Left handed lathe.
Anthony Knights01/02/2020 10:53:15
681 forum posts
260 photos
Because the majority of the population is right handed, I assume this is the reason every lathe I know of has the headstock on the left. If the majority of people were left handed, would lathes have the headstock on the right? Also, would a "normal" screw thread be left handed?
Bob Stevenson01/02/2020 10:58:31
579 forum posts
7 photos
There's a cultural influence too and there was, in the past, a considerable German interest in keeping the headstock to the right hand side, indeed many German users of watchmakers and 'precision' lathes still do so....still others, mainly German, use watch lathes with the tailstock to their chest and several makers still make lathes like this for fine work.
mechman4801/02/2020 11:41:15
2947 forum posts
468 photos
I'm right handed but I have used a left handed monkey wrench ...devil face 20
Geo.
not done it yet01/02/2020 11:56:00
7517 forum posts
20 photos
I’ve got a left-handed digi caliper - and I am right handed. Just so much easier to measure items while in the lathe chuck.
Lots of machinery was historically always made right handed. I doubt if many pairs of scissors were left handed until fairly recently? I know that circular sock knitting machines were all right-handed, until someone started making some for lefties within the last ten years.
The armies didn’t want infantry with guns, or spears, or bows, being used cack handed!
Dave Halford01/02/2020 12:04:20
2536 forum posts
24 photos
Posted by not done it yet on 01/02/2020 11:56:00:
Had a pair of those in the 70's, hard to use for a 'righty'.
Speedy Builder501/02/2020 12:30:00
2878 forum posts
248 photos
handy if you have to thread up to a shoulder
Bill Phinn01/02/2020 12:56:13
1076 forum posts
129 photos
Until the age of 21 I was right-handed. Since then, owing to an accident, I have had to be left-handed.
Some things that would be more convenient for me on your left-handed lathe:
sliding the tailstock along the bed and probably all other manipulations of the tailstock apart from inserting or removing drills etc.;
Cranking the compound-slide handle.
Some things that would be less, not more, convenient on your left-hand lathe:
locking and unlocking a typical jawed chuck;
Inserting and removing drills etc. into and from the tailstock quill;
Accessing gears or other things inside the gearbox casing;
Operating the on-off switches, speed-control dials, quick-change gearbox levers et al.
It's not lathes where I really feel the need of a left-handed machine, but mills and drills, since cranking a right-located handwheel to raise and lower the head, cranking the x-axis handwheel on a milling table having a single [always right-positioned?] handwheel, and lowering the quill [coarse feed on a mini-mill] are genuinely troublesome for me, especially the first two of these.
Nigel McBurney 101/02/2020 13:40:58
1101 forum posts
Did left hand position of the headstock originate from wood turning where it was convenient for the right handed majority to steady the wood turning chisel in the left hand and control and push to the left with the right hand.
50 odd years ago i spent a month in a German factory learning about a product to be transferred to a uk factory,in their toolroom they had bench vices wih a fixed rear jaw (closest to the operator0 and square headed hammers
IanH01/02/2020 14:21:03
129 forum posts
72 photos
If you look here...
you will see President Tito of the former Socialist Federal Republic of Yugoslavia using what is clearly a left handed Myford Lathe.....
I spotted this a few year ago when visiting Brijuni, Tito's summer residence. This photo is a part of a large photographic archive displayed on the island. The back to front lathe caught my eye, but on closer inspection I realised that in the photo he is wearing his watch on the wrong wrist, so I concluded that this photo is in fact printed back to front and the left handed Myford a mirage!
I helpfully pointed this out to the guide who was very sceptical until I was able to show that in every other photo where his watch was visible, he wore it on the other wrist. Strangely the guide did not seem too pleased that I had pointed this out and I was ushered out of the room. Clearly the message didn't get through to the web site designer.
Ian
Bill Phinn01/02/2020 14:36:46
1076 forum posts
129 photos
Interesting stuff, Ian.
The clincher is that the "Made in England" on the side of the lathe reads in reverse.
Georgineer01/02/2020 16:29:28
652 forum posts
33 photos
Posted by IanH on 01/02/2020 14:21:03:...in the photo he is wearing his watch on the wrong wrist, so I concluded that this photo is in fact printed back to front...
Ian - in every photo of me, I am wearing my watch on the wrong wrist. Does that mean I was printed back to front? My wife says that would explain a lot.
Papplewick Pumping Station has a lathe in the workshop - pre-war German I believe. I was told when visiting that, although its headstock is on the left, all its controls operate in the opposite way to usual, which is the nearest I have seen to a left-hand lathe.
That's as bad as the monstrosities sold as left-hand scissors, which are actually right-hand ones with a deeply moulded left-hand grip, so are no use to anybody. After a lifetime using right-hand scissors I simply can't get on with the left-hand ones, though left-hand calipers were a revelation. I do have a small number of left-hand pencils. Yes, really!
George B.
Enough!01/02/2020 16:39:42
1719 forum posts
I suppose a left handed lathe would have to rotate in the opposite direction .... and screw-on chucks would have to have the opposite thread?
martin perman01/02/2020 16:58:32
2095 forum posts
75 photos
Posted by mechman48 on 01/02/2020 11:41:15:
Geo.
A friend of mine collected over 600 hundred adjustable spanners over the years, all different and from all over the world, and he had a left handed one, as a left hander myself life has been a pain, particularly with electric hand tools, that has to be endured but then we are supposed to be more artistic and creative.
Martin P
Enough!01/02/2020 17:05:08
1719 forum posts
I didn't even know there are left-handed monkeys (let alone that they use wrenches). What a great source of information this forum is!
wink
Mike Poole01/02/2020 17:05:38
3676 forum posts
82 photos
Left handed people simply have their brain in upside down.
Nick Clarke 301/02/2020 17:15:23
1607 forum posts
69 photos
I am cross lateral - ie left eye dominant but right handed. when I was younger I always used Exacta or Exa cameras because the winder was on the left - a right handed camera such a Nikon found me poking my eye out when winding on.
I don't shoot anymore but when I did I used to frighten people trying to use a right handed shotgun sighting with my left eye - I appeared to be shooting round a corner and it worried those next to me where exactly it was pointed!!
martin perman01/02/2020 17:15:32
2095 forum posts
75 photos
Obviously the view point of a righthander smiley
martin perman01/02/2020 17:24:12
2095 forum posts
75 photos
When in the ATC we had .303 rifles whose bolt was on the right side, when I used one I sighted with my left eye,stock in my left shoulder and right hant supporting the barrel, all well until I had to reload as passing my arm and hand over the top to operare the bolt was not easy.
Martin p
old mart01/02/2020 20:40:27
4655 forum posts
304 photos
I am left handed, but only use my left hand exclusively for writing, otherwise it is whichever hand is more convenient. The only thing which I think is essential if you are left handed are scissors. One day I will buy one of the left handed digital calipers, but only because they are easier for anyone using a lathe. I feel sorry for anyone, right or lefthanded who cannot manage 95% of things with either hand.
martin perman01/02/2020 21:06:14
2095 forum posts
75 photos
Posted by old mart on 01/02/2020 20:40:27:
To answer your last comment I can hold tools but dont have a lot of coordination, put a knife in my right hand and I become dangerous smiley
Martin P
