Tapping and re-threading stuck screw!
claire dickson | 12/03/2020 08:05:14 |
2 forum posts | I have an old saw and the part where the blade sits on has a screw stuck in it so I need an engineer to get it out for me. Can anyone help please? |
David George 1 | 12/03/2020 14:03:26 |
![]() 2110 forum posts 565 photos | Hi Claire it would help if you can give a little more information ie what type of saw and which end of the saw is damaged a locality of where you are would help. David |
Chris Evans 6 | 14/03/2020 19:16:28 |
![]() 2156 forum posts | Just bumping this thread up. Claire if you are in the Midlands near Lichfield I may be able to help. |
DMB | 14/03/2020 21:36:37 |
1585 forum posts 1 photos | Claire, What sort of saw? Engineers hacksaw, presumably but could be a jewellers, coping or other type? Can you describe it? This applies to all queries; give as much info as possible and/or photo, to boost possible number of responses. I mean this to be helpful, not critical. John Edited By DMB on 14/03/2020 21:39:47 Edited By DMB on 14/03/2020 21:41:04 |
claire dickson | 20/03/2020 09:00:02 |
2 forum posts | It’s a printers saw. Am in Leeds, but my dad lives in London (it’s my dads saw). |
Former Member | 20/03/2020 09:09:10 |
1329 forum posts | [This posting has been removed] |
Speedy Builder5 | 20/03/2020 10:12:52 |
2878 forum posts 248 photos | Wait for Claire to verify, but pictures on the net look similar to a table saw, 5 or 7" diameter sitting in a big heavy cast iron base. It looks like rotation is normal (Anticlockwise looking on the nut). so should be a normal RH thread. |
Former Member | 20/03/2020 10:53:57 |
Samsaranda | 20/03/2020 11:46:22 |
![]() 1688 forum posts 16 photos | I think Claire has the saw in her possession by the way she has worded the request so presumably in Leeds ! |
Bob n About | 20/03/2020 12:01:53 |
60 forum posts 1 photos | If the screw isn’t totally mangled get some heat on the part, 100℃ or so and add a dab of diesel. Let it soak in for a while 30 mins, and try removing screw with screwdriver, Allen key, mole grips, whatever. Maybe add some more heat and repeat a couple of times. If it’s surrounded by plastic, you’re out of luck. |
ega | 20/03/2020 13:42:38 |
2805 forum posts 219 photos | If the screw has become overtight through the rotation of the spindle then "shock loading" might be the answer ie hit the allen key, etc. What does a printer's saw cut? |
not done it yet | 20/03/2020 14:10:09 |
7517 forum posts 20 photos | What does a printer's saw cut? Possibly lead strips? |
not done it yet | 20/03/2020 14:17:46 |
7517 forum posts 20 photos | When someone knows for sure whether it is a clockwise or anticlockwise screw, an impulse driver might do the trick. Otherwise drill with the appropriate left or right handed drill(s). |
Michael Gilligan | 20/03/2020 17:00:43 |
![]() 23121 forum posts 1360 photos | Posted by not done it yet on 20/03/2020 14:10:09:
What does a printer's saw cut? Possibly lead strips? . A wealth of information, here: https://circuitousroot.com/artifice/letters/press/comproom/saw/index.html MichaelG. |
ega | 20/03/2020 17:29:30 |
2805 forum posts 219 photos | Michael G: Thank for the link. I did actually glance at the linked page before posing my question; knowing next to nothing about printing, however, I came away without the answer. As a schoolboy I recall a visit to the Clarendon Press in Oxford and being impressed by the enormous volume of noise from the (?) linotype machines. |
Michael Gilligan | 20/03/2020 17:52:23 |
![]() 23121 forum posts 1360 photos | Sorry ega, I hadn’t noticed that the question was yours ... I was responding to ndiy’s post. The answer is ‘type metal’ [such as that used for Linotype], not Lead. This page [next stop on the circuitous route] links several instruction books and patents: **LINK** https://circuitousroot.com/artifice/letters/press/comproom/saw/cg/index.html MichaelG.
Edited By Michael Gilligan on 20/03/2020 17:53:15 |
Steviegtr | 21/03/2020 00:01:51 |
![]() 2668 forum posts 352 photos | Mnnnnnnnn. |
Michael Gilligan | 21/03/2020 09:12:17 |
![]() 23121 forum posts 1360 photos | Posted by Steviegtr on 21/03/2020 00:01:51:
Mnnnnnnnn. . That’s rather cryptic, Steve ... Could you please elaborate ? MichaelG. |
ega | 21/03/2020 09:26:44 |
2805 forum posts 219 photos | I hope to hear that someone can help the OP but in the meantime was interested to read some of the material linked by MichaelG. It seems that some of these old printer's saws had a sliding table immediately to the left of the blade which is the same configuration adopted by modern woodworking saws. |
