28 photos | Or buy John Stevenson er block from Arc Euro little bit cheaper than importing from the states and do the same job |
Oldiron | 17/01/2021 13:19:51 |
1193 forum posts 59 photos | Posted by Graham Titman on 17/01/2021 12:39:04:
Or buy John Stevenson er block from Arc Euro little bit cheaper than importing from the states and do the same job BUT can you get 2" through a JS block? I cannot. Cheapest way is to make yoiur own. regards |
Oldiron | 17/01/2021 13:24:32 |
1193 forum posts 59 photos | Posted by Iain Downs on 17/01/2021 12:25:44:
Iain I think if you were to buy a Rose block (better still, make one) it would turn out cheaper than buying a set of broaches & dies and a press to use them. regards |
Dr_GMJN | 17/01/2021 13:52:24 |
![]() 1602 forum posts | May well have misunderstood what's going on, but why is turning through exactly 90 degrees so important for drilling the pin holes? Wouldn't 'about 90 degrees' be OK, or really any angle so long as the drilled pin holes didn't break into the square hole? |
Nick Wheeler | 17/01/2021 13:56:39 |
1227 forum posts 101 photos | Posted by Oldiron on 17/01/2021 13:19:51:
Or buy John Stevenson er block from Arc Euro little bit cheaper than importing from the states and do the same job BUT can you get 2" through a JS block? I cannot. Cheapest way is to make your own.
a few laser cut plates pinned together would do it |
not done it yet | 17/01/2021 16:30:48 |
7517 forum posts 20 photos | Anything wrong with a rectangular block and a precision adjustable angle measurer? Some will have angle gauge blocks, some won’t need any great precision, etc. |
Hopper | 17/01/2021 17:12:21 |
![]() 7881 forum posts 397 photos | Posted by Iain Downs on 17/01/2021 12:25:44:
Iain Maybe because he got sent one to do a review on? Joe Pie has a cheapo homemade idea here at the 5.00 minute mark, but you have to glue it to the job. But you can buy a lot of glue for $149. |
Old Crock | 17/01/2021 20:04:03 |
31 forum posts 18 photos | Why not print one? Go to Thingiverse and search Rose Index. Inspired by Mr Pete’ video. John |
Roger Best | 17/01/2021 20:49:34 |
![]() 406 forum posts 56 photos | That's a useful principle, thanks, you only need the facets you need for a job so a jig is easy. |
