larry phelan 1 | 07/03/2020 11:50:18 |
1346 forum posts 15 photos | Good day all, I am having trouble with my Canon printer in that it will not feed the paper into itself. The paper gets as far as the rollers but they don't seem to pick it up. Any ideas how to correct this or even how to get access to these rollers ? I don't want to butcher the machine, trying to "fix" it. I,m sure some of you have come across this before ,so I would welcome your advice. Thank you in advance. |
Bryan Cedar 1 | 07/03/2020 11:54:11 |
127 forum posts 4 photos | It would help to get an answer if you would state the model number. |
Circlip | 07/03/2020 12:14:43 |
1723 forum posts | Whichever printer, look on T'internet for model type stripdown. Chances are, rollers have a polished appearance. Clean with spirits to give matt surface and reassemble.
Regards Ian Might be an idea to wear surgical type gloves, waste ink a bit like "Ingineers blue", damn stuff get all over. |
larry phelan 1 | 07/03/2020 12:22:20 |
1346 forum posts 15 photos | Sorry, I should have given the model number, which is MG3250. |
peak4 | 07/03/2020 12:44:15 |
![]() 2207 forum posts 210 photos | Larry, after a while, the rubber rollers, or pickup quadrant gets glazed over and looses friction. You could try cleaning with IPA, but don't overdo it as that in itself can dry out the rollers and cause future problems. I use Electrolube Rubber Roller Restorer on a lint free cloth Bill |
HOWARDT | 07/03/2020 13:28:51 |
1081 forum posts 39 photos | Try using a heavier weight paper. I had to go to 80 from 70gm when the transport system stopped picking up the paper consistently. |
Russell Eberhardt | 07/03/2020 15:30:14 |
![]() 2785 forum posts 87 photos | Best to strip it down if you can figure out how. Then remove the glaze with 400 wet and dry. Then all you've got to do is figure out where that spare spring came from! Russell |
Dennis D | 07/03/2020 15:46:03 |
84 forum posts 3 photos | Make sure there is no foreign object in the paper feed. Took a printer to the repair shop for while you wait repair only for him to find a playing card one of the ankle biters had posted. |
larry phelan 1 | 07/03/2020 16:54:39 |
1346 forum posts 15 photos | Yes indeed, I would strip it down if I could work out how to do it. I shall have a strong drink [maybe two ] and then attack it again. In the meantime, thank you all for your assistance. |
Enough! | 07/03/2020 17:15:42 |
1719 forum posts 1 photos | You can't just squint down the paper entry path with a flashlight and have a look? |
larry phelan 1 | 08/03/2020 16:42:25 |
1346 forum posts 15 photos | Strong drink and helpful advice seem to have helped to some extent, since my printer has now performed a little better. I,m not sure if this approach would work in all cases of machine failure, but it,s worth a try ! Cheers !!! |
Bill Davies 2 | 08/03/2020 18:39:15 |
357 forum posts 13 photos | Did you recently buy new paper, or is it stored somewhere cold? Slightly damp paper doesn't load well. I also agree with HOWARDT about the weight of paper. At multiple worklaces, I have had problems with industrial sized printer/copiers that objected to 70g paper (or cheap 80g) the buying departmens tried to foist on us. If you check with calipers, full weight 80g paper is close to 0.1mm thick. Bill |
Martin W | 09/03/2020 09:34:11 |
940 forum posts 30 photos | Larry PM sent re roller cleaning for the MG3200 series printer/scanners. Hope it helps Martin |
