Tony Scott | 19/11/2019 13:56:13 |
13 forum posts | Hi, I'm trying to put the original single phase motor back on to myford ml7 but I can't find the retaining clips, can these be bought? If yes would you send me the link please. I've tried searching but I can't find the item, maybe I'm using the wrong description. |
geoff warner 1 | 19/11/2019 14:00:28 |
12 forum posts | hi tony can you describe these clips i possibly may have some is the motor on resiliant mountings geoff warner |
not done it yet | 19/11/2019 14:35:37 |
7517 forum posts 20 photos | Have you tried contacting Myford? |
Tony Scott | 19/11/2019 14:56:49 |
13 forum posts | I haven't actually thought about that. I didn't consider this to be a solely myford problem just a motor issue. I'll give them a call later.
john fletcher 1 | 19/11/2019 15:46:18 |
893 forum posts | I'll be surprised if any one sell them, not many fail or get lost, tricky things to make. If you need the rubber/ plastic replacement resilient mountings, I suggest you go to your local motor factors and have a look. at their selection of exhaust mounts. |
Martin Kyte | 19/11/2019 16:17:53 |
![]() 3445 forum posts 62 photos | Not really sure what you are after but does this help? regards Martin Edited By Martin Kyte on 19/11/2019 16:18:18 |
mark smith 20 | 19/11/2019 17:03:37 |
682 forum posts 337 photos | I think hes refering to the clamp /clips with the nuts on that go on either end to fix the motor onto the cradle. Like in this thread. |
noel shelley | 19/11/2019 17:23:38 |
2308 forum posts 33 photos | Hi Tony, The rubber sleeve you will not find at a motor factors, and it is unlikely You will get the clamps from myford. There were numerous makers of motors with resilient mounts. Brooks, Hoover Etc. A motor rewind specialist is your best bet. Try yellow pages or the modern equivelent ! Good Luck, Noel. |
ega | 19/11/2019 17:30:05 |
2805 forum posts 219 photos | Posted by mark smith 20 on 19/11/2019 17:03:37:
I think hes refering to the clamp /clips with the nuts on that go on either end to fix the motor onto the cradle. Like in this thread. Tony Scott: I have a complete mount from a Hoover brand motor which might solve your problem; the between centres distance clip to clip is about 218mm. PM me if you want to pursue this. |
Tony Scott | 19/11/2019 17:39:06 |
13 forum posts | This group is so helpful. Ega, you are correct with the bits, it's just the clips that I need, I've put mine somewhere safe...... 😂 Can't recall where it is though so I consider them lost. |
john fletcher 1 | 19/11/2019 17:52:24 |
893 forum posts | Strange, I got my resilient rubber mountings from one of our local motor factors, and I have couple of spares hanging up in my workshop. |
Howard Lewis | 19/11/2019 20:41:49 |
7227 forum posts 21 photos | The rubbers provide a resilient mounting to isolate the vibration from the single phase motor from the rest of the machine, and to reduce noise. Bodger's methods! If the rubbers for the single phase motor have failed, probably because of oil contamination over the years) you could try an O ring of suitable size section. Cut to length to fit the groove. The material of the O ring may well have better oil resistance than the original. The clips are unlkely to be available, especially since they were probably made to Imperial dimensions, rather than the current Metric . I had a motor with a top half clip missing. I made a replacement. Not difficult. possibly; half and hours work. The bottom half of the seat for the rubber is in the motor mount, so you only need to make the top half. It may not be quite as pretty as the original, but it is only required to do the job, unless you mean to enter the motor in a concours d'elegance! Howard
Edited By Howard Lewis on 19/11/2019 20:42:57 |
ega | 19/11/2019 23:11:10 |
2805 forum posts 219 photos | Posted by Tony Scott on 19/11/2019 17:39:06:
This group is so helpful. Ega, you are correct with the bits, it's just the clips that I need, I've put mine somewhere safe...... 😂 Can't recall where it is though so I consider them lost. If you want the clips,I suggest we deal with this via PM and/or email; I would need your address of course which I am assuming is in the UK. |
Emgee | 19/11/2019 23:19:00 |
2610 forum posts 312 photos | An alternative retaining clip could be made from a Jubilee clip in an emergency. Emgee |
not done it yet | 19/11/2019 23:43:50 |
7517 forum posts 20 photos | Is it just a strip of curved metal with a right angle bend and bolt hole at one end, and a slot near the other? Not too difficult to sort out (at the second or third attempt, maybe |
Tony Scott | 25/11/2019 21:41:40 |
13 forum posts | Looks like I'll be making something up. Thanks for help Ega. This forum is really helpful and friendly.
Michael Gilligan | 27/11/2019 08:28:58 |
![]() 23121 forum posts 1360 photos | Tony, Sorry to be late to the discussion, but ... I just remembered that I have this photo from when I bought my ML7R . I hope it’s some help. MichaelG. |
Nick Hughes | 27/11/2019 14:49:42 |
![]() 307 forum posts 150 photos | Even later to the party, Remco list them as "Latches for resilient mounting rings" on page 84 of this catalogue:- |
Tony Scott | 21/12/2019 14:50:52 |
13 forum posts | I've just got back to this page, thanks again for updates, I have made the clamps now, they're not perfect but they do the job.
not done it yet | 21/12/2019 15:00:56 |
7517 forum posts 20 photos | They may not be perfect but they may well do the job perfectly. I expect the second one was easier than the first? Next time you might just make them together! Just confidence and experience (I might well make three - one as a quick trial, then two together). Still a job well done, all the same. |
