Cleaning an old lathe
Gavlar13/02/2020 16:27:10
119 forum posts
I recently acquired a 'new' old engine lathe. The condition is quite good but it is filthy, I'm not sure it has ever been cleaned. It is ex-school and as such it is caked in a sawdust and dried oil mix which has set like an epoxy resin and I'm finding near impossible to get off. I can clean the flat and unpainted surfaces with a scraper but I can't get it out of the various painted nooks and crannies without damaging the paintwork with abrasive cleaning methods. I've tried to soften it by soaking it in turn with oil, petrol, diesel and brake cleaner (which I think is acetone) but nothing is touching it.
It's not effecting the function of the lathe, I don't want to strip and repaint it and I can live with it, but it would be nice to get it properly clean.
Any ideas for removal, please?
ega13/02/2020 17:56:34
2805 forum posts
219 photos
Someone once told me that brake fluid would soften the carbon deposit in a cylinder head; might be worth a (careful) try.
What is the lathe and might you post a picture?
Grindstone Cowboy13/02/2020 18:07:56
1160 forum posts
73 photos
Careful, brake fluid will also soften and remove the paint if you get any on it. Try paraffin or white spirits (which may also affect the paint, but to a lesser extent, so a test might be in order.
Steviegtr13/02/2020 18:09:15
2668 forum posts
352 photos
Old brake fluid possibly. Brake fluid now is water based. I.E does not attack car paintwork anymore. Try a hot air gun. If it's wood resin, it may melt it.
Steve.
Brian Morehen13/02/2020 18:29:35
191 forum posts
11 photos
Oven Cleaner I have used this all of my vans to remove the sign writeing aand never damaged the paintwork on the motor. May be worth a try the sign work was paint and had been done by a singwriter.
Brian Morehen
Dave Halford13/02/2020 18:43:10
2536 forum posts
24 photos
Posted by Steviegtr on 13/02/2020 18:09:15:
Steve.
Heat will soften oil mineral oil that has set.
I'm sure that machine may have once been in a school, but no school I know would have let it get in that state.
not done it yet13/02/2020 18:53:00
7517 forum posts
20 photos
Brake fluid now water based? That’s a new one on me. Silicone based, maybe.
Gavlar13/02/2020 19:02:52
119 forum posts
I bought it direct from the school and I can only assume they had it from new. It's the third time I've bought machinery from a school (different schools, different LEAs) and they are always quality machinery, poorly maintained in my experience.
I've got white spirits and brake fluid in the workshop, I'll go and apply some in a minute and leave it overnight. If that fails, I'll try the heat gun and/or oven cleaner tomorrow.
Thanks for the advice.
Edited By Gavin Freeman 1 on 13/02/2020 19:04:46
Steviegtr13/02/2020 19:13:05
2668 forum posts
352 photos
Posted by not done it yet on 13/02/2020 18:53:00:
I stand corrected. Goes back to when I had a new Cherokee jeep. The master cylinder was leaking onto the bulkhead. I had it fixed under warrantee. The guy said it will not damage paintwork. It is water based now. Like car paint. That must be where I got that from. God 2003. where did time go.
Andrew Evans13/02/2020 20:08:32
366 forum posts
8 photos
Jizer
colin vercoe13/02/2020 20:10:30
72 forum posts
We used to clean machines in an industrial environment lathes milling machines etc using a product called Elbow Grease which is water based and very similar to Flash floor cleaner, Morrisons also do their own very similar product called Citrus Shine, most of the dirt that a machine collects is water based eg coolant etc and this worked very well especially if soaked and then agitated with a soft dust pan brush.
Mike Crossfield13/02/2020 20:29:44
286 forum posts
36 photos
I’ve always found that white spirit is the best common solvent for cleaning up old machinery. Helps to let it soak in well before scrubbing off. Old tooth brush is a good tool for this job.
+1 For Elbow Grease. A good general purpose water-based degreaser in a spray bottle, and cheap as chips. I used to stock up on it every time I went North to visit my old Mum in Lancashire, but since her demise I despaired of finding it in my adopted South. However I was delighted to find recently that my local Range stocks it. £1 a bottle.
mgnbuk13/02/2020 20:36:51
1394 forum posts
103 photos
I clean new arrivals at work with this
Dilute with water & apply with a trigger action spray, leave to soak in, agitate with a brush & wipe off the residue with paper towels. Repeat as required. It does tend to dull gloss paint, but doesn't remove it or appear to degrade beyond taking the shine off. Being water based it also rehydrates water based coolant residues (which solvent degreasers tend to struggle with), then breaks them down so no oily film afterwards.
It is caustic, so wear rubber gloves & eye protection.
Nigel B.
Chris Evans 613/02/2020 21:10:10
2156 forum posts
I have used "Traffic Film Remover" a variety of brands available, agitated with a washing up brush. Apply with a trigger spray.
Howard Lewis13/02/2020 21:17:03
7227 forum posts
21 photos
My first attempt would be with white spirit, since that is more easily available than kerosene.
Deb Chemicals used to market a product called Jizer, which could be washed off with water. Possibly a runny cousin of Swarfega?
All these may be like the beer that can reach places that others cannot!
Hopper14/02/2020 00:42:10
7881 forum posts
397 photos
Brake fluid WILL eat paint. Big time. (Unless it's the rather rare DOT 5 silicone brake fluid)
Brake fluid is NOT water based. Ever.
Spray-can degreaser from the auto parts store and a small wire brush will remove anything oil/grease-based. You might have to let it soak overnight etc. Finish off with soapy water using laundry detergent to remove the degreaser and residue.
Brian Morehen14/02/2020 08:50:53
191 forum posts
11 photos
Try Gunk engine Degreaser , Brush it on and let it soak it then rub it off with a dry then finish with a damp cloth or hose of and dry will look like new
Brian Morehen
old mart14/02/2020 09:43:27
4655 forum posts
304 photos
I would lean towards soaking in Jizer or Gunk rather than brake fluid. Cillet Bang is a strong cleaner, but needs to be rinsed off very well with water, as it is corrosive.
Perko714/02/2020 10:39:14
452 forum posts
35 photos
You could also try the cleaners used by bicycle mechanics to get congealed crud off bike components, they seem to be organic based and are kind to paintwork including powder coating and ordinary enamels. Failing that my go-to would be kerosene and an old stiff paint brush. Kerosene is pretty easy to get in Australia in 1litre, 4litre and 20litre containers from most hardware/handyman/motor accessory stores.
Samsaranda14/02/2020 15:20:51
1688 forum posts
16 photos
Agree with Hopper, brake fluid will definitely not be water based as the heat generated in braking systems would boil the water = disaster i.e. no brakes.
Dave W
