Help with lathe speed
Neil Mccarthy 121/11/2020 00:13:56
43 forum posts
I am in the middle of restoring my Drummond b lathe and I was wondering if you can have a speed controller on a 240volt single phase ac motor at all as I use to use a cj18a mini lathe and you could control the speed on that one
thank you in advance
Steviegtr21/11/2020 00:19:47
2668 forum posts
352 photos
You can slow down a single phase motor but in doing so will loose the torque needed. It is better to look for a 3 phase motor with 240 windings As 415v star 240 delta motor. Then use a 240v 3ph inverter . to control it. Probably going to cost you in the region of new 300+ quid. 2nd hand if you are lucky 200.
Steve.
Pete Rimmer21/11/2020 06:06:08
1486 forum posts
105 photos
Posted by Neil Mccarthy 1 on 21/11/2020 00:13:56:
Your Drummond's motor's speed is fixed by the 50Hz frequency of mains electricity. Whilst it is possible, it's not practical to alter the way you can with a 3-phase motor.
Your mini-lathe will have a DC motor which is why you can use a speed controller.
David George 121/11/2020 08:11:01
2110 forum posts
565 photos
Be careful the top speed for your lathe with bronze bushes is below 1000 RPM and most speed controlled motors loose power at slow speed on my M Type I can screw cut at 50 RPM with back gear and pleanty of power not so on a friend's variable Chinese lathe.
David
David Colwill21/11/2020 09:50:04
782 forum posts
40 photos
Posted by David George 1 on 21/11/2020 08:11:01:
David
You are right regarding the lathes top speed but torque at low speed shouldn't be a problem as the Drummond has back gear (I think) and this can be used for turning larger diameters and screw cutting etc.
If you can find a scrap yard willing to let you poke around, you may be able to rumage up a three phase motor for not too much.
There are any number of cheap inverters from China for £50-£60. I don't have any experience of these (I have one in a box waiting for the time to come available) but others here will have used them.
David.
Martin Connelly21/11/2020 10:06:11
2549 forum posts
235 photos
If you go three phase make sure the nominal speed of the three phase motor is similar to that of the current one. The number of poles on a three phase motor determines the nominal speed. A scrap motor may look the part but cause problems of running too slow or too fast at nominal frequency from a VFD.
Martin C
old mart21/11/2020 15:31:41
4655 forum posts
304 photos
Should you end up deciding to change to a 3 phase motor run from a VFD, then there is a choice of basic types. At 50Hz standard mains frequency, the choice is as follows:
2 pole @ 3000rpm
4 pole @ 1500rpm
6 pole @1000rpm
8 pole @ 750rpm
The price increases with the number of poles. They all can be controlled with a VFD and the torque values are good between 25 and 75 Hz, (0.5 to 1.5 times their standard speed). Lower frequencies bring a steep dip in torque.
Steviegtr22/11/2020 00:50:29
2668 forum posts
352 photos
David
My lathe has a Bronze front spindle bearing & is rated at around 2150 rpm from the single phase as supplied motor. A Super 7B 1977 vintage. I rarely run much above 1000 though.
Steve,
Henry Artist22/11/2020 03:04:45
121 forum posts
46 photos
Depending on what you intend to use the lathe for, why not just use a motor and speed controller from a mini-lathe?
PETER ROACH25/11/2020 22:37:44
50 forum posts
25 photos
Probably not widely known, but split phase, cap run single phase motors can be run from VFDs. These motors are in effect a two phase motor and the generic AT2 VFDs are design to provide control for them.**LINK**
