Meddings Pillar Drill, VFD and referb
petro1head06/12/2019 12:57:02
984 forum posts
207 photos
The VFD works fine when the motor is not connected. As soon as i connect it and power on the VFD it immediately trips the fuse.
i have checked to motor winding etc and all is fine, plus the motor was working fine before i /bought it, connected to 3 phase supply.
looking at the wiring under the motor over, where the supply enters, it looks like its setup in a star config.
any thoughts?
Edited By petro1head on 06/12/2019 13:13:03
Brian H06/12/2019 13:04:29
2312 forum posts
112 photos
Are you working on 240 or 415 volts?
Ian P06/12/2019 13:04:41
2747 forum posts
123 photos
Can you clarify what you mean by 'connected' and 'connect' in the first sentence. (ie it worked when connected, but not when you?)
Ian P
petro1head06/12/2019 13:14:00
984 forum posts
207 photos
240V
I have aditied the first post and added Not
not done it yet06/12/2019 13:15:56
7517 forum posts
20 photos
Also what do you mean by ‘trips the fuse’. Fuses ‘blow’. MCBs trip and can be reset. Is this the mains supply or just the local plug-top fuse? Does the VFD run without the motor connected? Are you switching on the supply to the VFD with it programmed to start the motor at switch-on ( not a good idea)? Are you using the machine switch, not the VFD start button?
petro1head06/12/2019 13:22:20
984 forum posts
207 photos
Sorry, yes trip the MCB
VFD works fine without the motor connected
The motor is connetcted directly to the VFD, no switch, so I just power the VFD on
This is the VFD I am using VFD
Oldiron06/12/2019 13:23:05
1193 forum posts
59 photos
A photo of the motor plate & connection box wiring layout would help someone determine or at least point to any obvious errors.
Make/model of VFD ?
By "VFD working fine" do you mean it just powers up or have you tested it for output.
Have you set up the VFD to match the motor specs ?
regards
Dave Halford06/12/2019 13:28:54
2536 forum posts
24 photos
Too much inrush current for the MCB? Set the VFD for soft start.
Emgee06/12/2019 13:28:55
2610 forum posts
312 photos
Can you confirm if it is a fuse rupturing or an mcb tripping, also state size and type.
The rating of the fuse or mcb could be too low for the load or the motor may have an line to earth fault.
If supply is 240v to the VFD you will as a rule be getting 220v 3 phase output so your motor needs to be connected in Delta form for the lower voltage to function at rated power.
Emgee
petro1head06/12/2019 13:39:50
984 forum posts
207 photos
See previous post for VFD Make/Model
Not tested for output
Setup, hmm good question. Just using using default settings. Oh god I can hear you swearing at me now
Edited By petro1head on 06/12/2019 13:44:53
petro1head06/12/2019 13:51:45
984 forum posts
207 photos
petro1head06/12/2019 13:52:10
984 forum posts
207 photos
Posted by Emgee on 06/12/2019 13:28:55:
Emgee
MCB
Well done, sorted.  Now wired in Delta config and working thanks
Edited By petro1head on 06/12/2019 14:01:30
Emgee06/12/2019 13:59:45
2610 forum posts
312 photos
Although all cable ID's are shrouded I agree looks like connected for 400v working, remove links and fit top to bottom as pictured.
What rating and type is the mcb ?
Emgee
petro1head06/12/2019 14:02:29
984 forum posts
207 photos
Posted by Emgee on 06/12/2019 13:59:45:
Emgee
See above
To be honest a bit confused by Star vs Delta
Oldiron06/12/2019 14:07:16
1193 forum posts
59 photos
Is that motor dual voltage ? Cannot see lower voltage on the plate. Correct me if I am wrong.
petro1head06/12/2019 14:09:25
984 forum posts
207 photos
Just 410
Oldiron06/12/2019 14:25:09
1193 forum posts
59 photos
Oh. Check your speeds as it will only probably run at 2/3 speed on 230v and will probably stall if any load is applied.
Extract from Inverter drive website. The motor must now be considered as a 230V x 29Hz motor as far as data entry into the Inverter Drive is concerned. The Full Load Current will be that stated on the nameplate for 400V.
If the maximum speed is set to 50Hz or more, the Motor may possibly reach these speeds, but it will become progressively "Under-Fluxed" (Torque will reduce). However, this will only be evident if the Motor is fully loaded. If it is, the Motor will look for more current to meet the load. A correctly set Inverter will provide protection against over-Current by reducing the speed automatically to bring the load current under the maximum set.
It is important to note that when the Inverter output voltage does not match the Motor rated voltage, the drive should match or exceed the Motor full load current (not kW).
The link to your inverter is blocked by my malware software so could not check it out. You will need to really study your VFD settings to get much use out of that motor.
I hope this has not put the cat amongst the pigeons.
regards
Edited By Oldiron on 06/12/2019 14:31:16
Andrew Johnston06/12/2019 15:29:22
7061 forum posts
719 photos
Posted by Oldiron on 06/12/2019 14:25:09:
Indeed it has, but the pigeons are mobbing the cat. smile
The speed of an induction motor is determined mainly by the applied frequency, and to a much smaller extent by the load. The speed is unaffected by the motor being connected in star or delta. However, if you apply 240V to a motor in star, and designed to run at 415V, then the phase currents will be lower. In theory the currents will be lower by the square root of 3. To a first approximation the torque of an induction motor is proportional to phase current. Power is torque times angular velocity. So for a motor connected in star, but running at 240V instead of 415V, the angular velocity will be the same, but the torque, and hence power, will be reduced by a factor of root 3.
Summary: The motor should run fine on 240V, but the available torque and power will be reduced.
petro1head06/12/2019 15:49:54
984 forum posts
207 photos
Try this link which is now public in my Google Drive VFD Manual
Pete Rimmer06/12/2019 16:02:23
1486 forum posts
105 photos
Star or delta connection should not have a bearing on the fault you were getting, but I see evidence of burning to the right of the connector block. I don't think that you can safely assume that this fault is fixed.
