Brian H | 04/11/2019 18:07:37 |
![]() 2312 forum posts 112 photos | I'm hoping that one (or more) of our electrical boffins can help me with this one. I have done this task successfully where there have been links to remove and replace but I've now come across a different system. The motor is a Brook Crompton Parkinson 1.5kw one and normally sits in the base of a Tom Senior Major Mk 2 ELTmilling machinel. I eventually managed to remove the motor which has a plate stating that is is 220/380-420 volts and alongside this are the Delta & Star symbols. When I opened up the junction box on the motor I found 4 terminals plus earth. 3 of the terminals were for the individual phases with one black wire to each from inside the motor. The other terminal had 3 black wires from inside the motor all connected to the one terminal. I have a 240v 3 phase inverter rated at 1.5kw, how do I connect it to the motor? Any help will be most welcome! Brian |
John Haine | 04/11/2019 18:18:30 |
5563 forum posts 322 photos | Aha! You need to...
Emgee | 04/11/2019 18:28:31 |
2610 forum posts 312 photos | Brian The 3 black wires on the same terminal will be the ends of the windings, if there are no markings at all you will have to identify the pairs of windings so you can connect in delta mode. If you have an ohm meter you can remove the 3 wires and separate the ends, then check across the end of 1 and find it's mate still connected on the terminal block, mark the 2 with some number so you know they are a coil. If someone doesn't beat me to it I will post a drawing on further connections and links. Emgee John beat me to it again so follow his advice.
Edited By Emgee on 04/11/2019 18:29:52 |
Brian H | 04/11/2019 19:37:04 |
![]() 2312 forum posts 112 photos | Many thanks John & Emgee. I've now cleaned the areas and can see that there are tags on the wires. The wires on the individual terminals are marked U1, V1 & W1. The 3 wires on the other terminal are marked U2, V2 & W2. I have dismantled the motor further and found that the bearing just behind the pulley is siezed and have removed this. It is marked 6205Z which I know is an easily obtained one. I'm assuming that the other bearing will be the same but will remove the nylon fan and end cover to check. Any suggestions on removing these without damage? Brian |
noel shelley | 04/11/2019 19:41:55 |
2308 forum posts 33 photos | Hi Brian, I may be telling you what you already know but To reverse the rotation just swap any two incoming phases. Though if your using an inverter then this may not be needed. Good luck, Noel. |
noel shelley | 04/11/2019 19:45:16 |
2308 forum posts 33 photos | And then-- When ordering the bearings tell the supplier that there for an electric motor and likely will be C3 fit. Noel. |
Brian H | 04/11/2019 20:02:44 |
![]() 2312 forum posts 112 photos | Many thanks Noel, yes, I knew about swapping 2 wires and the bearings I've ordered are C3 but I'm very grateful to you for replying. Brian |
Brian H | 04/11/2019 22:22:37 |
![]() 2312 forum posts 112 photos | Just to confirm that I have understood correctly.....do I then connect each of the phases from the inverter to the same terminals that I connect both ends of the coils to? Brian |
Vic | 04/11/2019 23:13:47 |
3453 forum posts 23 photos | I had a Brook Crompton three phase motor on my Elliot Omnimill and after rewiring from star to delta I ran it on single phase with just a capacitor between two of the phases. You only get about 80% of the rated power but I never noticed the mill struggle. |
Emgee | 04/11/2019 23:48:10 |
2610 forum posts 312 photos | Brian U1, V1 and W1, the original terminals that were connected, Emgee |
peak4 | 05/11/2019 02:00:22 |
![]() 2207 forum posts 210 photos | Posted by Emgee on 04/11/2019 23:48:10:
Brian U1, V1 and W1, the original terminals that were connected, Emgee Emgee, I'm not quite sure what you meant to say there, but I'm not sure it came out right in print. 3 individual windings U, V, & W, each with ends 1&2 and all end 2s currently commoned together in Star formation. To transform to Mesh (i.e. Delta), whilst still maintaining the correct orientation of each coil, as follows. Leave U1, V1, & W1 where they are, U2 goes on top of V1, V2 on top of W1, and W2 on top of U1 Bill
Bill |
Emgee | 05/11/2019 08:10:50 |
2610 forum posts 312 photos | Sorry Bill, I apolpgise for my bad description, yes you only have 3 terminals and 3 incoming wires to connect so 1 phase on each is the only option. Emgee |
Brian H | 05/11/2019 08:58:43 |
![]() 2312 forum posts 112 photos | So, please excuse me for being pedantic but; Quote Leave U1, V1, & W1 where they are, U2 goes on top of V1, V2 on top of W1, and W2 on top of U1 So the end of one coil is connected to the start of the next coil? Brian |
Micky T | 05/11/2019 09:26:48 |
![]() 76 forum posts 29 photos | Hi Brian that is correct the end of one coil is connected to the start of the next
Mickyt |
Brian H | 05/11/2019 10:14:52 |
![]() 2312 forum posts 112 photos | Thanks for clarifying Mickey, and thanks to all who replied. Wonderful Forum this! Brian |
not done it yet | 05/11/2019 10:24:53 |
7517 forum posts 20 photos | One can consider it as connecting them in series, but being careful that each coil is pulling in the same direction as the others. What one does not want is one coil connected such that it is opposing the the other two! |
Mike Poole | 05/11/2019 13:41:51 |
![]() 3676 forum posts 82 photos |
A picture can be worth a thousand words.
Mike Edited By Mike Poole on 05/11/2019 13:42:06 |
Brian H | 05/11/2019 14:51:54 |
![]() 2312 forum posts 112 photos | Many thanks Mike, that very helpful. Brian |
Emgee | 05/11/2019 16:18:37 |
2610 forum posts 312 photos | Brian, nice clear detail in Mike's picture, are you up and running now ? Emgee |
Brian Oldford | 05/11/2019 17:27:27 |
![]() 686 forum posts 18 photos | Posted by not done it yet on 05/11/2019 10:24:53:
One can consider it as connecting them in series, but being careful that each coil is pulling in the same direction as the others. What one does not want is one coil connected such that it is opposing the the other two! Been there, done that.
Edited By Brian Oldford on 05/11/2019 17:27:56 |
