Philip Burley | 23/09/2019 17:26:26 |
![]() 198 forum posts 1 photos | A couple of weeks ago I made a mix of citric acid from powder , I used it for cleaning some copper parts before I soldered them . Today I took the lid off to use it again and found it contaminated with a lot of small black balls of something . I would have thought that the mildly acid solution would kill off any fungus etc Any ideas what this might be ? Phil |
Neil Wyatt | 23/09/2019 17:52:17 |
![]() 19226 forum posts 749 photos 86 articles | Probably fungus... citric acid a.k.a. vitamin C isn't very toxic and in dilute form it's probably even food source for some things. Neil |
Michael Gilligan | 23/09/2019 18:02:55 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 23/09/2019 17:52:17:
... citric acid a.k.a. vitamin C ... .
MichaelG. . https://www.uwhealth.org/files/uwhealth/docs/pdf/kidney_citric_acid.pdf Edited By Michael Gilligan on 23/09/2019 18:03:19 |
Michael Cox 1 | 23/09/2019 18:16:10 |
555 forum posts 27 photos | Vitamin C is ascorbic acid. |
SillyOldDuffer | 23/09/2019 18:30:52 |
10668 forum posts 2415 photos | Posted by Philip Burley on 23/09/2019 17:26:26:
A couple of weeks ago I made a mix of citric acid from powder , I used it for cleaning some copper parts before I soldered them . Today I took the lid off to use it again and found it contaminated with a lot of small black balls of something . I would have thought that the mildly acid solution would kill off any fungus etc Any ideas what this might be ? Phil Fungus and bacteria having a feast probably. Citric Acid is common in many fruits and edible. The crystals are fairly resistant to hungry bugs but add water and Citric Acid goes off just like a rotting Lemon or Lime. 'Acid' always sounds a scary but most of them are weaklings. Citric is one of the mild organic acids: it's not in the same league as Sulphuric, Hydrochloric, or Nitric which are strong mineral acids. Dave |
Philip Burley | 23/09/2019 18:52:38 |
![]() 198 forum posts 1 photos | So should I dump this and mix some fresh , or carry on using it , Will it still have the cleaning effect ? Should I have made a stronger mix ? Phil |
JA | 23/09/2019 19:03:43 |
![]() 1605 forum posts 83 photos | I would guess it is a fungus or some form of lower life. These can turn up in unexpected places such as in petrol and aviation fuel. Why don't you just try using your citric acid. It will either work or not work. What ever it is will not eat your copper. Fungi are more likely to be killed by copper than citric acid. JA Edited By JA on 23/09/2019 19:05:47 |
Howard Lewis | 23/09/2019 19:05:31 |
7227 forum posts 21 photos | Amazing where fungi will grow. At school, we found that the winchester of fuming sulphuric acid had a white fungus growing in it. In THAT environment? Try out your solution on a some metal. If it works satisfactorily, use it. If it doesn't, dispose of it safely Howard |
Hacksaw | 23/09/2019 20:35:12 |
474 forum posts 202 photos | If it tastes mouldy it probably is |
Enough! | 23/09/2019 22:11:12 |
1719 forum posts 1 photos | Posted by Neil Wyatt on 23/09/2019 17:52:17:
citric acid ....... it's probably even food source for some things.
Like humans? |
Michael Gilligan | 23/09/2019 22:51:57 |
![]() 23121 forum posts 1360 photos | Posted by Philip Burley on 23/09/2019 17:26:26:
A couple of weeks ago I made a mix of citric acid from powder , I used it for cleaning some copper parts before I soldered them . Today I took the lid off to use it again and found it contaminated with a lot of small black balls of something . I would have thought that the mildly acid solution would kill off any fungus etc Any ideas what this might be ? Phil . Possibly aspergillus niger, which [oddly enough] is used in the production of Citric Acid Photos, or a rough estimate of size might help. MichaelG. |
James Alford | 24/09/2019 07:25:59 |
501 forum posts 88 photos | I used citric acid to pickle copper a lot a while ago. It regularly grew mould on the surface, irrespective of the strength of the solution. However, it worked just as well with or without the fur coat. It just looked a bit grim. James. |
Clive India | 24/09/2019 07:54:51 |
![]() 277 forum posts | Adding a small amount of bleach fixes the mould problem for me. Edited By Clive India on 24/09/2019 07:58:27 |
thaiguzzi | 24/09/2019 09:23:13 |
![]() 704 forum posts 131 photos | Posted by Philip Burley on 23/09/2019 18:52:38:
So should I dump this and mix some fresh , or carry on using it , Will it still have the cleaning effect ? Should I have made a stronger mix ? Phil Nah, add a double Vodka in there, it'll be fine... |
Neil Wyatt | 24/09/2019 09:51:07 |
![]() 19226 forum posts 749 photos 86 articles | Posted by Michael Cox 1 on 23/09/2019 18:16:10:
Vitamin C is ascorbic acid. D'oh! Engage brain before keyboard... |
Michael Gilligan | 24/09/2019 10:25:04 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 24/09/2019 09:51:07:
Vitamin C is ascorbic acid. D'oh! Engage brain before keyboard... . Sulking ... Why does Michael Cox get the credit ? |
JA | 24/09/2019 12:57:04 |
![]() 1605 forum posts 83 photos | Posted by Howard Lewis on 23/09/2019 19:05:31:
Try out your solution on a some metal. If it works satisfactorily, use it. If it doesn't, dispose of it safely Howard If it just citric acid I guess you pour it down the sink. My pickling acid, made from powder bought from CuP Alloys, is now a nice green colour since used acid is returned to bottle. I guess the green is copper citrate. I would think the powder I bought contained a biocide since I never had anything grow in the liquid. JA |
Tim Stevens | 24/09/2019 17:07:28 |
![]() 1779 forum posts 1 photos | I wonder if the 'mould' seen by Howard Lewis was actually crystals of SO3, and not a fungus at all. Fuming H2SO4 is so eager to combine with the tiniest speck of water that it would not make a good environment for anything living - mould, germ, or virus. Just because it looked fluffy, do not be misled. Cheers Tim |
Clive India | 25/09/2019 09:03:15 |
![]() 277 forum posts | Posted by Clive India on 24/09/2019 07:54:51:
Adding a small amount of bleach fixes the mould problem for me. Just a reminder
