Member postings for Charles R
Here is a list of all the postings Charles R has made in our forums. Click on a thread name to jump to the thread.
Thread: What is this mic used for?
04/08/2020 20:35:58
Also, it's different in that it reads in the opposite direction to a normal depth mic, plus it's only graduated to 13mm.
04/08/2020 20:33:52
Posted by Clive Foster on 04/08/2020 14:01:28:
That style of micrometer head an bock is frequently found on the micrometer adjusted slides / carriers used with optical benches and tables. Usually two counterbored holes to fixt it.
Think you may have hit the nail on the head Clive, as there are indeed 2 small counterbored holes in it.
04/08/2020 20:31:24
Posted by Mike Poole on 04/08/2020 14:00:38:
The micrometer parts are available for use on custom jigs etc. They are handy to make into a special purpose mic should you ever develop the need for one.
Hi Mike...didn't realise that and thanks for info.
04/08/2020 20:30:18
Posted by Clive Brown 1 on 04/08/2020 13:22:50:
Agree with Nick. The standard M&W depth mic. had a rather more shapely block.depth micrometer.jpg
Hi Clive...I thought the same myself about the unshapely block, which incidentally measures (exactly) 1/2" in depth.
04/08/2020 20:26:32
Posted by Nicholas Farr on 04/08/2020 12:46:53:
Hi Charles R, could just be a micrometer head fitted to a custom made block which probably fitted to an instrument or machine for setting procedures. Does it have a number on the thimble?
Regards Nick.
Hi Nick...think you may well be correct and there's no M&W model number on the thimble.
04/08/2020 12:20:36
Can anyone shed light on the purpose of this metric Moore and Wright tool?
Looks like a conventional depth mic but has the scale going in the opposite direction.20200804_121710.jpg
Thread: Cheap ER collet advice please
15/10/2019 12:13:51
Posted by Nicholas Wheeler 1 on 15/10/2019 11:15:33:
Posted by Charles R on 15/10/2019 01:29:05:
Posted by old mart on 14/10/2019 21:58:26:
Unless you want to use a full range of twist drills, you don't need a full set of collets as milling cutters come in much more limited shank sizes.
A complete ER25 set would be great but I don't want to spend lots on something I may not use that often.
As ER collets can be used for both tool and workholding, not buying a set is a false economy.
I bought an ER32 chuck to use on the mill, and intending to get a bolt on chuck for the lathe, bought a full set of collets. The collet chuck was such an improvement that I quickly gave the Clarkson clone away, and bought the lathe chuck. 12 years later, only one of the collets is still in its plastic wrapping. Some of the rest haven't been used much, but it beats having to stop work for a few days to get a £5 part that should have been bought as part of a set.
I use the collet chuck for drills when doing jobs that combine milling and drilling. I'm tempted to buy extras of the common ones I use to keep with particular tools, like the edge finder, to speed up changes. I find the idea that hobbyests don't need to work quickly and efficiently very strange.
Arc's Stevensons collet blocks really simplify milling/drilling operations on round parts.
The ball-bearing nuts are such an improvement that I bought another pair so that each chuck has its own and the blocks share the third.
I have a set of ER11 collets to use with my toolpost spindle lashup; I'm very tempted to convert one of my MT blanks into a holder to use small drills in the tailstock.
Thank you for the info Nicholas.
I'm starting to think the same re. buying a set...it would be very handy, if not now, in the future.
Will look into the other items you mentioned later on tonight.
Edited By Charles R on 15/10/2019 12:15:30
15/10/2019 12:10:37
Posted by Chris Evans 6 on 15/10/2019 08:45:27:
Plus 1 for ARC and Chronos. A £ more on 6 or 8 collets is forgotten in short time. I use 5C collets on my lathe and have never bought one that was not up to scratch.
Just been looking on their respective websites.
15/10/2019 01:29:05
The collet chuck I have is for my lathe and I initially intend to use it for holding some milling cutters I got with the lathe when I purchased it.
A big thanks to everyone who has taken the time to write me a reply and I've taken in everything that's been said.
14/10/2019 12:08:56
Dave...you should change your username to WiseOldDuffer!
I agree with you on all points.
My little lathe has a max speed of 1050rpm, so no need for me to buy high end where balance and precision are crucial.
I haven't heard of Tracy but will have a look later today.
Charles
14/10/2019 10:25:11
Posted by Tony Pratt 1 on 14/10/2019 06:51:05:
I see CTC actually give a tolerance run out of .008mm, if they don't meet that standard you can get your money back [Paypal - item not as described, credit card - chargeback] so a win win situation. They would also have to pay postage if they wanted the collet[s] back.
Tony
Good thinking Tony...I need to get a set where there are claimed tolerances and if the collets are out of spec, then I can return them for a refund.
Edited By Charles R on 14/10/2019 10:27:06
14/10/2019 10:18:25
Thanks everyone for their advice.
14/10/2019 00:20:30
Thanks for the replies and help, Mike and Emgee.
Mike...haven't heard of CTC before, so just had a quick search...would this be www.ctctools.biz ? I'm guessing you've been buying collets individually, as and when needed?
Emgee...that's an excellent price but unfortunately the seller currently has no items for sale though I will definitely keep an eye out for new listings.
13/10/2019 22:34:57
I need to get a set of ER25 collets.
I've been looking at the cheap Chinese offerings on eBay.
I realise this is a bit of a lottery as some people appear to be happy with their purchases and others, not.
The quality of these collets seems to vary a lot.
Has anyone here bought a good cheap set and if they have, can you let me know what seller they were bought from?
From what I've seen, pretty much all of them seem to be located /shipped from Leicestershire irrespective of who's selling them!
Any advice much appreciated, thanks.
Thread: Hi from Portsmouth
13/10/2019 22:18:49
Thanks Neil.
Charles
Edited By Charles R on 13/10/2019 22:21:02
Thread: Perfecto 3-1/2" x 16" lathe half nut lever operation
03/10/2019 11:42:00
Hi Diogenes, thanks.
I made some new pins and deburred the curved slots yesterday as they were indeed pretty rough!
The whole mechanism is working much better now.
02/10/2019 19:50:43
Posted by Raymond Griffin on 30/09/2019 10:52:03:
Hi, I have the one of these lathes. It sounds as though somebody has been very heavy handed on the lever: to bend the pins. I also have a copy of the instructions and a screw cutting chart and can send them on to an e-mail address. Ray
Hi Ray...yes please for the copies!
I sent you my details via pm just after you posted this.
Regards, Charles
30/09/2019 22:36:34
Thanks for the welcome George and Sean...and thanks George for the invite. When I have a bit of spare time, I'd like to pop along and take a look around.
30/09/2019 22:23:48
I'm overwhelmed with everyone's willingness to be helpful and to take time to post replies...it's very much appreciated.
I had a more in depth look today and it very much seems like my setup is indeed working on friction alone like most people have suggested.
The half nut pins are pretty useless now bent, so I intend to make some replacement ones.
Some more photos below...
29/09/2019 22:02:23
...and another.
