lfoggy | 20/01/2020 21:25:53 |
![]() 231 forum posts 5 photos | I have just aquired a rather nice Starrett #650 'back plunger' type indicator. I've never used one of these before as I have always used the more conventional dial indicators and lever type dial test indicators. The back plunger type seem more common in America maybe. Any tips or comments on their use? Any advantages over the more usual types for general workshop indicating? |
Howard Lewis | 20/01/2020 21:34:47 |
7227 forum posts 21 photos | Very occasionally, I use one. They can save a lot of craning of the neck in some situations. Howard |
Mike Poole | 20/01/2020 21:38:27 |
![]() 3676 forum posts 82 photos | Can be handy for jobs like mill head tramming as the face is always in view. Mike |
Mick B1 | 20/01/2020 21:45:28 |
2444 forum posts 139 photos | I worked for Baty's for a couple of years in the '80s, and as far as I know there were none in their very extensive and practically unplannable dial gauge range then. I'd guess they'd probably have to use a helical worm rather than a rack and pinion to drive the hand in a different plane, and that might be more expensive to make and harder to maintain. |
Clive Foster | 20/01/2020 21:55:30 |
3630 forum posts 128 photos | As Howard says the angle of view can be better than a conventional plunger type in many machine set up applications. Especially if you have the full set of Starrett (or other make) accessories. Ultimately the standard plunger style indicator is intended for quality control purposes when mounted in a stand rather than machine set up. Which doesn't stop it doing a perfectly good job when needed but I suspect folk who have properly learned to exploit the back plunger type may get along a little better. Hafta say I grabbed my Starrett Last Word set with all the bits very cheaply (probably due to it being stuffd into a three layer pencil case rather than a proper box) maybe 30 years ago thinking "This will be very useful.". Yup so useful that I've literally never used it! That said my 5 standard stye ones average around 2 or 3 outings a year at most. The lever types and Blake Co-Ax knock off do all the heavy lifting. One thing in the set that really out to be useful is the "extender seesaw" thingy which can be poked something approaching 2 1/2 inches down a bore. Clive Edited By Clive Foster on 20/01/2020 21:56:05 Edited By Clive Foster on 20/01/2020 21:56:22 |
Steviegtr | 20/01/2020 22:06:27 |
![]() 2668 forum posts 352 photos | I wouldn't mind one in my workshop. |
Ian Johnson 1 | 20/01/2020 22:35:19 |
381 forum posts 102 photos | I've got a nice Mercer which is only really used for tramming the mill tables, easy to see the dial face. Other than that particular job I can't see any advantage of using a back plunger dial gauge rather than the usual type or Verdict lever type. Ian
mark costello 1 | 21/01/2020 17:48:53 |
![]() 800 forum posts 16 photos | Works well for tramming in a vise also. use one all the time. |
Brian G | 21/01/2020 18:36:25 |
912 forum posts 40 photos | I nearly bought one at Christmas (Amazon had some seriously silly price reductions of 75% or more) thinking the "see-saw" deep hole attachment looked handy but in the end went for a vertical dial DTI which, like the back plunger indicator, can also be read in any position on the mill. I have to say though, US made Starrett kit always looks and feels lovely, especially in the padded jewellery boxes. Brian G |
Tony Pratt 1 | 21/01/2020 19:07:29 |
2319 forum posts 13 photos | 50 odd years machining & I can't recall ever having used one. Tony |
Sandgrounder | 21/01/2020 19:25:08 |
256 forum posts 6 photos | Posted by mark costello 1 on 21/01/2020 17:48:53:
Works well for tramming in a vise also. use one all the time. I do as well and I know now what it's called. John |
thaiguzzi | 22/01/2020 15:20:54 |
![]() 704 forum posts 131 photos | Posted by mark costello 1 on 21/01/2020 17:48:53:
Works well for tramming in a vise also. use one all the time. +1. Use mine for tramming the mill and shaper vises in. Dial face is staring straight at me. |
Bob Unitt 1 | 22/01/2020 16:32:17 |
![]() 323 forum posts 35 photos | I use these all the time, never owned a lever-type. One is a Mercer in a fitted case with all the trimmings, and I have a couple of others from car-boot sales, permanently fitted to various bits of equipment. |
