petro1head | 24/07/2020 08:35:55 |
![]() 984 forum posts 207 photos | Quite often i get a build of of alloy on the cutter and have to stop the job to remove the build up. so would a dab of thread cutting oil help, or something else. don't want to flood cool due to mess |
Martin Kyte | 24/07/2020 08:44:01 |
![]() 3445 forum posts 62 photos | Paraffin or WD40. regards Martin |
petro1head | 24/07/2020 08:45:45 |
![]() 984 forum posts 207 photos | Brill, thanks |
not done it yet | 24/07/2020 08:57:42 |
7517 forum posts 20 photos | I’ve just sent you a PM. |
Martin Connelly | 24/07/2020 09:04:55 |
![]() 2549 forum posts 235 photos | Avoid coated cutters as well. Martin C |
Eric Cox | 24/07/2020 10:05:43 |
![]() 557 forum posts 38 photos | Make sure your cutter is sharp.Yesterday I had to take a centre punch and hammer to mine to remove the build up. |
mechman48 | 24/07/2020 11:10:23 |
![]() 2947 forum posts 468 photos | + 1 for WD 40. George. |
Bill Pudney | 24/07/2020 11:54:31 |
622 forum posts 24 photos | +2 for kero or WD40. My preference is for kero. Experience with WD40, in other applications suggests that WD40 leaves a sticky gooey mess, as a result I haven't used it much as a cutting aid. It is however brilliant at water displacing. Kero, or paraffin is very good on al. alloy, and as others have said, uncoated really sharp cutters work best. best of luck!! cheers Bill |
mark costello 1 | 24/07/2020 19:28:10 |
![]() 800 forum posts 16 photos | If You can buy cheap penetrating fluid at auto jumbles etc. it works well.The cheaper the better. |
