sean logie | 23/12/2019 10:39:13 |
![]() 608 forum posts 7 photos | Am I right in saying I will only need to use red and yellow wires for the new thermostat ?
Merry xmas
Emgee | 23/12/2019 11:55:01 |
2610 forum posts 312 photos | Hi Sean Red would usually be live supply in and yellow the live switch wire back to the programmer, neutral used on the old stat as it had a heater included within the mechanism. Emgee |
Vic | 23/12/2019 13:51:02 |
3453 forum posts 23 photos | A wired Thermostat, how quaint! Only joking, we only switched over to wireless earlier this year when we had a new boiler fitted. |
Stuart Smith 5 | 23/12/2019 14:01:28 |
349 forum posts 61 photos | As emcee says, red should be live, yellow with red sleeve switched live to boiler and blue would be neutral on an old style thermostat. So red to A, yellow with red sleeve to B and terminate the unused blue in an insulate terminal block.
sean logie | 23/12/2019 15:24:18 |
![]() 608 forum posts 7 photos | Thanks everyone .
Merry xmas Sean |
David George 1 | 23/12/2019 15:37:00 |
![]() 2110 forum posts 565 photos | Dont forget to conect the green and yellow to the metal box pattress. David |
Anthony Knights | 25/12/2019 06:23:45 |
681 forum posts 260 photos | My recently installed gas central heating has a portable thermostat with a radio link to the boiler. It does however read 2 degrees higher than any of the thermometers I have in the house. I wonder if it has been "adjusted " by the eco-police. |
David George 1 | 25/12/2019 07:00:12 |
![]() 2110 forum posts 565 photos | I have the same setting problem I have to set wireless thermostat 2 degrees higher to old style thermometer at the side of it. David |
Norfolk Boy | 25/12/2019 07:54:05 |
74 forum posts 18 photos | wonder if it has been "adjusted " by the eco-police. Well yes to some extent. Modern stats are intelligent (not ). They use a type of fuzzy logic. Old stats had a neccessarily wide hysteresis loop which meant if the stat was across the room from the heat source it took a while to react to the rise in temperature and even when the stat turned off thevtemperature would still climb as the heat source still outputting at that point. New stats predict this effect so will turn the heat of and on a few times before desired temp is reached. this wil vary with the amount of temperature difference demanded by the user. the end goal being not to overshoot required temperature. Alan Edited By Norfolk Boy on 25/12/2019 07:59:19 |
