Eric Cox | 31/07/2020 09:55:41 |
![]() 557 forum posts 38 photos | I've seen quite a few models of stationary steam engines with guard railings. How do you make and secure yours. |
mechman48 | 31/07/2020 10:15:42 |
![]() 2947 forum posts 468 photos | Good question; am looking to make further models with rails etc. I understand if you have the scale right you can get model ships railings & stanchions from model ships dealers. George. |
JasonB | 31/07/2020 11:46:27 |
![]() 25215 forum posts 3105 photos 1 articles | I'd drill through the base and screw them on from below, it allows you to rotate them so the rail holes are in line. As for making use round bar, cross drill for rails first and then turn from that, mill if I want any squares where the rails go or at base, saw/part off, face bottom end true and then drill and tap for fixing. Edited By JasonB on 31/07/2020 12:08:56 |
Neil Wyatt | 31/07/2020 13:58:19 |
![]() 19226 forum posts 749 photos 86 articles | Very carefully, with form tools. Easiest if drilled before forming, although that obviously makes them more fragile... Neil |
duncan webster | 31/07/2020 14:02:49 |
5307 forum posts 83 photos | Brass balls drilled both ways then silver soldered to the upright. Might be easier to turn the uprights with 2 very small steps to locate the balls, drill one way, silver solder, then drill t'other way |
not done it yet | 31/07/2020 14:43:03 |
7517 forum posts 20 photos | If for aesthetics only. 3-D printing, for monotonous regularity, could be an alternative? Particularly for uprights? |
Brian H | 31/07/2020 17:58:16 |
![]() 2312 forum posts 112 photos | Not cheap but; Brian |
Dalboy | 31/07/2020 18:07:26 |
![]() 1009 forum posts 305 photos | If you want just a single rail and will be painting them then use some split pins and a brass rod they can be soft soldered. The other alternative is to turn you own with the number of balls then cross drill the balls for the rails this would be for larger stanchions the same as Neil shows |
