Cheap ER collet advice please
Charles R13/10/2019 22:34:57
24 forum posts
15 photos
I need to get a set of ER25 collets.
I've been looking at the cheap Chinese offerings on eBay.
I realise this is a bit of a lottery as some people appear to be happy with their purchases and others, not.
The quality of these collets seems to vary a lot.
Has anyone here bought a good cheap set and if they have, can you let me know what seller they were bought from?
From what I've seen, pretty much all of them seem to be located /shipped from Leicestershire irrespective of who's selling them!
Any advice much appreciated, thanks.
Mike Crossfield13/10/2019 23:03:41
286 forum posts
36 photos
I’ve bought ER25 collets a couple of times from CTC and been very happy with the quality and price. The chap running the operation in China, a German, was very helpful when I had some queries and wanted a special size. In my experience, accuracy doesn’t seems to be far from the stated 0.4 thou runout with everything carefully cleaned.
Emgee13/10/2019 23:11:44
2610 forum posts
312 photos
Charles
I bought a set of ER25 2-16mm in Dec 2018 for £14.99 from worldtrade100
I needed an additional 16mm at the time and saw these when searching, used it for a 4f carbide cutter roughing out some aluminium, worked OK.
Have checked some other sizes and they appear to be as accurate as indicated in the listing.
Emgee
Charles R14/10/2019 00:20:30
24 forum posts
15 photos
Thanks for the replies and help, Mike and Emgee.
Mike...haven't heard of CTC before, so just had a quick search...would this be www.ctctools.biz ? I'm guessing you've been buying collets individually, as and when needed?
Emgee...that's an excellent price but unfortunately the seller currently has no items for sale though I will definitely keep an eye out for new listings.
Enough!14/10/2019 00:45:39
1719 forum posts
Posted by Mike Crossfield on 13/10/2019 23:03:41:
+1
Bill Pudney14/10/2019 02:45:17
622 forum posts
24 photos
Posted by Bandersnatch on 14/10/2019 00:45:39:
+1
I've bought both ER11 and ER32 collets and chucks from CTC, as well as other stuff...boring head, cutters etc. All good gear. Once again I have no doubt that there is better quality stuff available, but all of CTC kit has been fit for purpose. My only problem with CTC is that delivery can take a while, not as quick as Arc Euro for instance.
cheers
Bill
Tony Pratt 114/10/2019 06:51:05
2319 forum posts
13 photos
I see CTC actually give a tolerance run out of .008mm, if they don't meet that standard you can get your money back [Paypal - item not as described, credit card - chargeback] so a win win situation. They would also have to pay postage if they wanted the collet[s] back.
Tony
not done it yet14/10/2019 07:14:15
7517 forum posts
20 photos
My advice, and it is free so as cheap as you can get, is not to go the bang good way.
Collets all needed checking and most needed fettling before use, but seem to be satisfactory now. However the collet holder was scrap. It HAD be replaced because it WOULD have destroyed both my cutters and my machine spindle.
That made buying from them no less expensive than buying better quality from elsewhere.
ER collets are a precision system. No better than your machine when in use, but can maintain your overall system TIR to the minimum attainable.
People often use them for items where workpieces are removed from and refitted to the collet, expecting concentricity. Generally far better than most 3 jaw chucks, but if you are relying on good concentricity (on replacement in the collet) buy good ones. Buy from a reliable suppler who does not supply ‘out of spec’ items and with a good warranty record.
’Nuff said?
Baz14/10/2019 09:35:18
1033 forum posts
I am sure that it’s been said before but I feel it needs repeating, you get what you pay for, pay next to nowt and you will get rubbish, pay a good price and you will get good stuff, pay top dollar and you get top quality.
Former Member14/10/2019 09:42:35
1329 forum posts
Nick Clarke 314/10/2019 09:54:24
1607 forum posts
69 photos
Posted by Baz on 14/10/2019 09:35:18:
I think the other posts here suggest a slight modification to this sweeping statement - With items at the lower end of the market you cannot assume you are going to get an accurate quality product while with a branded one you ought to be able to.
Unfortunately in today's world you don't know where any product is manufactured and you may get an adequate or good item for little money, CNC makes it as easy to make something accurately as not, but at this point in the market quality control may pass out some that are not acceptable.
However by paying more the name on the box does not always guarantee quality. Trade names and brands are bought and sold and applied to items manufactured elsewhere. You can usually get an improved product from a branded supplier or manufacturer should you have an item you are not satisfied with, but it appears that some bargain brands are also doing this now.
Edited By Nick Clarke 3 on 14/10/2019 10:00:49
Vidar14/10/2019 10:04:08
57 forum posts
I've got 3 chinese ER8 collets. They are for a tiny tapping head, so I figured likely not the most critical application. Similarly I wouldn't be too worried if I were using them as holders of workpieces in a milling machine.
Anyway, I got my three direct from China. The point being that many of the sellers there do like the industry suppliers here: They offer ER collets with different tolerances and prices to match. So you can get what you pay for with ER collets from China too. (And knowing that they do checking and sorting the less expensive ones are likely the ones that failed the higher standards).
I'm with those above - you get what you pay for, and sometimes low initial expense comes at a cost too.
Charles R14/10/2019 10:18:25
24 forum posts
15 photos
Thanks everyone for their advice.
Charles R14/10/2019 10:25:11
24 forum posts
15 photos
Posted by Tony Pratt 1 on 14/10/2019 06:51:05:
Tony
Good thinking Tony...I need to get a set where there are claimed tolerances and if the collets are out of spec, then I can return them for a refund.
Edited By Charles R on 14/10/2019 10:27:06
Howard Lewis14/10/2019 10:30:13
7227 forum posts
21 photos
I bought my ER25 collets and holder from Chronos, about 20 years ago, and have had no problems.
My ER20 collets, used for drill grinding came from Arc Euro Trade.
With a supplier in your own country, if there is a problem, you have some hope of advice and a solution. From a low cost supplier thousands of miles away, I wouldn't expect too much interest or help.
Getting a set of low cost items may cost you material, frustration and stress, in the longer term; before you then lay out more money for decent quality.
F W I W, buy from a supplier with a good reputation, where you will get service after sales, if there is a problem.
SillyOldDuffer14/10/2019 10:37:51
10668 forum posts
2415 photos
Posted by 34046 on 14/10/2019 09:42:35:
With Baz on this one - extremely good advice.
Bill
Once good advice, I think that's too simple these days. The market is too diverse. For example, if you pay top dollar for an ER collet, what do you actually get for your money? What makes collets really expensive is their ability to spin at high rpm - up to 60000rpm in some cases. In addition to being accurately made, a specially strong steel is used, the collet is carefully balanced, and then individually tested and certificated. All this adds to the cost, and is a complete waste of money unless you do high-speed machining and own a suitable chuck.
Trouble with ebay is cost isn't much of a clue. The item might be a genuine bargain (many are) or it might be cheap and nasty. It might even be a fake. Ebay, Bangood and similar all offer potential savings but they're not as reliable as buying from a reputable source.
I buy from ebay whenever I'm happy to take a mild risk. Usually I've been happy with what arrived. Mostly I want more certainty from tools and buy from Tracy, ArcEuro, Warco and other Names because they put more effort into selecting products and meet their obligations if it goes wrong. Only rarely do I go to the bother of buying high-end tooling - for what I do the best available just isn't worth it.
Charles R14/10/2019 12:08:56
24 forum posts
15 photos
Dave...you should change your username to WiseOldDuffer!
I agree with you on all points.
My little lathe has a max speed of 1050rpm, so no need for me to buy high end where balance and precision are crucial.
I haven't heard of Tracy but will have a look later today.
Charles
mechman4814/10/2019 12:58:51
2947 forum posts
468 photos
I have a selection of ER25 collets & holders bought from CTC & ArcEuro & have found them to be of satisfactory quality for what I make so would concur with some of the comments from other users,I have also had a lot of other items from ArcEuro, so can only suggest you look at them, plus you will have the advantage of direct contact with the retailer should anything be unsatisfactory. Usual disclaimer applies.
George.
old mart14/10/2019 15:50:34
4655 forum posts
304 photos
I bought ER25 and the first cheap Chinese one had a 0.002" tir runout, the second is less than 0.0004" tir. The collets were a lottery too, so I have collets in 6,8,10,12 and 16mm from Cutwell and Vertex, which are very good.
Nick M0NPH14/10/2019 20:25:59
24 forum posts
That would be Tracy tools in Torquay Devon
www.tracytools.com
i have used them in the past and they seam to be ok on most prices and quick delivery
Nick
