Please discuss freely ...
Michael Gilligan | 13/10/2019 12:24:05 |
![]() 23121 forum posts 1360 photos | A friend who is a professional Clock repairer/restorer recently shared these photos of an hour wheel, from a long-case clock which passed through his workshop. My initial reaction was: “Hideous as it may be ... that hour-wheel repair is rather clever.” . I then obtained his permission to post them here, for your consideration. This is neither a ‘how to do it’ nor a ‘how not to do it’ thread ... but I will be very interested to see peoples’ opinions. Feel free to let the discussion include other scenarios; there are no rules ! [ and if you don’t like the way the thread develops, please just ignore it ] MichaelG. |
Nick Wheeler | 13/10/2019 12:44:15 |
1227 forum posts 101 photos | Unsightly not hideous, but certainly clever. I wonder how long it has been like that? |
JasonB | 13/10/2019 13:21:38 |
![]() 25215 forum posts 3105 photos 1 articles | Better for the "repairer" to work with what they had rather than leave the clock gathering dust and not working. Is the repair soft soldered to the wheel? Edited By JasonB on 13/10/2019 13:21:49 |
Michael Gilligan | 13/10/2019 13:30:10 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 13/10/2019 13:21:38:
Better for the "repairer" to work with what they had rather than leave the clock gathering dust and not working. Is the repair soft soldered to the wheel? . Agreed, Jason ... and yes. MichaelG. |
Mike Poole | 13/10/2019 13:32:19 |
![]() 3676 forum posts 82 photos | I love a bit of alternative engineering, I have used it myself on many occasions. It is amazing what you can do with a few bits and pieces that are laying around or can be repurposed.. Mike |
Clive Steer | 13/10/2019 13:37:09 |
227 forum posts 4 photos | I think this repair scheme, although not orthodox or elegant , should be high on the conservationists score as it neither adds nor subtract material from the original artefact and if adopted using modern super glue could be reversible with no lasting impact on the artefact. The orthodox repair usually required a slot or dovetail shape to be cut into the wheel and a single or multiple teeth usually donated by a similar wheel to be shaped to fit and soft soldered in place. Another accepted approach is to make and fit a new, signed and dated, wheel and leave the old one with the movement. If taken to the limit one could make a completely new movement and leave the old one in the bottom of the case where at least it won't wear out or need servicing again. Unfortunately the value of long case clocks is so low that, unless they are family heirlooms, they are beyond economical repair. I think a sketch, similar to the well known one about a Norwegian Blue, could be written for long case clocks. Clive |
Gary Wooding | 13/10/2019 13:38:04 |
1074 forum posts 290 photos | I think its ingenious. Not pretty, but effective. |
RichardN | 13/10/2019 13:50:53 |
123 forum posts 11 photos | I find it quite pleasing aesthetically- but one query for the clockmakers- what is the impact of wheel balance on the movement both rotationally (with that tooth tending to slump to bottom of rotation) as well as altering load on the bearing points? |
Ron Laden | 13/10/2019 13:55:03 |
![]() 2320 forum posts 452 photos | I dont think hideous Michael and I agree quite clever really. Looking at it from just the tooth side and not knowing anything about clocks I would have probably glanced at it and thought it designed that way and served a function for each revolution of the wheel. Ron |
Brian Wood | 13/10/2019 13:56:17 |
2742 forum posts 39 photos | Not pretty but quick and very practical. John Stevenson would have certainly have approved, it is clearly in bodger's territory and presumably it still works as intended. Brian
DiogenesII | 13/10/2019 14:18:09 |
859 forum posts 268 photos | That is a clever repair - and I hope will be left "as is" as an example of "folk" engineering - one wonders what, and how many, similarly ingenious examples of lateral thinking and applied empirical knowledge have been lost through the "putting-right" of perceived "bodges" of the past, in everything from watermills to pocketwatches.. ..it cheers to to think that that particular repair would probably be greeted with the same wry admiration by the maker of the Antikythera Mechanism that it seems to elicit here. |
roy entwistle | 13/10/2019 14:21:37 |
1716 forum posts | I have seen a straight piece of brass shaped like a tooth soldered to the side of a wheel on a thirty hour long case Roy |
Neil Wyatt | 13/10/2019 17:10:02 |
![]() 19226 forum posts 749 photos 86 articles | Ingenious, and not done without skill. Neil |
David Noble | 13/10/2019 18:06:31 |
![]() 402 forum posts 37 photos | Being involved in maintenance engineering for a long time, I think that it's a brilliant repair : )
David |
Nicholas Farr | 13/10/2019 18:36:19 |
![]() 3988 forum posts 1799 photos | Hi, similar techniques were often used on breakdowns during my maintenance years, when production was imperative, although they were repaired or replace during a suitable ASAP shutdown period. If it works and cosmetic appearance is not an issue, then I think it's fine. Regards Nick. |
Meunier | 13/10/2019 19:11:34 |
448 forum posts 8 photos | Handsome is, as handsome does. DaveD |
Bazyle | 13/10/2019 20:46:57 |
![]() 6956 forum posts 229 photos | The pinion is of course wider than the wheel and the repairer understood the principles of operation of a cycloidal gear. |
Howard Lewis | 13/10/2019 20:55:18 |
7227 forum posts 21 photos | Where needs must! Lantern pinions are used in clocks, so this would probably worked fairly well. Not necessarily Engineering as we know it Jim, but it does the job. Far better than taking out of service or scrapping an otherwise good mechanism. You wonder how the original tooth became damaged. Howard |
Michael Gilligan | 13/10/2019 22:08:26 |
![]() 23121 forum posts 1360 photos | Thanks for all the comments so far ... I confess that I am a little surprised [but delighted] to see that everyone takes a positive view about the work done. ... I was half expecting comments like “if you can’t be bothered to do it properly, just put a Quartz insert in” ... but everyone seems to appreciate the sound engineering principle. Sorry, I have no idea how long it was in service. MichaelG. |
duncan webster | 14/10/2019 00:01:38 |
5307 forum posts 83 photos | Posted by Ron Laden on 13/10/2019 13:55:03:
Ron Pedant alert: I don't think Michael is hideous, but I've never met him! and I don't understand smileys or I'd put one in Edited By duncan webster on 14/10/2019 00:02:21 |
